Author Topic: Custom dialog boxes examples?  (Read 18200 times)
MickD
Re: Custom dialog boxes examples?
« Reply #30 on: August 05, 2006, 06:42:49 PM »
A simple rule of thumb for doc locking - if you're coming from a dialog to the editor (after hitting your pick points button say) you need to lock the document because you're coming from a non document context to the doc context and you have to let autocad know.
If you are running a command from the command line (no windows), autocad automatically looks after the locking operation.
- John Carmack
- J.R.R. Tolkien
« Reply #31 on: August 06, 2006, 03:12:56 PM »
Thanks Kerry and Mick.  I think I understand now about locking.
Glenn R
« Reply #32 on: August 07, 2006, 08:05:17 AM »
Only if the dialog is modeless...well not quite true, but good enough for this discussion.
« Reply #33 on: August 07, 2006, 11:18:53 AM »
Thanks Glenn. I'm sure there area  lot of little things that will take writting code to understand, but this is good for now.
