Author Topic: How to do it in AutoLISP then in ObjectARX  (Read 3505 times)
LE
« on: July 25, 2006, 10:13:26 PM »
Just want to post some functions written originally  in AutoLisp and then translated into ObjectARX
Function: NDIV divides a vector in "n" numbers of parts.
In AutoLISP
(defun NDIV  (pt1 pt2 n)
  (mapcar '+ pt1 (mapcar '/ (mapcar '- pt2 pt1) (list n n n))))
In ObjectARX
static void PtNdiv(ads_point p1, ads_point p2, double ndiv, ads_point ptres)
ptres[0] = p1[0] + (p2[0] - p1[0]) / ndiv;
ptres[1] = p1[1] + (p2[1] - p1[1]) / ndiv;
ptres[2] = p1[2] + (p2[2] - p1[2]) / ndiv;
Function: CENCIR giving three points find the circle center.
In AutoLISP
(defun CENCIR  (p0 pm p1 / p)
  (inters (setq p (ndiv p0 pm 2))
  (polar p (+ (angle p0 pm) (/ pi 2)) 1)
  (setq p (ndiv p1 pm 2))
  (polar p (- (angle p1 pm) (/ pi 2)) 1)
  nil))
In ObjectARX
#define PI 3.141592653589793238462643383279502884197169399375105820974944592308
int CenCir(ads_point p0, ads_point pm, ads_point p1, ads_point ptres)
ads_point from1,to1,from2,to2,ptint;
int teston;
teston=0;
PtNdiv(p0,pm,2,from1);
acutPolar(from1, (acutAngle(p0,pm) + (PI / 2)), 1, to1);
PtNdiv(p1,pm,2,from2);
acutPolar(from2, (acutAngle(p1,pm) - (PI / 2)), 1, to2);
if (acdbInters(from1,to1,from2,to2,teston,ptres)==RTNORM)
ads_point_set(ptres,ptint);
return TRUE;
else
return FALSE;
Function: P1CLC passing a point, center, arclength & direction draw an arc.
In AutoLISP
(defun P1CLC  (p1 cen lc dir / r r1 delta delt1)
  (setq r     (distance cen p1)
r1    (sqrt (- (expt r 2) (expt (/ lc 2) 2)))
delta (* 2 (atan (/ lc (* 2 r1))))
delt1 (/ (* delta 180) pi))
  (if (minusp dir)
    (setq delt1 (* delt1 -1)))
  (vl-cmdf "._ARC" "_C" cen p1 "_A" delt1))
In ObjectARX
void CmdCall (struct resbuf *cmdlist)
if (cmdlist==NULL)
acdbFail("\nCouldn't create list buffer\n");
acutRelRb(cmdlist);
}else {
int status;
struct resbuf rb, rb1;
acedGetVar("CMDECHO", &rb);
rb1.restype = RTSHORT;
rb1.resval.rint = 0;
acedSetVar("CMDECHO", &rb1);
status=acedCmd(cmdlist);
acutRelRb(cmdlist);
if ((status==RTNORM)&&(rb.restype == RTSHORT))
acedSetVar("CMDECHO", &rb);
if ((status==RTCAN)&&(rb.restype==RTSHORT))
void p1clc(ads_point p1, ads_point cen, ads_real lc, short dir)
ads_real r,r1,delta,delt1;
r=acutDistance(cen,p1);
r1= sqrt((pow(r,2) - pow(lc/2,2)));
delta=(2 * atan((lc / (2*r1))));
delt1=((delta*180) / PI);
if (dir < 0) { //(dir==-1)
delt1=(delt1 * -1);
struct resbuf *cmdlist=NULL;
cmdlist=acutBuildList(
RTSTR, "_.ARC",
RTSTR, "_C",
RT3DPOINT, cen,
RT3DPOINT, p1,
RTSTR, "_A",
RTREAL, delt1,
0);
CmdCall(cmdlist);
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: How to do it in AutoLISP then in ObjectARX
« Reply #1 on: July 26, 2006, 04:03:23 AM »
My version:
  AcGeVector3d v1(asPnt3d(p0)-asPnt3d(pm)),
               v2(asPnt3d(p1)-asPnt3d(pm));
  if (v1.isParallelTo(v2)) return FALSE;
  AcGeCircArc3d crc(asPnt3d(p0),asPnt3d(pm),asPnt3d(p1));
  ads_point_set(ptres,asDblArray(crc.center()));
  return TRUE;
« Reply #2 on: July 26, 2006, 04:36:58 AM »
My version:
int CenCir( ..
... return FALSE;
..   return TRUE;
I keep forgetting that C++ TRUE and FALSE are ints, not boolean .. :lol:
--> Donate to theSwamp<--
LE
« Reply #3 on: July 26, 2006, 12:27:12 PM »
My version:
int CenCir( ..
... return FALSE;
..   return TRUE;
Yes they are part of the #define's like:
#define TRUE 1
#define FALSE 0
In example more definitions can be:
#define BAD 0
#define TRUE 1
#define FALSE 0
#define CLOCKWISE 1
#define COUNTERCLOCKWISE-1
#define 2PI 6.28318530717958647692528676655901
#define MIN(x,y) (x < y ? x : y)
#define MAX(x,y) (x > y ? x : y)
//#define ENGLISH 1
#define EPS 1e-05
#define PI90 1.5707963267948966192313216916398
#define PI270 4.7123889803846898576939650749193
#define PI360 6.283185307179586476925286766559
#define Absolute(a)  ((a) >= 0.0 ? (a) : -(a))
#define EQN(x,y) (Absolute((x) - (y)) <= EPS)
#define EQNPLUS(x, y)(EQN(x,y) || x > y)
#define EQNMINUS(x,y)(EQN(x,y) || x < y)
// For checking near equal floating-point values
#define EPSILON 0.001 //0.0000000001 //0.0001   // tolerance.
#define DOUBLE_EQ(x,v) (((v - EPSILON) < x) && (x <( v + EPSILON)))
