Author Topic: Pronouncing AutoLISP  (Read 9083 times)
zoltan
Re: Pronouncing AutoLISP
« Reply #15 on: July 29, 2006, 03:48:32 PM »
itoa - Integer to Atom
atof - Atom to Float
(i think)
jonesy
  • SuperMod
« Reply #16 on: July 31, 2006, 12:48:20 PM »
Great thread!
How about these?
atof  = a-t-o-f
getkword = get key word *yawn*
itoa = i-t-o-a
atof = hat off
getkword= get keyword
itoa = iota
(not that I do any programming... I just look at other peoples to see if I can figure out what does what)
Sdoman
« Reply #17 on: August 02, 2006, 08:04:32 AM »
(i think)
Another variant:
atof - Ascii to Floating, meaning convert string to real (floating point) number
Sdoman
« Reply #18 on: August 02, 2006, 08:11:46 AM »
atof = hat off
itoa = iota
Hat Off and Iota !  Thanks for the great humor Jonesy.
daron
« Reply #19 on: August 02, 2006, 08:58:18 AM »
Most of the previous one's I'd pronounce as others have stated, except:
princ = prink
« Reply #20 on: June 09, 2013, 02:36:20 PM »
Just stumbled across this great thread and thought I'd add my own pronunciations for some common AutoLISP functions:
cdr        = C-D-R
cadr       = C-A-D-R
cdar       = C-D-A-R
etc.
atof       = a-tov
atoi       = A-toy
itoa       = I-T-O-A
rtos       = R-toz
distof     = diss-tov
defun      = D-fun
setq       = set-Q
mapcar     = map-car
lambda     = lamb-dah
logior     = log-I-or
progn      = prog-n
princ      = prink
prin1      = prin-one
terpri     = terr-pree
textscr    = text-screen
strcase    = string-case
strcat     = string-cat
strlen     = string-length
substr     = sub-string
wcmatch    = W-C-match
tblnext    = table-next
tblobjname = table-object-name
tblsearch  = table-search
vlax-*     = V-lax (as in relax)
vl-*       = V-L
vlr-       = V-L-R
Print-see or Print-cee sounds good.  But I wonder what the "C" is for?  Where is Print-A and Print-B?
Since princ is designed to output data that is 'intended to look good for people', I would guess that the 'c' stands for 'console', i.e. print to console?
I guess the "N" in Progn confused me.  Group N lines?
I believe progn is the nth extension of the prog1 & prog2 functions found in Common LISP, to evaluate all n supplied expressions.
atof  = perhaps it would have been more appropriate for the authors of AutoLISP to have named this function stor for string-to-real
itoa = likewise, itos for integer-to-string would have been better imo.
As suggested by others, I understood atof to be a shortening of ASCII to float; similarly, itoa as integer to ASCII; however, for me, the inconsistency lies with the rtos & distof functions... by the same logic, I would have thought rtos (real to string) should be ftoa (float to ASCII), or that either distof (distance to float I presume?) or atof should instead be stor (string to real) as you've suggested.
Interesting thread  :-)
