Just stumbled across this great thread and thought I'd add my own pronunciations for some common AutoLISP functions:
cdr = C-D-R
cadr = C-A-D-R
cdar = C-D-A-R
etc.
atof = a-tov
atoi = A-toy
itoa = I-T-O-A
rtos = R-toz
distof = diss-tov
defun = D-fun
setq = set-Q
mapcar = map-car
lambda = lamb-dah
logior = log-I-or
progn = prog-n
princ = prink
prin1 = prin-one
terpri = terr-pree
textscr = text-screen
strcase = string-case
strcat = string-cat
strlen = string-length
substr = sub-string
wcmatch = W-C-match
tblnext = table-next
tblobjname = table-object-name
tblsearch = table-search
vlax-* = V-lax (as in relax)
vl-* = V-L
vlr- = V-L-RPrint-see or Print-cee sounds good. But I wonder what the "C" is for? Where is Print-A and Print-B?
Since
princ is designed to output data that is '
intended to look good for people', I would guess that the
'c' stands for 'console', i.e. print to console?
I guess the "N" in Progn confused me. Group N lines?
I believe
progn is the n
th extension of the
prog1 & prog2 functions found in Common LISP, to evaluate all
n supplied expressions.
atof = perhaps it would have been more appropriate for the authors of AutoLISP to have named this function stor for string-to-real
itoa = likewise, itos for integer-to-string would have been better imo.
As suggested by others, I understood
atof to be a shortening of ASCII to float; similarly,
itoa as integer to ASCII; however, for me, the inconsistency lies with the
rtos &
distof functions... by the same logic, I would have thought
rtos (real to string) should be
ftoa (float to ASCII), or that either
distof (distance to float I presume?) or
atof should instead be
stor (string to real) as you've suggested.
Interesting thread
