Author Topic: Virtual key  (Read 4035 times)
David Hall
  • Automatic Duh Generator
Virtual key
« on: August 09, 2006, 12:34:13 PM »
I had nothing better to do, so I tried to duplicate Keith's Capsmanager program in C#.  I cant get it to work.  Any ideas?
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Data;
using System.Runtime.InteropServices;
using System.Text;
namespace Caps
/// <summary>
/// Summary description for Form1.
/// </summary>
public class Form1 : System.Windows.Forms.Form
private System.Windows.Forms.Label label1;
private System.Windows.Forms.Timer timer1;
private System.Windows.Forms.Label IDWindowLabel;
private System.ComponentModel.IContainer components;
public Form1()
// Required for Windows Form Designer support
InitializeComponent();
// TODO: Add any constructor code after InitializeComponent call
/// <summary>
/// Clean up any resources being used.
/// </summary>
protected override void Dispose( bool disposing )
if( disposing )
if (components != null)
components.Dispose();
base.Dispose( disposing );
#region Windows Form Designer generated code
/// <summary>
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
private void InitializeComponent()
this.components = new System.ComponentModel.Container();
this.label1 = new System.Windows.Forms.Label();
this.timer1 = new System.Windows.Forms.Timer(this.components);
this.IDWindowLabel = new System.Windows.Forms.Label();
this.SuspendLayout();
// label1
this.label1.Location = new System.Drawing.Point(32, 72);
this.label1.Name = "label1";
this.label1.Size = new System.Drawing.Size(208, 48);
this.label1.TabIndex = 0;
this.label1.Text = "label1";
// timer1
this.timer1.Enabled = true;
this.timer1.Tick += new System.EventHandler(this.timer1_Tick);
// IDWindowLabel
this.IDWindowLabel.Location = new System.Drawing.Point(32, 152);
this.IDWindowLabel.Name = "IDWindowLabel";
this.IDWindowLabel.Size = new System.Drawing.Size(232, 23);
this.IDWindowLabel.TabIndex = 1;
this.IDWindowLabel.Text = "label2";
// Form1
this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
this.ClientSize = new System.Drawing.Size(292, 273);
this.Controls.Add(this.IDWindowLabel);
this.Controls.Add(this.label1);
this.Name = "Form1";
this.Text = "Form1";
this.Load += new System.EventHandler(this.Form1_Load);
this.ResumeLayout(false);
#endregion
/// <summary>
/// The main entry point for the application.
/// </summary>
[STAThread]
static void Main()
Application.Run(new Form1());
[ DllImport("user32.dll") ]
static extern int GetForegroundWindow();
static extern int GetWindowText(int hWnd, StringBuilder text, int count);
[DllImport("user32.dll")]
public static extern short GetKeyboardState(byte[] kbBytes);
public static extern short SetKeyboardState(byte[] kbBytes);
private void GetActiveWindow()
const int nChars = 256;
int handle = 0;
StringBuilder Buff = new StringBuilder(nChars);
handle = GetForegroundWindow();
if ( GetWindowText(handle, Buff, nChars) > 0 )
this.label1.Text = Buff.ToString();
if (this.label1.Text.StartsWith("AutoCAD 2007"))
SetCapsLock(true);
else
SetCapsLock(false);
//this.label1.Text = Buff.ToString();
this.IDWindowLabel.Text = handle.ToString();
private void SetCapsLock(bool Enabled)
byte[] kbBytes = new byte[256];
GetKeyboardState(kbBytes);
kbBytes[20] = 0;
if (Enabled == true)
kbBytes[20] = 1;
SetKeyboardState(kbBytes);
private void timer1_Tick(object sender, System.EventArgs e)
GetActiveWindow();
private void Form1_Load(object sender, System.EventArgs e)
Greg B
  • Tell me a Joke!
Re: Virtual key
« Reply #1 on: August 09, 2006, 12:38:58 PM »
:blink blink:
David Hall
Re: Virtual key
« Reply #2 on: August 09, 2006, 05:52:37 PM »
ok, I got it working, here is what I did
using System;
using System.Data;
using System.Text;
namespace ACAD_CapsLockUtil
/// <summary>
/// </summary>
public class frmMain : System.Windows.Forms.Form
public frmMain()
/// <summary>
/// </summary>
if( disposing )
/// <summary>
/// </summary>
System.Resources.ResourceManager resources = new System.Resources.ResourceManager(typeof(frmMain));
this.niMain = new System.Windows.Forms.NotifyIcon(this.components);
this.niMenu = new System.Windows.Forms.ContextMenu();
this.miPauseStart = new System.Windows.Forms.MenuItem();
this.lblAbout = new System.Windows.Forms.Label();
this.pictureBox1 = new System.Windows.Forms.PictureBox();
this.btnOK = new System.Windows.Forms.Button();
this.menuItem1 = new System.Windows.Forms.MenuItem();
this.menuItem2 = new System.Windows.Forms.MenuItem();
// niMain
this.niMain.ContextMenu = this.niMenu;
this.niMain.Icon = ((System.Drawing.Icon)(resources.GetObject("niMain.Icon")));
this.niMain.Text = "TEP AutoCad CapsLock Utility";
this.niMain.Visible = true;
// niMenu
this.niMenu.MenuItems.AddRange(new System.Windows.Forms.MenuItem[] {
   this.miPauseStart,
   this.menuItem1,
   this.menuItem2});
// miPauseStart
this.miPauseStart.Index = 0;
this.miPauseStart.Text = "Pause";
