Author Topic: Custom dialog boxes examples?  (Read 18199 times)
Re: Custom dialog boxes examples?
« Reply #15 on: August 02, 2006, 01:35:15 PM »
Tim:
 One good source is The AutoLisp Tutorials DCL-Dialog Control Language by Kenny Rammage @ www.afralisp.com
MGF
Thanks for the tip, but I know how to write dcl's, it this .Net (C#) that I don't know how to write.
FYI...
It's not "afralisp.com" anymore, it www.afralisp.net now.  :-)
And welcome to theswamp MGF.
« Reply #16 on: August 04, 2006, 03:16:43 PM »
So here is my first (working) attempt.  Do I use the LockDocument method apporiatly? and why do you need it?  I'm trying to understand what it does.
Thanks in advance. Now on to the code.  :lmao:
using System;
using System.Drawing;
using System.Windows.Forms;
using Autodesk.AutoCAD.Windows;
[assembly: CommandClass(typeof(Test.MyDialog))]
namespace Test
/// <summary>
/// Description of MyDialog.
/// </summary>
public class MyDialog : System.Windows.Forms.Form
private System.Windows.Forms.Button button1;
private System.Windows.Forms.RichTextBox richTextBox1;
private System.Windows.Forms.Button button2;
public MyDialog()
// The InitializeComponent() call is required for Windows Forms designer support.
InitializeComponent();
// TODO: Add constructor code after the InitializeComponent() call.
#region Windows Forms Designer generated code
/// <summary>
/// This method is required for Windows Forms designer support.
/// Do not change the method contents inside the source code editor. The Forms designer might
/// not be able to load this method if it was changed manually.
/// </summary>
private void InitializeComponent() {
this.button2 = new System.Windows.Forms.Button();
this.richTextBox1 = new System.Windows.Forms.RichTextBox();
this.button1 = new System.Windows.Forms.Button();
this.SuspendLayout();
// button2
this.button2.DialogResult = System.Windows.Forms.DialogResult.Cancel;
this.button2.Location = new System.Drawing.Point(104, 48);
this.button2.Name = "button2";
this.button2.TabIndex = 1;
this.button2.Text = "Cancel";
// richTextBox1
this.richTextBox1.Location = new System.Drawing.Point(16, 8);
this.richTextBox1.Name = "richTextBox1";
this.richTextBox1.Size = new System.Drawing.Size(168, 24);
this.richTextBox1.TabIndex = 2;
this.richTextBox1.Text = "Test just to see.";
// button1
this.button1.Location = new System.Drawing.Point(8, 48);
this.button1.Name = "button1";
this.button1.TabIndex = 0;
this.button1.Text = "Okay";
this.button1.Click += new System.EventHandler(this.Button1Click);
// MyDialog
this.AcceptButton = this.button1;
this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
this.CancelButton = this.button2;
this.ClientSize = new System.Drawing.Size(200, 77);
this.Controls.Add(this.richTextBox1);
this.Controls.Add(this.button2);
this.Controls.Add(this.button1);
this.Name = "MyDialog";
this.Text = "MyDialog";
this.ResumeLayout(false);
#endregion
void Button1Click(object sender, System.EventArgs e)
this.Close();
void Button2Click(object sender, System.EventArgs e)
this.Close();
[CommandMethod("TestDialog")]
public void ShowMyDialog()
DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();
MyDialog modalForm = new MyDialog();
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(modalForm);
docLock.Dispose();
« Reply #17 on: August 04, 2006, 03:36:35 PM »
I made my box even prettier.  I anchored all the elements, and I gave it a min and max size.  That is easy, and fun.
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #18 on: August 04, 2006, 04:50:42 PM »
Hey Tim,
Anytime that an object implements the IDisposable interface and it needs to be disposed, you should use the Try..Catch..Finally construct, or what I generally prefer, wrap everything in a Using(DocumentLock docLock = ...) {} block.
Bobby C. Jones
LE
« Reply #19 on: August 04, 2006, 04:59:08 PM »
Tim;
You are doing your homework my friend, I do not have the IDE installed at home, but will try your sample ... can you describe each of the steps (I asked this, because that's how I was able to understand what I know now about ObjectARX/C++) - that will help others better.
Cheers!
« Reply #20 on: August 04, 2006, 05:21:38 PM »
Hey Tim,
So if I read you correctly, you would have done something like (not tested)
using (DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();)
docLock.Dispose();
or
try
catch
finally
Nothing to dispose of, since I don't get and 'object' right?  Or am I way off base.  I know, I'm slow, but I'm trying.  Thanks for your help Bobby.  :roll: :wink:
Tim;
Cheers!
Sure Luis.  I dl'ed the artice here which helped a lot with understanding dialog boxes (forms), even though it is written for VB.net (I had to become a member, so that I could dl the pdf version of the file [its free]).  Once I had the look of the dialog I wanted, I then changed each objects properties.
