Author Topic: Good place to start learning  (Read 13096 times)
« on: July 19, 2006, 05:22:13 PM »
Here is an artical which looks like a good place to start learning C# coding for Autocad.  Goes over some basic drawing objects.
Hi all C# lovers,
Recently, I did a project for Govt. PSU which involved using AutoCAD with C# and I found it very interesting. I am very eager to share it with you.
This article shows how to use AutoCAD objects in a .NET application using C#.
Re: Good place to start learning
« Reply #1 on: July 19, 2006, 06:48:26 PM »
Does this mean you've decided to skip VBA and jump right into C#? :-)
« Reply #2 on: July 19, 2006, 06:53:48 PM »
Will see.  At work I don't have the required .net framework, and I don't think if the IT people will freak (they are cool here).  I will ask them and see if they care.  If so, then maybe. :wink:
Was figuring if I have to learn a new language, let it be powerful.
But this one makes it look kind of easy to start.  I will digest it all tonight.
LE
« Reply #3 on: July 19, 2006, 07:10:55 PM »
Tim;
Very good, that you will be moving to the dark side.... !!!!!!
(I know about those samples..... and I can tell, we have Masters on that HERE @theSwamp...  :-))
« Reply #4 on: July 19, 2006, 07:16:26 PM »
That is a good place to start in C# with AutoCAD especially if you're familiar with vba as all the examples are using COM. You will be familiar with the AutoCAD Object model and will only notice the different syntax required for C# which will help ease you into the language and be productive at the same time.
Using the managed arx wrappers is the way to go though but has a 'little' steeper learning curve.
Cheers,
Mick.
- John Carmack
- J.R.R. Tolkien
« Reply #5 on: July 19, 2006, 07:34:09 PM »
Tim;
I have been broken down, and I can't resist any longer.  Thanks Luis.  You know I will be asking for help, if I can install the needed stuff on my computer, which I think won't be a problem.
Cheers,
Mick.
I use the ActiveX controls through AutoLisp, so I have a little understand of the object model.  Do you/anyone have some basic examples of the arx wrappers?  If that is the way to go, how much harder will it be to learn?  I will search for that tonight also then.  Thanks.
« Reply #6 on: July 19, 2006, 08:45:47 PM »
http://www.theswamp.org/index.php?topic=8245.msg141017#msg141017
Some Samples provided by Jim Awe at AutoDesk <public issue> .  ... for 2006 ; he is working on 2007
« Reply #7 on: July 19, 2006, 09:27:21 PM »
Thanks Kerry.  I don't know what I can do with these at home, but I will see.
Bobby C. Jones
« Reply #8 on: July 20, 2006, 08:06:25 AM »
acad 2005 and 2006 install the 1.1 version of the framework, 2007 installs version 2.0.  You'll just need the .NET SDK and an IDE.  And technically the IDE is optional, but only if you're a masochist...
Bobby C. Jones
« Reply #9 on: July 20, 2006, 11:12:17 AM »
I thought I read somewhere that 2006 needed .net 2.0.  If you say I don't need 2.0, then all I need is a good FREE ide I guess.  I will see what I can find.  The article I read mentioned ShartDevelop as and ide to use, and I think Tim R. uses it also.
Where do you get the .Net SDK from?  I don't think I have run across that yet.
Thanks for the info Bobby.
« Last Edit: July 20, 2006, 11:13:23 AM by T.Willey »
TR
« Reply #10 on: July 20, 2006, 11:16:31 AM »
Anyone else think of "Along Came Polly" when they read that?
TR
« Reply #11 on: July 20, 2006, 11:31:33 AM »
I use SharpDevelop2 to run .NET 2.0 apps on AutoCAD 2005 and all is well. For SharpDevelop2 all you need is the .NET 2.0 runtime and you will be able to build and run 2.0 apps. If you want the .NET 2.0 documentation you will need the SDK available @ http://msdn.microsoft.com/netframework/downloads/updates/default.aspx
« Reply #12 on: July 20, 2006, 11:36:55 AM »
But if I don't want to install .NET 2.0, can I run SharpDevelop1.1 with the .NET framwork already installed on my computer, and use the SDK from here? (version 1.1)
Sorry for the nubish questions.  I'm running 2006 right now.
TR
« Reply #13 on: July 20, 2006, 11:39:24 AM »
Yes, you can do that. I recommend SD2 and .NET 2.0 though.
« Reply #14 on: July 20, 2006, 11:49:07 AM »
Thanks for the info Tim.  I will have to talk with my IT people then.  If they say it is ok, I will grab all the 2.0 stuff.
