Author Topic: (REQUEST)TimeStamp  (Read 5508 times)
(REQUEST)TimeStamp
« on: March 22, 2004, 04:14:48 PM »
Does anyone have a timestamp progy they use --or even used to use-- for acad.  I dont want answers like "use R-text" or anything, if you dont have one that's alright, ill just have to write one tonight. (I wanted to give a quick demo)
Just checking...
Later,
(REQUEST)TimeStamp
« Reply #1 on: March 22, 2004, 04:24:52 PM »
Uh .. use R-Text ....
ok, so you don't want that answer ...
What functionality do you want.. timestamp at open? at close? when the user specifies and picks a button?
What format?
hh:mm:ss.ms ?
mm/dd/yy hh:mm:ss.ms ?
I have something.. but not quite sure what you want...
(REQUEST)TimeStamp
« Reply #2 on: March 22, 2004, 04:35:05 PM »
Just a real simple timestamp progy that will update a text entry (or block) upon save or plot. (Would like it to be an "auotmatic" app but a manual program will do. ...Im not picky at all.)
thanx
(REQUEST)TimeStamp
« Reply #3 on: March 22, 2004, 04:46:18 PM »
Ok, let me look at my archives and I will see what I can find ....
CADaver
(REQUEST)TimeStamp
« Reply #4 on: March 22, 2004, 04:47:06 PM »
Quote from: Se7en
thanx
try HERE
(REQUEST)TimeStamp
« Reply #5 on: March 22, 2004, 05:23:02 PM »
here's some code that might help.
(defun theyear ()
  (substr (itoa (fix (getvar 'cdate))) 1 4)
  ;; example (setq y (theyear))
(defun themonth ()
  (substr (itoa (fix (getvar 'cdate))) 5 2)
  ;; example (setq m (themonth))
(defun theday ()
  (substr (itoa (fix (getvar 'cdate))) 7)
  ;; example (setq d (theday))
(defun thetime (/ ctime ampm stime)
  (setq ctime (rtos (rem (getvar 'cdate) 1) 2 6)
        ampm (if (<= (atof (substr ctime 3 2)) 12) "AM" "PM")
        stime (strcat
                (substr ctime 3 2)":"
                (substr ctime 5 2)":"
                (substr ctime 7 2)":"ampm
  ;; example (setq curtime (thetime))
  ;; "10:18:58:AM"
(REQUEST)TimeStamp
« Reply #6 on: March 22, 2004, 05:29:21 PM »
Thanx alot guys.
Ill tell ya all what happned when i get home.
(REQUEST)TimeStamp
« Reply #7 on: March 22, 2004, 06:51:34 PM »
Had this one.
Don't know where i got it though. :D
;;; FUNCTION
;;; time stamp, searches dwg for text/dtext that contains "Time Stamp:"
;;; if found, it updates the text to the current date and time. format
;;; looks like 'Time Stamp: 03/31/2003@13:22'.
;;; ARGUMENTS
;;; none
;;; USAGE
;;; add it to you acad.lsp to run every time you open the dwg, or a plot
;;; reactor to update it when plotting, or a button to update when you
;;; feel like it, or simply type in (mst-tstamp) to see it work
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2003 Mark S. Thomas
;;; mark.thomas@bigswamp.org
;;; VERSION
;;; 1.0    Mon Mar 31, 2003
(defun MST-TStamp (/ *doc* *mspace* *pspace* mst-date switch)
  (setq
    *doc* (vla-get-ActiveDocument (vlax-get-acad-object))
    *mspace* (vla-get-ModelSpace *doc*)
    *pspace* (vla-get-PaperSpace *doc*)
    ); setq
  (defun MST-date (/ tmp)
    (setq tmp (rtos (getvar 'cdate) 2 4))
    (strcat "Time Stamp: "
            (substr tmp 5 2) "/"
            (substr tmp 7 2) "/"
            (substr tmp 1 4) "@"
            (substr tmp 10 2) ":"
            (substr tmp 12 2)
    ); defun
  ; search modelspace first
  (vlax-for item *mspace*
              (= (vlax-get-property item 'ObjectName) "AcDbText")
                (wcmatch
                  (vlax-get-property item 'TextString)
                  "*Time Stamp:*"
                  (vlax-put-property item 'TextString (mst-date))
                  (setq switch 1)
                    (not (vlax-object-released-p item))
                    (vlax-release-object item)
                ) ; if
              ) ; if
  ; search paperspace if not found in modelspace
    (not switch)
    (vlax-for item *pspace*
                  (wcmatch
                    "*Time Stamp:*"
                    (setq switch 2)
                      ); if
                  ); if
    ); if
  ; release the overhead, just for the heck of!
  (mapcar 'vlax-release-object (list *doc* *mspace* *pspace*))
  (if (= switch nil) (princ "\nTime Stamp Not Found In DWG..."))
  ); defun
(REQUEST)TimeStamp
« Reply #8 on: March 22, 2004, 07:36:07 PM »
...perfect!
(REQUEST)TimeStamp
« Reply #9 on: March 22, 2004, 08:48:29 PM »
now why couldn't I find that........
(REQUEST)TimeStamp
« Reply #10 on: March 23, 2004, 12:20:26 AM »
You didn't look where it was ????
CADaver
(REQUEST)TimeStamp
« Reply #11 on: March 23, 2004, 07:51:51 AM »
(setq pldate (menucmd "m=$(edtime, $(getvar, date),dd-mon-yy hh:mmam/pm)"))
