trying it right now....
its loading....
and 3 2 1
DesktopProfile\detail.scr"
Command: -STYLE
Enter name of text style or [?] <L175>: L175
Existing style. Full font name = Arial
Specify full font name or font filename (TTF or SHX) <ARIAL.TTF>: ARIAL.TTF
Specify height of text <0.2000>: .2
Specify width factor <1.0000>:
Specify obliquing angle <0d0'0">:
Display text backwards? [Yes/No] <N>:
Display text upside-down? [Yes/No] <N>:
"L175" is now the current text style.
Command: chtXT
Searching BLOCKS for Text..........
Searching ENTITIES for Text
CHBTX Cancelled.
Thanks for Using CHTXT!
Command:
CHTXT
CHBTX Cancelled.
Command:
CHTXT
CHBTX Cancelled.
Command: SPELL
Select objects: ALL
33 found
Select objects:
Command: insert
Enter block name or [?]: watermark
Units: Feet Conversion: 12.0000
Specify insertion point or
[Basepoint/Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: 0,0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 1
Enter Y scale factor <use X scale factor>:
Specify rotation angle <0d0'0">: 0
Command:
INSERT Enter block name or [?] <watermark>:
[Basepoint/Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: -plot
Point or option keyword required.
[Basepoint/Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: *Cancel*
