In this post
http://www.theswamp.org/index.php?topic=10923.msg137954#msg137954 I had a question about checking for a linetype. Well with CABs help I finally use this. I know it can be made more efficient that is the reason for posting. Please post some input.
code below
;;; Timothy G. Spangler
;;; ------------ Checks to see if a linetype is availible
(defun FIND_LINETYPE(LineType / Files)
(setq Files (GET_LINETYPE_FILES))
(vl-some '(lambda(x) (if (CHECK_LINETYPE (findfile x) LineType) x)) Files)
(defun CHECK_LINETYPE (LINFile Linetype / OpenFile LineNumber CurrentLine Result)
(setq OpenFile (open LINFile "r"))
(while (setq CurrentLine (read-line OpenFile))
(if (wcmatch CurrentLine "`**")
(setq LinetypeName (substr(car(TGS:Stringtolist CurrentLine ","))2))
(if (= (strcase Linetype) LinetypeName)
(setq Result T)
(close OpenFile)
Result
(defun GET_LINETYPE_FILES (/ AcadTemp Dir)
;;; gets a list of all directories in the support path
(setq AcadTemp (reverse(STRING_TO_LIST (getenv "ACAD")";")))
;;; creates a list of all files with the ".ext" in the support path
(foreach X AcadTemp
(setq Dir (vl-string-translate "\\" "/" X))
(if (vl-directory-files Dir "*.lin" 1)
(foreach Y (vl-directory-files Dir "*.lin" 1)
(setq LINFileList (cons Y LINFileList))
;;; return the list
LINFileList
load it type (find_linetype "linetype")
It will search all .lin files in your search path if it finds it it will return the file it is in.
I have also thought about making it more ambiguous. use it to search any file type for anything (just a thought)
Anyway here it is, help make it more efficient.
