Author Topic: Getting Xrecord Data (lesson 2)  (Read 4830 times)
« on: July 18, 2006, 01:24:20 PM »
Here is my code
Public Function GetXRecLisp() As AcadXRecord
Dim DictCol As AcadDictionaries
Dim MyDict As AcadDictionary
Dim XRec As AcadXRecord
Set DictCol = ThisDrawing.Dictionaries
On Error GoTo MyError
Set MyDict = DictCol.Item("LisptoVBA")
Set XRec = MyDict.Item("LisptoVBA")
Set GetXRecLisp = XRec
Exit Function
MyError:
    MsgBox "Error " & Err.Number & " ( " & Err.Description & " )"
End Function
Public Sub ShowXrecData(ByRef XRec As AcadXRecord)
Dim DataType As Integer
Dim Data As Variant
Dim Cnt As Integer
Set XRec = GetXRecLisp
XRec.GetXRecordData DataType, Data
For Cnt = 0 To UBound(Data)
    MsgBox Data(Cnt)
Next
End Sub
It seems like the first one works.  I tried it with two drawings, one with information, no error message prompt, one with no information, and got the error message.  My problem seems to be with the second code.  I'm trying to see if I can get the xrecord data without specifying a size, and just print it to a message box (command line would be fine also, for now).
Thanks in advance for any help.
Here is the lisp code used to add the xrecord, and dictionary (just incase).
(defun MySetXRec (Obj CodeList DataList / )
; Sets XRecordData. Dxf numbers between 1-369, except 5, 100, 105.
; See help for types and numbers to use.
(vla-SetXRecordData Obj
 (vlax-make-variant
  (vlax-safearray-fill
   (vlax-make-safearray
    vlax-vbInteger
    (cons 0 (1- (length CodeList)))
   CodeList
 (vlax-make-variant
    vlax-vbVariant
    (cons 0 (1- (length Datalist)))
   DataList
(MySetXrec
 (vla-AddXRecord
  (vla-Add
   (vla-get-Dictionaries
    (vla-get-ActiveDocument
     (vlax-get-Acad-Object)
   "LisptoVBA"
  "LisptoVBA"
 '(1 2)
 '("Testing" "Again")
Re: Getting Xrecord Data (lesson 2)
« Reply #1 on: July 18, 2006, 01:37:24 PM »
Untested <conceptual coding> but this is how I might code GetXRecLisp for flexibility --
Public Function GetXRecLisp(dictname As String, _
                            xrecname As String) _
                            As AcadXRecord
    Dim dict As AcadDictionary, _
        xrec As AcadXRecord
    On Error GoTo GetXRecLispError
    Set dict = ThisDrawing.Dictionaries.Item(dictname)
    Set xrec = dict.Item(xrecname)
    Set GetXRecLisp = xrec
    Exit Function
GetXRecLispError:
    Err.Clear
    Set GetXRecLisp = Nothing
    ''  caller tests for nothing result
End Function
Also note var / label naming (case / specificity etc).
Retentively yours,
« Reply #2 on: July 18, 2006, 01:46:43 PM »
Thanks Michael.  I will look at coding for more flexibility when I understand what I'm doing. :wink:  I like what you show though, as always.
What do you mean by
Should var's all be lower case?  Is this something that VBA likes?
« Reply #3 on: July 18, 2006, 01:51:39 PM »
I try / tend to code --
subs / functions: Capital case, then camel case, e.g. GetSomeValue
local variables: lower case, then camel case, e.g. dictMain
module / (class) member variables: prefixed with my, then same as subs, e.g. myCollection
widgets: prefixed with abbrev. of widget type, then as subs, e.g. frmMain.
Big topic, but sorry, gotta go to a lunch meeting, bye!
« Last Edit: July 18, 2006, 01:52:50 PM by MP »
« Reply #4 on: July 18, 2006, 02:08:08 PM »
Tim, I more or less follow what MP describes, but I think it is more a personal taste for what looks good to you.
As for your error, I think that it stems from Dim'ing the DataType as Integer in the GetXrecordData code......when you are GETTING something Acad returns a Variant, I know it's bassackwards from when you are Putting something, but it's what they decided to use. So try changing the Integer to Variant and I think it will work....... in fact here's what I used to test your  SetXrecord code:
Public Sub getXRec(ByRef XrecName As String)
Dim Xrec As AcadXRecord
Dim DataType As Variant
Dim Data As Variant
Dim I As Integer
Set MyDict = DictCol.Add("VBAtoLisp")
Set Xrec = MyDict.Item(XrecName)
Xrec.GetXRecordData DataType, Data
For I = 0 To UBound(Data)
    Debug.Print DataType(I) & " - " & Data(I)
Next
End Sub
« Reply #5 on: July 18, 2006, 02:24:01 PM »
Public Sub ShowXrecData(ByRef Xrec As AcadXRecord)
Dim Data As Variant
Dim Cnt As Integer
Set Xrec = GetXRecLisp
    Debug.Print Data(Cnt)
Next
End Sub
So I changed my code to look like above.  How can I get it to run so that I can test it?  I hit the play button, but it is asking for a macro name.  It seems it is because it is defined with an argument.  When I tried to put it into a sub with no arguments, and call it, it didn't work.
Thanks Jeff.
Bob Wahr
« Reply #6 on: July 18, 2006, 02:31:55 PM »
You need to pass an xrecord to this sub when you call it.  The other option would be to get rid of "ByRef Xrec As AcadXRecord" and Dim it in this sub.  If you go that way you will have to hunt through the dictionaries collection for the dictionary, then through the dictionary to find the xrecord.
« Reply #7 on: July 18, 2006, 02:33:35 PM »
What Bob said, but since you are getting it in the code you don't need to pass it as an argument. This is carrying on from your other thread's code:
Set MyDict = DictCol.Item("VBAtoLisp")
Set XRec = MyDict.Item("VBAtoLisp")
Exit Function
MyError:
End Function
Public Sub ShowXrecData()
Dim Data As Variant
Dim Cnt As Integer
    MsgBox Data(Cnt)
Next
End Sub
Sub test2()
ShowXrecData
End Sub
« Reply #8 on: July 18, 2006, 02:39:58 PM »
Thank you, all three.  It is working now.  Don't know what I put that there.  Must have tried to code to early in the work day morning.
« Reply #9 on: July 18, 2006, 04:05:27 PM »
You don't know how long it took me to finally find out how to do this.  Searching here, and the help files, but I have it now so it's all good.  Time for lunch.
