Author Topic: Pulldown menu icons  (Read 5973 times)
Dave R
Re: Pulldown menu icons
« Reply #15 on: March 27, 2009, 08:17:25 AM »
Kerry, what are you doing in the VBA forum? Shame on you.  :lmao:
Spike Wilbury
« Reply #16 on: March 27, 2009, 11:21:50 AM »
Thanks Luis
They've obviously forgotten that a lot of us use Menuload of partial menus from MNU files
... do not have a straightforward method ...
I wonder if they have ANY method ??
Kerry,
What I have done is to once my MNU it is loaded (I have done it in ARX the making of my MNU, too) - it will generate a CUI and do a modification depending where I want to have an icon, I just look for:
        <Macro type="Any">
          <Revision MajorVersion="16" MinorVersion="2" UserVersion="1" />
          <ModifiedRev MajorVersion="17" MinorVersion="0" UserVersion="1" />
          <Name xlate="true" UID="XLS_0002">Unload Menu</Name>
          <Command>^C^CUNLOADSUPP </Command>
          <SmallImage Name="unloader.bmp" />
          <LargeImage Name="unloader.bmp" />
        </Macro>
Then, I loaded again.... I know but so far that's what it works for me
« Reply #17 on: March 27, 2009, 09:44:47 PM »
Thanks for the thought Luis.
I found the source of your ADN reference in the discussion groups ... wasn't much help was it ;)
I may need to write my own updater for the .CUI, .CUIx files ... UGH !
--> Donate to theSwamp<--
« Reply #18 on: March 27, 2009, 09:46:17 PM »
H Dave,
One does what one must.  :-P    :-)
