Author Topic: Dim Tolerance  (Read 2952 times)
Martin-Y
Dim Tolerance
« on: March 24, 2004, 12:43:25 PM »
If you set your dimension tolerance to Symmetrical and precision to 0.00, upper value to 0.05 then draw a linear dim plus an angular dim the linear dim shows the +-0.05 but the angular only shows 0.
Any ideas, I cannot find a variable that controls this.
hendie
Dim Tolerance
« Reply #1 on: March 25, 2004, 03:51:30 AM »
look under the primary units tab... what do you have the precision set to in the angular dimensions section ?
would it be 0 by any chance ?
Martin-Y
Dim Tolerance
« Reply #2 on: March 25, 2004, 04:55:13 AM »
Spot on as usual. However there is discrepancy between linear and angular. As my user pointed out, if you don't want 2 decimal places on the dimension but you still want to show 0.05 as a deviation it still seems possible only on the linear, not the angular.
hendie
Dim Tolerance
« Reply #3 on: March 25, 2004, 05:05:18 AM »
but if you don't want to show 2 decimal places... how can you show a 0.05 tolerance ??
am I misunderstanding ?
Martin-Y
Dim Tolerance
« Reply #4 on: March 25, 2004, 05:47:23 AM »
Your right it does seem illogical to go for that accuracy on deviation without giving the accuracy on the primary unit and I don't understand why he needs this.
It is still strange that Acad seems to allow this control of Linear but not Angular.
Hopefully he's happy with previous reply.
