Author Topic: Pronouncing AutoLISP  (Read 9081 times)
Sdoman
« on: July 17, 2006, 03:12:04 PM »
Just for geeky fun, how do you pronounce these AutoLisp function names when your reading code to yourself?
cdr
cadr
lambda
logior
lsh
princ
progn
terpri
Here's what I've been using:
Cdr: I use to pronounce C-D-R, but a book I've been reading says that the correct pronunciation is Coulder.
Cadr: C-A-D-R or should that be Car-Coulder?
Lambda:  Lamb-duh?
Logior: Log-gee-or?
Lsh: I have no idea.  Never used this anyway but is an interesting pronunciation challenge.
Princ: Prince or Prin-Cee?
Progn: Prog-N or Prog-Nin?
Terpri: Terminal-Print?
Re: Pronouncing AutoLISP
« Reply #1 on: July 17, 2006, 03:59:47 PM »
These are more the way I hear 'em in my head --
cdr    • could-rrr
cadr   • cad-rrr
lambda • bleet, bleet
logior • log-i-orrr
lsh    • left shift (true story)
princ  • prin-see
progn  • prog-n
terpri • ter-pri
CADaver
« Reply #2 on: July 17, 2006, 04:36:02 PM »
cdr    • C-D-R
cadr   • cad-rrr
lambda • lamb-duh
logior • log-Eyor (as in Pooh's donkey friend)
lsh    • lish (short I, rhymes with FISH)
princ  • prin-see ("See, there it prints".)
progn  • proggin' (rhymrs with noggin')
terpri • ter-print
« Last Edit: July 17, 2006, 04:37:18 PM by CADaver »
« Reply #3 on: July 17, 2006, 04:46:59 PM »
I have to admit first that I don't read whole words most of the time, so I make up words for things.
cdr = c-d-r
cadr = cad-r
lambda = lam-ba-da (like the dance)
logior = log-i-or
lsh = lish (I guess I would use)
princ = prince
progn = pro-nog
terpri = tear-pre
« Reply #4 on: July 17, 2006, 05:43:34 PM »
Same as MP except for the bleet, bleet .. lamb-dah
« Reply #5 on: July 17, 2006, 05:59:22 PM »
cdr = c-d-r
cadr = c-a-d-r
lambda = lamb-dah
logior = logical-or
lsh = logical-shift
princ = print-c
progn = pro-gen
terpri = tera-print
Sdoman
« Reply #6 on: July 18, 2006, 08:39:56 AM »
The functions CDR, CADR, CADDR, etc,  are the most awkward for me to read as a word.  That's why I just spell them out C-D-R, C-A-D-R.  I've never really been happy with that pronunciation however.  COULDER seems even more awkward to me.
It finally dawned on me that LAMBDA is from the Greek alphabet.
Logical shift make sense
Print-see or Print-cee sounds good.  But I wonder what the "C" is for?  Where is Print-A and Print-B?
I guess the "N" in Progn confused me.  Group N lines?
Since programming languages are read often yet rarely spoken, it is interesting to see what pronunciation people use while reading to themselves.  Thanks for replies.
« Reply #7 on: July 18, 2006, 09:25:24 AM »
Great thread!
How about these?
atof  = a-t-o-f
getkword = get key word *yawn*
itoa = i-t-o-a
and don't even try the vl- and vlax- functions! :-)
Quote from: MP
What the ... :-)
« Reply #8 on: July 18, 2006, 09:31:29 AM »
Quote from: MP
What the ... :-)
Sdoman
« Reply #9 on: July 18, 2006, 12:56:12 PM »
Great thread!
How about these?
atof  = a-t-o-f
itoa = i-t-o-a
atof  = perhaps it would have been more appropriate for the authors of AutoLISP to have named this function stor for string-to-real
itoa = likewise, itos for integer-to-string would have been better imo.
LE
« Reply #10 on: July 18, 2006, 01:06:58 PM »
Maybe, maybe, something like this (note: before you use the code below, make sure you are using a test drawing):  :-)
(pragma '((unprotect-assign stor)))
(setq stor atof)
(pragma '((protect-assign stor)))
(pragma '((unprotect-assign atof)))
(setq atof nil)
Then in the command line:
Command: (stor "3")
3.0
« Last Edit: July 18, 2006, 01:08:15 PM by LE »
Sdoman
« Reply #11 on: July 18, 2006, 03:02:30 PM »
That's cool LE.  I wasn't aware of the unprotect-assign function.  As an example it's interesting.  Of course, if someone was to redefine native lisp functions, they would break any old code that expects those functions to exist.
Pragma : Prag-Ma
Bob Wahr
« Reply #12 on: July 18, 2006, 03:07:19 PM »
Does list use s for something other than string like maybe Single?
LE
« Reply #13 on: July 18, 2006, 03:11:57 PM »
Pragma : Prag-Ma
I never had tried.... but I would guess that if you saved your routine inside of a protected namespace VLX, it might work....
Actually by simple calling:
(setq stor atof)
And kept the built-in functions alone....
« Last Edit: July 18, 2006, 03:19:27 PM by LE »
Sdoman
« Reply #14 on: July 18, 2006, 03:18:41 PM »
Does lisp use s for something other than string like maybe Single?
Bob: Not that I know of.  But then, I don't know it all :)
Good point Luis!
