Author Topic: Set lisp to run every time a DWG is opened  (Read 8502 times)
hyposmurf
« on: August 01, 2006, 07:45:47 AM »
How do I set a lisp to run everytime I open a new drawing?I realise you can set one to run everytime AutoCAD opens, but I mean everytime a new drawing is opened.What Im intending to do is have my own default variables set every time a new drawing is opened, just fed up of the MIRRTEXT varaible etc not set to my requirements.
Do I have to redefine the open command? :-o
Andrea
Re: Set lisp to run every time a DWG is opened
« Reply #1 on: August 01, 2006, 08:47:53 AM »
drag&drop your lisp file to the suitecase...
in the appload dialog box..
OR
load your program from your ACAD.lsp file..
but be sure that in your profile to load ACAD.lsp on each dwg.
Keep smile...
CADmium
« Reply #2 on: August 01, 2006, 09:29:23 AM »
IMHO not in the acad.lsp !!!
for this use the load and run command in acaddoc.lsp -File. It will call with every new document. If you don't have a acaddoc.lsp , you can create on in a acad-support-directory
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
David Hall
  • Automatic Duh Generator
« Reply #3 on: August 01, 2006, 09:55:54 AM »
Also, do a test on the drawing name.  If its Drawing?? then run your command,  if its already got a name, dont run it.  I have some example code if you need it
CADaver
« Reply #4 on: August 01, 2006, 10:01:57 AM »
?  Oh? Why not?
CADaver
« Reply #5 on: August 01, 2006, 10:02:27 AM »
cool, can you post it here??
« Reply #6 on: August 01, 2006, 10:11:36 AM »
This is what I use:
(if (not (wcmatch (getvar 'DWGNAME) "Drawing*.dwg"))
LE
« Reply #7 on: August 01, 2006, 10:17:25 AM »
Why not DWGTITLED ?
nivuahc
« Reply #8 on: August 01, 2006, 10:24:26 AM »
Why not DWGTITLED ?
That's what I use. :)
« Reply #9 on: August 01, 2006, 10:35:12 AM »
Why not DWGTITLED ?
I'm not sure?  :-D
I like that much better...
(if (= (getvar 'dwgtitled) 1)
« Last Edit: August 01, 2006, 10:37:08 AM by ronjonp »
CADaver
« Reply #10 on: August 01, 2006, 10:48:01 AM »
I use the same as ronjonp's (getvar 'DWGNAME) phrase, I never really looked at dwgtitled until today.  Cool.   I'm still wondering what CmdrDuh uses, though.
Andrea
« Reply #11 on: August 01, 2006, 12:56:39 PM »
I use this on from ACAD.LSP located on network drive
(setq cprofile (strcase (getvar "cprofile")))
(if (vl-string-search "Section of profile name" cprofile)
(do this....))
(if (vl-string-search "Section of another one" cprofile)
(do that....))
and some othe loading utilities..
why ??
because to many department here loading to many diffrent programs and utilities that why.   :wink:
« Last Edit: August 01, 2006, 12:58:12 PM by Andrea »
Keep smile...
CADmium
« Reply #12 on: August 02, 2006, 02:30:51 AM »
acad.lsp ist the file for make something when acad starts
acaddoc.lsp ist the file for make something when new document starts
i think, both files are not only for fun
vladimirzm
« Reply #13 on: August 02, 2006, 03:05:31 AM »
from CUI you can load any lisp when new drawig starts: right clic on LISP Archives node > Load Lisp.
Crank
« Reply #14 on: August 02, 2006, 03:11:35 AM »
I agree with CADnium.
Another option is the .mnl file: That's is also loaded in every drawing.
