Author Topic: InputBox  (Read 6171 times)
Patrick_35
InputBox
« on: August 04, 2006, 04:10:40 AM »
Hello
Also my small contribute share on this fabulous site
To supplement what Gary Fowler did on this nice post http://www.theswamp.org/index.php?topic=9684.0 and in same logic, here the InputBox function
(defun InputBox (Title Message Default XPos YPos / users1 value)
  (if (not Xpos)
    (setq XPos (* (/ (car (getvar "screensize")) 2) 10)))
  (if (not YPos)
    (setq YPos (* (/ (cadr (getvar "screensize")) 2) 10)))
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (setq users1 (getvar "users1"))
  (acad-push-dbmod)
  (vla-eval
    *acad*
    (strcat
      "ThisDrawing.SetVariable \"USERS1\","
      "InputBox (\""
      Message
      Title
      Default
      (rtos XPos)
      (rtos YPos)
  (setq value (getvar "users1"))
  (setvar "users1" users1)
  (acad-pop-dbmod)
  value
(InputBox "My title" "My Message" "Default" nil nil)
(InputBox "My title" "My Message" "Default" 150 200)
Didge
Re: InputBox
« Reply #1 on: August 04, 2006, 07:20:01 AM »
Nice One Patrick  :-)
Think Slow......
lispman21
Re: InputBox
« Reply #2 on: August 04, 2006, 08:24:56 AM »
Never used an input box like this.  What type of application would you use it in or for.
Re: InputBox
« Reply #3 on: August 04, 2006, 08:35:08 AM »
Patric I get this error using ACAD2000.
Command: (inputbox "My title" "My Message" "Default" nil nil)
; error: Automation Error. VBA expression evaluation failed
; reset after error
Fatty
Re: InputBox
« Reply #4 on: August 04, 2006, 08:35:46 AM »
Hi, guys
You can play with this also: 8-)
(defun AnswerMe (TitleStr MsgStr  / IntPass StrPass)
(setq WshShell (vlax-create-object "WScript.Shell"))
(setq IntPass (vlax-invoke WshShell 'Popup
TitleStr  7
MsgStr  35)
(setq StrPass
(cond ((= intPass 6) "Yes")
      ((= intPass 7) "No")
      ((= intPass 2) "Not sure about")))
(alert StrPass);for debug only
(vlax-release-object WshShell)
; CaLL :
(AnswerMe "Do you want something?" "Answer My Question:" )
Fatty
~'J'~
Re: InputBox
« Reply #5 on: August 04, 2006, 08:42:10 AM »
; reset after error
Perhaps include this in the initialization bit Alan --
(if (null (member "acvba.arx" (arx)))
    (arxload "acvba.arx")
Nice demonstration Patrick; you too Fatty.
Re: InputBox
« Reply #6 on: August 04, 2006, 08:54:04 AM »
Hummm.
Command: (arxload "acvba.arx")
; error: ARXLOAD failed
; reset after error
Search failed to find this.
Gotta go, so I'll look again later.
Re: InputBox
« Reply #7 on: August 04, 2006, 09:03:46 AM »
What version of AutoCAD are you runnin' Alan? Maybe it'll have to perform a more intelligent | branched load on the arxname. I've only got 2006 here and don't know them off the top of my head.
Re: InputBox
« Reply #8 on: August 04, 2006, 11:53:34 AM »
I am using ACAD2000 to test & this one runs fine
Must be an ACAD version problem so don't spend any time chasing it.
If I have time later I'll try it in 2006.
LE
Re: InputBox
« Reply #9 on: August 04, 2006, 12:20:21 PM »
I tried too... and I got same error as Alan using A2005 - and having loaded "acvba.arx"
GDF
Re: InputBox
« Reply #10 on: August 04, 2006, 03:26:38 PM »
Same error using 2006
Gary
Patrick_35
Re: InputBox
« Reply #11 on: August 04, 2006, 05:44:04 PM »
If you need an input in your application, you can use it
After your message, i tested it in ACAD2000 and the code do it, not error
It's "acvba.arx" or "acadvba.arx" ?
In my french version of ACAD2000, i find "acadvba.arx", not "acvba.arx"
Thank's for you code Fatty, good job
Serge J. Gianolla
Re: InputBox
« Reply #12 on: August 06, 2006, 04:32:12 PM »
Patrick, no problemo here on 2006. Ca marche au poil!
Fatty good work too.
Fatty
Re: InputBox
« Reply #13 on: August 06, 2006, 05:11:13 PM »
Thanks to all, guys
I am still learning  :-)
Fatty
~'J'~
Patrick_35
Re: InputBox
« Reply #14 on: August 07, 2006, 03:21:41 AM »
Thanks Serge
Your remark make me think that it will be necessary for me to find a new avatar  :-)
J'ai remarqué aussi qu'il va falloir grandement améliorer mon anglais et désolé pour les fautes   :|
Amicalement
Flatty
I see your code and i don't understand what the parameter number seven can be serve  :?
