Author Topic: Eliminate the Paper Space Viewport from a list of all viewports on a layout  (Read 17398 times)
Don't get too excited I still haven't conquered the ON/Off thing, just separated out the Paper Space.
So if the vp is OFF it is included in the list, But I'm still looking.
Here I was thinking you had it all solved, and I was like "How??!!?" with little kid eyes, shaking with anticipation.
Here is one that works the way it should.  Most of the code is Alan's, I just added one line.
(defun foo (/ ss result vpl tab exc tmp)
  (defun get_exc (vpe / a b c)
    (and
    (setq a (cdr (assoc 330 (entget vpe))))
    (setq b (cdr (assoc 340 (entget a))))
    (setq c (cdr (assoc 331 (entget b))))
    c
  (if (setq ss (ssget "x" '((0 . "VIEWPORT"))))
      (setq vpl (mapcar 'cadr (ssnamex ss)))
      (setq vpl (mapcar '(lambda (x) (cons x (cdr (assoc 410 (entget x))))) vpl))
      (setq vpl (vl-remove-if '(lambda (x) (equal 131072 (logand 131072 (cdr (assoc 90 (entget (car x))))))) vpl)) ;; TMW
      (setq vpl (vl-sort vpl '(lambda (e1 e2) (< (cdr e1) (cdr e2)))))
      (foreach vp vpl
          ((null tab)
           (setq tab (cdr vp)
                 exc (get_exc (car vp))
          ((= tab (cdr vp))
           (if (not (= exc (car vp)))
             (setq tmp (cons (car vp) tmp))
          (t
           (setq exc    (get_exc (car vp))
                 result (if result
                          (cons (list tab tmp) result)
                          (list (list tab tmp))
                 tab    (cdr vp)
                 tmp    nil
      (if tmp
        (setq result (if result
  result
Here is the line of code I used to test it.
(mapcar '(lambda (x) (cons (car x) (length (cadr x)))) (foo))
Here is the help area that showe me what to try.
90
 Viewport status bit-coded flags:
1 (0x1) = Enables perspective mode
2 (0x2) = Enables front clipping
4 (0x4) = Enables back clipping
8 (0x8) = Enables UCS follow
16 (0x10) = Enables front clip not at eye
32 (0x20) = Enables UCS icon visibility
64 (0x40) = Enables UCS icon at origin
128 (0x80) = Enables fast zoom
256 (0x100) = Enables snap mode
512 (0x200) = Enables grid mode
1024 (0x400) = Enables isometric snap style
2048 (0x800) = Enables hide plot mode
4096 (0x1000) = kIsoPairTop. If set and kIsoPairRight is not set, then isopair top is enabled. If both kIsoPairTop and kIsoPairRight are set, then isopair left is enabled
8192 (0x2000) = kIsoPairRight. If set and kIsoPairTop is not set, then isopair right is enabled
16384 (0x4000) = Enables viewport zoom locking
32768 (0x8000) = Currently always enabled
65536 (0x10000) = Enables non-rectangular clipping
131072 (0x20000) = Turns the viewport off
Okay, time to go home now.
Lots of effort in this thread, kudos to all of you!
That was the last part of the puzzle.
Here is my version with flag.
 Only get vps that are ON if flag is true
(setq Vpon (foo t))
(defun foo (on? / ss result vpl tab exc tmp)
  ;;  Only get vps that are ON if flag is true
    (and
    c
      (foreach vp vpl
          ((null tab)
           (setq tab (cdr vp)
          ((= tab (cdr vp))
           (if (and (not (= exc (car vp)))
                    (or (not on?)
                        (zerop (logand 131072 (cdr (assoc 90 (entget (car vp))))))))
          (t
                 result (if result
                 tab    (cdr vp)
                 tmp    nil
      (if tmp
  result
<edit: removed some floatsam>
« Last Edit: July 13, 2006, 08:13:27 AM by CAB »
Sdoman
Bingo!  Excellent coding!  Thank you Cab and Tim for finding a solution.  Hi fives to everyone.  You guys really are awesome and exhibited some very highly skilled code.
I had been stuck with that programming problem for a long time before I posted for help.  Really do appreciate the effort you guys made.  And I hope I can help you out some time.
Regards,
Steve Doman
Well done guys, I really enjoy the spirit exhibited in of this place, and the skills !
I had fun.  I like ones that are challenging.  Whats next?
Good work Alan.
Thanks you Sir's, great effor all, twas fun indeed. :-)
Patrick_35
Hi
An old post   :-)
I found a another solution
(defun view(/ doc ent fen sau vie)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for lay (vla-get-layouts doc)
    (setq vie nil
  sau nil
    (vlax-for ent (vla-get-block lay)
      (if (and sau
      (eq (vla-get-objectname ent) "AcDbViewport")
(setq vie (cons ent vie))
(setq sau T)
    (and vie
      (setq fen (cons (list (vla-get-name lay) vie) fen))
  fen
return a list with name of layout and a list of viewport
Example
(("Layout1" (#<VLA-OBJECT IAcadPViewport2 15148314>))
 ("Layout2" (#<VLA-OBJECT IAcadPViewport2 15148c64>))
 ("Layout3" (#<VLA-OBJECT IAcadPViewport2 151721a4> #<VLA-OBJECT IAcadPViewport2 15174c64>))
Paulli_apa
  • Mosquito
When a drawing first opens by default only a single layout is automatically activated. So all vports in that layout will have vport ids greater than 1 with that layout itself with a vport id of 1 which is why the following code works only when there's a single layout in the drawing:
(setq ss (ssget "_X" '((0 . "VIEWPORT")(-4 . "!=")(69 . 1))))
The problem with this approach is when a dwg first opens & there is more than a single layout all other layouts pspace vport ids are still left as 0 just like the layout vport id itself. So the above code will also selection those layout itself thinking that it's a pspace vport when it's not.
A way to activate all the other layouts pspace vports is to cycle through making each layout current which is a hassle when a drawing has lots of layout tabs.
« Last Edit: January 12, 2024, 06:04:24 PM by Paulli_apa »
