Author Topic: Helix issue  (Read 4685 times)
johnjoe
Helix issue
« on: March 24, 2004, 03:50:43 PM »
HI,
Im having a problem extruding a non-circular shape around a helix. The shape I need to extrude is rectangular. Whenever I extrude a rectangle around a polyline helix (into solid form) the rectangle gets twisted. The rectangle starts off perpendicular to the axis of the helix and ends up twisted at an angle. I checked a number of furums and noticed other people had problems with helix's. Perhaps Autocad can't do this. If this is the case, is there a relatively easy way aound this. I'd like to point out that I'm not interested in extruding a circle. Id apreciate some feedback on this,
ELOQUINTET
Helix issue
« Reply #1 on: March 24, 2004, 03:54:40 PM »
ah there ya go john sorry no answer for your question  :oops:
Helix issue
« Reply #2 on: March 24, 2004, 03:59:59 PM »
Click on this as it may be what you are looking for.
hyposmurf
Helix issue
« Reply #3 on: March 24, 2004, 05:45:55 PM »
Fuccaro again :) ,he'll have to say something soon on this forum,hey Fuccaro :wink: :)
Fuccaro
Helix issue
« Reply #4 on: March 25, 2004, 01:24:33 AM »
Quote from: hyposmurf
SOMETHING
Fuccaro
Helix issue
« Reply #5 on: March 25, 2004, 01:31:18 AM »
Johnjoe
If you wish to use that lisp you should read this first:
http://cadtutorforum.net/forum/viewtopic.php?t=477
Sorry, the program itself isn't well documented...
Good luck!
hyposmurf
Helix issue
« Reply #6 on: March 25, 2004, 07:58:52 AM »
I guess I was asking for that Fuccaro,nice to see you pop up up anyway :)
Helix issue
« Reply #7 on: March 25, 2004, 08:17:13 AM »
Welcome Fuccaro,
 I posted that link in with the code that I posted here.
I had the code but lost track of where I found it.
Thanks.
P.S.
I admire your talents programing with DCL as well. :)
Fuccaro
Helix issue
« Reply #8 on: March 25, 2004, 10:06:08 AM »
I never wrote a single DCL line in my life!
I learn VBA but not so fast as I wish. Until that I remain a lisper without DCL abilities.
Helix issue
« Reply #9 on: March 25, 2004, 10:44:23 AM »
A thousand pardons, a case of mistaken identity. :oops:
I was thinking of eduardo fernal but my memory
was playing tricks on me and I was too lazy to
look it up.
Sorry for the confusion.
johnjoe
Helix issue
« Reply #10 on: March 25, 2004, 02:06:58 PM »
Thanks Fuccaro,
Im new to autocad.  So its always a good idea to seek out some help. Tried on my pc and it worked a treat.  Must start programming some lisp.
TTYL :)
daron
Helix issue
« Reply #11 on: March 25, 2004, 02:44:09 PM »
Quote from: johnjoe
...Must start programming some lisp.
TTYL :)
I like this guy.
johnjoe
Helix issue
« Reply #12 on: March 25, 2004, 05:10:47 PM »
By the way Fuccaro, did you add that other option that you were discussing  in the previous topic? Remember the flatness issue of the extruded object.  I noticed the helical object seems to get flatter the wider the axis of rotation.
Fuccaro
Helix issue
« Reply #13 on: March 26, 2004, 01:26:36 AM »
Sorry Johnjoe!
Try to stretch the shape in the opposite direction before the spiral extrusioin. In that Forum you will find a routine for this.
