Author Topic: Seperating Xrefs from blocks  (Read 10287 times)
GDF
Re: Seperating Xrefs from blocks
« Reply #30 on: August 24, 2006, 05:03:13 PM »
I just caught this thread and tried your revised routine.
Works great, I can sure use this one. Thanks.
Gary
Cool! 8-)
Thanks for testing Gary.
Edit: Gary/all the way it's coded, it should work with drawings opened with ObjectDBX.  It will print to the current drawing opened.
So, I can use objectdbx to bind all xrefs within a directory, by using this function within an objectdbx routine?
Kool.
Gary
« Reply #31 on: August 24, 2006, 05:15:26 PM »
Yup.  You would need to make small changes (to make it work like it should with multiply drawings).
« Reply #32 on: August 25, 2006, 12:53:42 PM »
Aaron,
  This code works on your drawing.  I had some bad order in the way it worked.  I detached the xref, and then tried to get the name, and that won't work, so I had to get the name first.
Let me know it still causes problems.
(defun ReloadBindXrefs (Doc / XrefList LstLen TroubleList *error* tmpName)
(defun *error* (msg)
;(vl-bt)
(prompt (strcat "\n Error--> " msg))
(vlax-for Blk (vla-get-Blocks Doc)
 (if (= (vla-get-IsXref Blk) :vlax-true)
    (vl-catch-all-error-p
     (vl-catch-all-apply 'vla-Reload (list Blk))
      (setq tmpName (vla-get-name Blk))
       (vl-catch-all-apply 'vla-Detach (list Blk))
     (setq TroubleList (cons Blk TroubleList))
     (prompt (strcat "\n Detached xref: " tmpName))
     (vla-Bind Blk :vlax-true)
       (not (vl-position (vla-get-Name Blk) XrefList))
      (setq XrefList (cons Blk XrefList))
(setq LstLen (length XrefList))
(while
  (> LstLen 0)
  (> LstLen (setq LstLen (length XrefList)))
 (foreach Blk XrefList
   (or
    (= (vla-get-IsXref Blk) :vlax-false)
   (setq XrefList (vl-remove Blk XrefList))
(foreach Blk (append XrefList TroubleList)
 (prompt (strcat "\n Unable to bind xref: " (vla-get-Name Blk)))
Call with (for current drawing)
(ReloadBindXrefs (vla-get-ActiveDocument (vlax-get-Acad-Object)))
Hangman
« Reply #33 on: August 25, 2006, 05:53:23 PM »
Hey Tim,
This works superbly.  THANK YOU very much.  I appreciate your help.
btw, I was reading the One Up link from Se7en and found your comment about tidying up an eleven year stint.
I hope it's in your best interest.
And why would you put so much time into helping me when you have more pressing issues at hand ???  Now I owe you a double THANK YOU !!
Best of luck in your endeavors.  And if there's anything I can do for you, let me know, you have my email addr.
And so, ... now we need to work on the images.  :-D
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
« Reply #34 on: August 25, 2006, 06:44:18 PM »
Hey Tim,
You're welcome.  I seem to be drawn to questions about xrefs.  It's like I must answer.  :-D
This was directed toward Michael.  I haven't been coding that long.  :wink:
Thanks.
Did you see I started a thread about them.  I can't seem to figure that one out, and it looks like I'm not the only one.  I have started looking into coding with C# (.Net) and didn't see anything about images that would help, but it was a quick look.  This really bugs me that I/we can't figure it out.
Maverick®
« Reply #35 on: August 26, 2006, 01:09:41 PM »
Tim, Have you been learning reply ettique from Cadaver?   :-D
