Author Topic: vbnet how to load userdefined autoCAD dll  (Read 5902 times)
www1970
« on: July 21, 2006, 04:51:13 AM »
I used VB NET develop objectArx , then I want to put some common functions in a "MYLIB" dll, load then in other programl, but I tryed N times , failed ! I don't know if to set some things in VBNET, or set the DLL functions to "shared"。please give me a detailed step. thanks before!
english not well :-o
www1970
Re: vbnet how to load userdefined autoCAD dll
« Reply #1 on: July 21, 2006, 05:26:34 AM »
reinforce more
for example:
a object is:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Public Class hw
    <Autodesk.AutoCAD.Runtime.CommandMethod("Hello")> _
    Public Shared Sub HelloWorld()
        Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Hello World")
    End Sub
End Class
compile to "HW.dll"
the second example :
new a class1 object
first “Add Reference” "HW.dll"
Imports HW
Public Class Class1
    <Autodesk.AutoCAD.Runtime.CommandMethod("Example")> _
    Public Shared Sub Example()
        Dim exp as HW
       exp.Hello
    End Sub
End Class
jonesy
  • SuperMod
« Reply #2 on: July 21, 2006, 05:44:09 AM »
hi www1970, welcome to theswamp.
Unfortunately I know nothing about programming. There are many very good programmers that visit the site on a daily basis, but they havent logged on just yet today. I'm sure someone will be along shortly to help you.
Kind regards
Tracey
« Reply #3 on: July 21, 2006, 05:59:10 AM »
Try exo.HelloWorld  .. which is the name of the method of the hw class.
Hello is the registered command to be used from the command AutoCAD line
Glenn R
« Reply #4 on: July 21, 2006, 07:04:16 AM »
I don't think that will work as you're trying to call a registered command from another registered command, for some reason...
MickD
« Reply #5 on: July 21, 2006, 08:14:13 AM »
You should still be able to call the method (HelloWorld in this case) all the same, the command method attribute is just the acad 'export' of the method for the command stack.
I don't know about vb but maybe a 'Set' is required for a new instance of exo??
Or-
if 'shared' is the same as static, you would need to call hw.HelloWorld, not HW which is what he is trying to create that doesn't exist, the class declaration is 'hw'
- John Carmack
- J.R.R. Tolkien
Bob Wahr
« Reply #6 on: July 21, 2006, 08:19:29 AM »
Triple Aussied...Nice.
Quadruple if you count Jonesy and subscribe to the belief that Brits are just Aussies who didn't get caught.
« Last Edit: July 21, 2006, 08:21:13 AM by Bob Wahr »
www1970
« Reply #7 on: July 21, 2006, 08:27:40 PM »
thanks for everyone
though my problem isnot solved,but I am inspired by everybody
www1970
« Reply #8 on: July 21, 2006, 08:46:17 PM »
Congratulate! solved
  Public Sub Example()
        Dim exp As HW = New HW
        exp.HelloWorld()
  End Sub
first:     exp.HelloWorld()
second:      New HW
not need define shared
« Reply #9 on: July 22, 2006, 01:11:36 AM »
DUH ! I forgot the parenthesis
exo.HelloWorld ( )
now thats a silly thing for an old lisper to do :lol:
www1970
« Reply #10 on: July 23, 2006, 08:17:12 PM »
Kerry Brown
not silly,thank you wery much!
