Not too far evidently..
Since I got such an overwhelming response to my drag and drop problem
and could not find an answer anywhere else I decided to suck it up and write an insert method. I didn't want any autocad related code in my project and I didn't want to lock this down to a particular version of autocad so I decided to attempt using late binding in c#.
Here is the result:
// method to insert a drawing file into autocad using late binding.
// As of 8/7/06 Tested for versions 2000 to 2007
public static void InsertDrawingLB(string sDwgName)
object acadApp = null;
object[] parameters;
object cmd = null;
if (!File.Exists(sDwgName))
throw new System.ArgumentException("Drawing does not exist", "sDwgName");
// try to open an existing instance
try
acadApp = (object)Marshal.GetActiveObject("AutoCAD.Application");
catch // if not successful try to start a new instance
try
acadApp = (object)Microsoft.VisualBasic.Interaction.CreateObject(
"AutoCAD.Application", null);
parameters = new object[1];
parameters[0] = true;
cmd = acadApp.GetType().InvokeMember("Visible",
BindingFlags.SetProperty, null, acadApp, parameters);
catch // you don't even have autocad installed
throw new System.Exception("Could Not find AutoCAD to open");
try // need to make autocad active and the top dog
cmd = acadApp.GetType().InvokeMember("Caption",
BindingFlags.GetProperty, null, acadApp, null);
string caption = (string)cmd;
Microsoft.VisualBasic.Interaction.AppActivate(caption);
cmd = acadApp.GetType().InvokeMember("WindowState",
parameters[0] = 3;
catch
throw new System.Exception("Problem forcing the AutoCAD window to Top");
object dwg = null;
try // finally, insert the drawing using the newest technology - a script!!!
// first get the drawing
try
dwg = acadApp.GetType().InvokeMember("ActiveDocument",
catch
throw new System.Exception("You must have a drawing loaded");
string sTemp = "(Command " + @"""" + "Insert" + @"""" + " " + @"""" +
sDwgName + @"""" + " )" + "\r";
parameters[0] = sTemp;
cmd = dwg.GetType().InvokeMember("SendCommand",
BindingFlags.InvokeMethod, null, dwg, parameters);
catch
throw new System.Exception("Could not Insert the drawing");
What cracks me up is, when all said and done, I had to use visual basic (.net admittedly), scripting a string using sendcommand to send an autolisp string to the command prompt.
anyway, this works if you ever need it. No reference to autocad needed (com or otherwise).
oh, and if you see a better way of doing this, please post.