this.miPauseStart.Click += new System.EventHandler(this.miPauseStart_Click);
// timer1
// lblAbout
this.lblAbout.Location = new System.Drawing.Point(48, 8);
this.lblAbout.Name = "lblAbout";
this.lblAbout.Size = new System.Drawing.Size(232, 32);
this.lblAbout.TabIndex = 0;
this.lblAbout.Text = "About";
this.lblAbout.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
// pictureBox1
this.pictureBox1.Image = ((System.Drawing.Image)(resources.GetObject("pictureBox1.Image")));
this.pictureBox1.Location = new System.Drawing.Point(8, 8);
this.pictureBox1.Name = "pictureBox1";
this.pictureBox1.Size = new System.Drawing.Size(32, 32);
this.pictureBox1.TabIndex = 1;
this.pictureBox1.TabStop = false;
// label1
this.label1.Location = new System.Drawing.Point(16, 56);
this.label1.Size = new System.Drawing.Size(264, 168);
this.label1.TabIndex = 2;
// btnOK
this.btnOK.Location = new System.Drawing.Point(112, 232);
this.btnOK.Name = "btnOK";
this.btnOK.TabIndex = 3;
this.btnOK.Text = "OK";
this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
// menuItem1
this.menuItem1.Index = 1;
this.menuItem1.Text = "-";
// menuItem2
this.menuItem2.Index = 2;
this.menuItem2.Text = "Help";
this.menuItem2.Click += new System.EventHandler(this.menuItem2_Click);
// frmMain
this.ControlBox = false;
this.Controls.Add(this.btnOK);
this.Controls.Add(this.pictureBox1);
this.Controls.Add(this.lblAbout);
this.Icon = ((System.Drawing.Icon)(resources.GetObject("$this.Icon")));
this.Name = "frmMain";
this.Text = "TEP AutoCad CapsLock Utility";
this.Load += new System.EventHandler(this.frmMain_Load);
this.Paint += new System.Windows.Forms.PaintEventHandler(this.frmMain_Paint);
/// <summary>
/// </summary>
[STAThread]
static void Main()
Application.Run(new frmMain());
private System.Windows.Forms.NotifyIcon niMain;
private System.Windows.Forms.ContextMenu niMenu;
private System.Windows.Forms.MenuItem miPauseStart;
private System.Windows.Forms.Label lblAbout;
private System.Windows.Forms.PictureBox pictureBox1;
private System.Windows.Forms.Button btnOK;
private System.Windows.Forms.MenuItem menuItem1;
private System.Windows.Forms.MenuItem menuItem2;
#endregion
const byte VK_CAPITAL=0x14;
string ActiveAppTitle = "Rob H. Needs A Raise Without Any Added Responsibilities";
bool Initial = false;
static extern void keybd_event(byte bVk, byte bScan, uint dwFlags, UIntPtr dwExtraInfo);
public static extern short GetKeyState(int nVirtKey);
private void ToggleKey(byte KeyCode)
const int KEYEVENTF_EXTENDEDKEY = 0x1;
const int KEYEVENTF_KEYUP = 0x2;
keybd_event(KeyCode, 0x45, KEYEVENTF_EXTENDEDKEY, (UIntPtr) 0);
keybd_event(KeyCode, 0x45, KEYEVENTF_EXTENDEDKEY | KEYEVENTF_KEYUP, (UIntPtr) 0);
private void miPauseStart_Click(object sender, System.EventArgs e)
if (timer1.Enabled)
timer1.Enabled = false;
miPauseStart.Text = "Re-Start";
else
private void frmMain_Load(object sender, System.EventArgs e)
lblAbout.Text = "This program was created for TEP \n by Robert Houts and David Hall";
label1.Text = "This program was created to ensure that the caps lock key is enabled while you are working in AutoCAD.  When AutoCAD is the active window, it will turn the Caps Lock key On and when you leave AutoCAD, it will turn Caps Lock Off.  \n\nKeep in mind, you can still manually toggle the Caps Lock key on your own and you can pause this program by right-clicking the 'C' icon and selecting 'Pause'.  You re-enable this program by right-clicking the 'C' icon and selecting 'Re-Start'. \n\nThank you and Happy Drafting! :-)";
private void btnOK_Click(object sender, System.EventArgs e)
this.Hide();
private void menuItem2_Click(object sender, System.EventArgs e)
this.Visible = true;
string CurrentTitle = GetActiveWindowTitle();
if (ActiveAppTitle != CurrentTitle)
if (CurrentTitle.StartsWith("AutoCAD "))
if (GetKeyState(VK_CAPITAL) == 0)
ToggleKey(VK_CAPITAL);
else
if (GetKeyState(VK_CAPITAL) == 1)
ActiveAppTitle = CurrentTitle;
CurrentTitle = string.Empty;
private string GetActiveWindowTitle()
int handle = 0;
return Buff.ToString();
else
return string.Empty;
private void frmMain_Paint(object sender, System.Windows.Forms.PaintEventArgs e)
if (Initial == false)
this.Hide();
Initial = true;
MickD
Re: Virtual key
« Reply #3 on: August 09, 2006, 06:36:53 PM »
Nice one 'Duh, there is proabably something there to help Dave Baranas in all that for his palette problem. I found the same trouble but didn't want to dip into PInvoke to hook into the keyboard to fix it but it may be the only way.
- John Carmack
- J.R.R. Tolkien
Re: Virtual key
« Reply #4 on: August 09, 2006, 10:12:59 PM »
OK, so whatever is typed, the displayed text is "David and Rob deserve a substantial raise" ... yes ?
[seriously]
Until we all come to grips with theparticular idiosyncrasies of the language, or till "someone" produces docs, whatever works may be the way to go ..   Not purist, I know, but bloody practical !!