First I changed the "Cancel" buttons properties:  I anchored it to both the right side, and the bottom of the form
Second I changed the "Okay" buttons properties: I also anchored it to the bottom and right side, but the right side of this button is anchored to the left side of the "Cancel" button (which happens by default), so they will always be the same space apart.
Third I change the "richTextBox" properties:  I anchored this on all sides, so the bottom is now anchored to the top of the buttons, so now that space is always the same.
The order of the anchoring is important.  I'm not sure if it's the order of the anchoring, or the order of making the items in the form.  But my worked with the ordering of the anchoring, so that is what I'm going to go with.  :-)
Then I saw that I could make the dialog as big or as small as I wanted.  This didn't work because you could make it so small that you couldn't see anything.  So on the form there is an area for minimum and maximum size.  You can set those to what you want.  A helpful hint I noticed is, there is also a property that tells you the current size of the dialog, so you can use that as a starting point.
Hope that is what you wanted Luis.   :-D
Bobby C. Jones
« Reply #21 on: August 04, 2006, 05:39:14 PM »
close.  There's no need for you to call .Dispose() when using Using.  When the using code block is exited, whether by hook or crook, .Dispose() will be called on the object that you're Using (not tested either :-)).
  using (DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument())
You can do the exact same with try..catch..finally like this
    try
    catch
    finally
      docLock.Dispose();
You're most welcome :-)
Bobby C. Jones
« Reply #22 on: August 04, 2006, 05:56:23 PM »
Thanks Bobby!!!  I found out some stuff (much what you just told me) about using the 'using' statement here on the MSDN website, after I posted, and before you did.  I like this idea so far......
Now I'm doing my reading on the try...catch...finally, which the MSDN site only calls try....finally.  Whoops.  Now I see a link to the try...catch...finally block on the MSDN.  I think I like both these methods.  Since I only code for myself, I think I would want to use the TCF way (right now), so that I can write the error message to the screen, and see what I did wrong, code or using wise.
A lot to learn.  Getting interresting though.
« Reply #23 on: August 04, 2006, 07:05:54 PM »
Tim,
speaking of the using statement,
 have a look at this use for using as well ..
using System ;
using System.Text;
using Autodesk.AutoCAD.Runtime ;
namespace blablabla
which allows this sort of thing
    Editor e = AcadApp.DocumentManager.MdiActiveDocument.Editor;
         using ( Transaction tr = e.Document.Database.TransactionManager.StartTransaction() )
« Last Edit: August 04, 2006, 07:07:48 PM by Kerry Brown »
« Reply #24 on: August 04, 2006, 07:25:02 PM »
Tim,
using System ;
using System.Text;
namespace blablabla
Thanks Kerry.  I used that before, but didn't think I was going to need it for the this dialog routine.  It took me so long just to get this thing working, maybe 5 tries, that I just forgot it.  I like that style also.
MickD
« Reply #25 on: August 04, 2006, 08:15:48 PM »
In regards to document locking, it's more of a recource management problem for the application. AutoCAD and windows have to work together to handle messages from devices such as the keyboard and by locking the document you're sort of saying 'stop everything, I'm doing something here' and AutoCAD will let you do your stuff without losing all your resources.
That's a simple explaination anyways :)
- John Carmack
- J.R.R. Tolkien
LE
« Reply #26 on: August 04, 2006, 08:54:21 PM »
Excuse my ignorance and confusion here;
Why the locking document is needed - ? -
Is this a wrap from the lockDocument method (ARX) - ? -
If it is, in all the code I have done in ARX, I only had needed to use in one solution (preview & inserting drawings) ie:
acDocManager->lockDocument(curDoc());
or
acDocManager->lockDocument(acDocManager->curDocument());
That I uploaded in the ARX forum here...
Hope that someone that knows could explain that... thanks!
« Reply #27 on: August 05, 2006, 04:43:50 AM »
.... Why the locking document is needed - ? -
Hi Luis ,
There is a real chance that the code behind the dialog will be modifying 'something' in the database. If this IS the case, then when the document is being accessed it must be locked first.
Personally, the overhead to lock the document irrespective doesn't seem wastefull .... perhaps not the most efficient, but safe.
« Last Edit: August 05, 2006, 04:46:42 AM by Kerry Brown »
« Reply #28 on: August 05, 2006, 02:57:14 PM »
Thanks Mick.  Simple is good right now, maybe later I will be able to understand the complex ones.
Hi Luis ,
Thanks Kerry.  Is it correct to assume then, that you use LockDocument with each of your apps?
« Reply #29 on: August 05, 2006, 05:36:44 PM »
... Is it correct to assume then, that you use LockDocument with each of your apps?
No.
This is my understanding, which may need confirmation, 'cause I'm not aware of all the ramifications :
If code executes in a document context, LockDocument is not required, 'cause AutoCAD locks the current document.
Otherwise, locking is required.
There is a distinction between the command session flags used with command registration which affect this.
I believe a context menu callback event runs code from outside the document, so if database changes are to be made, the 'user' is obliged to lock the document.
I believe the same applies when defining a COM interface which modifies the document or its objects.
I hope someone corrects me if my understanding is skewed.
