Author Topic: ARCHTICK problem  (Read 5784 times)
Matersammichman
ARCHTICK problem
« on: July 11, 2006, 03:31:40 PM »
When I use the following to set my1/16" = 1'-0"  dimensioning parameters, I cannot get the dimension ticks to display as an Archtick, it always displays Oblique. I've tried this as many ways as I can think of.
What am I missing???
Private Sub optarrowsixteenth_Click()
Dim TextStyle0 As AcadTextStyle
Dim newDimStyle As AcadDimStyle
Dim currDimStyle As AcadDimStyle
Set TextStyle0 = ThisDrawing.TextStyles.Add("DIMTXT")
TextStyle0.fontFile = "simplex.shx"
TextStyle0.Height = 0
ThisDrawing.SendCommand "_TEXTSTYLE" & vbCr & "DIMTXT" & vbCr
ThisDrawing.SendCommand "_dimcen" & vbCr & 3 / 32 & vbCr
Dim varData As Variant
Dim DataType As Integer
sysVarName = "DIMSCALE"
varData = ThisDrawing.GetVariable(sysVarName)
Set newDimStyle = ThisDrawing.DimStyles.Add("My_Arch")
ThisDrawing.SendCommand "_graphscr" & vbCr
ThisDrawing.ActiveDimStyle = newDimStyle
ThisDrawing.SendCommand "DIMADEC" & vbCr & 2 & vbCr
ThisDrawing.SendCommand "DIMALT" & vbCr & "Off" & vbCr
ThisDrawing.SendCommand "DIMALTD" & vbCr & 2 & vbCr
ThisDrawing.SendCommand "DIMALTF" & vbCr & 25.4 & vbCr
ThisDrawing.SendCommand "DIMALTRND" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMALTTD" & vbCr & 2 & vbCr
ThisDrawing.SendCommand "DIMALTTZ" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMALTU" & vbCr & 2 & vbCr
ThisDrawing.SendCommand "DIMALTZ" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMAPOST" & vbCr & "" & vbCr
ThisDrawing.SendCommand "DIMASSOC" & vbCr & 1 & vbCr
ThisDrawing.SendCommand "DIMASZ" & vbCr & 1 / 8 & vbCr
ThisDrawing.SendCommand "DIMATFIT" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMAUNIT" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMAZIN" & vbCr & 2 & vbCr
ThisDrawing.SendCommand "DIMBLK" & vbCr & "_ArchTick" & vbCr
ThisDrawing.SendCommand "DIMBLK1" & vbCr & "_ArchTick" & vbCr
ThisDrawing.SendCommand "DIMBLK2" & vbCr & "_ArchTick" & vbCr
ThisDrawing.SendCommand "DIMCEN" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMCLRD" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMCLRE" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMCLRT" & vbCr & 256 & vbCr
ThisDrawing.SendCommand "DIMDEC" & vbCr & 3 & vbCr
ThisDrawing.SendCommand "DIMDLE" & vbCr & 1 / 16 & vbCr
ThisDrawing.SendCommand "DIMDLI" & vbCr & 1 / 16 & vbCr
ThisDrawing.SendCommand "DIMDSEP" & vbCr & "." & vbCr
ThisDrawing.SendCommand "DIMEXE" & vbCr & 1 / 16 & vbCr
ThisDrawing.SendCommand "DIMEXO" & vbCr & 1 / 16 & vbCr
ThisDrawing.SendCommand "DIMFIT" & vbCr & 5 & vbCr
ThisDrawing.SendCommand "DIMFRAC" & vbCr & 2 & vbCr
ThisDrawing.SendCommand "DIMGAP" & vbCr & 1 / 64 & vbCr
ThisDrawing.SendCommand "DIMJUST" & vbCr & "0" & vbCr
ThisDrawing.SendCommand "DIMLDRBLK" & vbCr & "" & vbCr
ThisDrawing.SendCommand "DIMLFAC" & vbCr & 1 & vbCr
ThisDrawing.SendCommand "DIMLIM" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMLUNIT" & vbCr & 4 & vbCr
ThisDrawing.SendCommand "DIMLWD" & vbCr & -1 & vbCr
ThisDrawing.SendCommand "DIMLWE" & vbCr & -1 & vbCr
ThisDrawing.SendCommand "DIMPOST" & vbCr & "" & vbCr
ThisDrawing.SendCommand "DIMRND" & vbCr & "1/16" & vbCr
ThisDrawing.SendCommand "DIMSAH" & vbCr & "On" & vbCr
ThisDrawing.SendCommand "_dimscale" & vbCr & "192" & vbCr
ThisDrawing.SendCommand "DIMSD1" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMSD2" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMSE1" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMSE2" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMSHO" & vbCr & "ON" & vbCr
ThisDrawing.SendCommand "DIMSOXD" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMTAD" & vbCr & 1 & vbCr
ThisDrawing.SendCommand "DIMTDEC" & vbCr & 3 & vbCr
ThisDrawing.SendCommand "DIMTFAC" & vbCr & 1 & vbCr
ThisDrawing.SendCommand "DIMTIH" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMTIX" & vbCr & "ON" & vbCr
ThisDrawing.SendCommand "DIMTM" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMTMOVE" & vbCr & 1 & vbCr
ThisDrawing.SendCommand "DIMTOFL" & vbCr & "ON" & vbCr
ThisDrawing.SendCommand "DIMTOH" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMTOL" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMTOLJ" & vbCr & 1 & vbCr
ThisDrawing.SendCommand "DIMTP" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMTSZ" & vbCr & 1 / 32 & vbCr
ThisDrawing.SendCommand "DIMTVP" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMTXSTY" & vbCr & "DIMTXT" & vbCr
ThisDrawing.SendCommand "DIMTXT" & vbCr & 3 / 32 & vbCr
ThisDrawing.SendCommand "DIMTZIN" & vbCr & 0 & vbCr
ThisDrawing.SendCommand "DIMUNIT" & vbCr & 6 & vbCr
ThisDrawing.SendCommand "DIMUPT" & vbCr & "OFF" & vbCr
ThisDrawing.SendCommand "DIMZIN" & vbCr & 3 & vbCr
ThisDrawing.SendCommand "_TEXTSIZE" & vbCr & 18 & vbCr
ThisDrawing.SetVariable "DIMBLK", "_ArchTick"
Bryco
Re: ARCHTICK problem
« Reply #1 on: July 11, 2006, 03:45:53 PM »
Matersammichman  you set the setvars (no sendcommand needed) first
then use copyfrom to set the dimstyle, I do all mine at once so this is part of a few subs.
The setvars have already been set for the leaderdimstyle elsewhwere
Private Sub childDimset(sDimStyle As String)
    Dim AngulardimStyle As AcadDimStyle
    Dim DiameterdimStyle As AcadDimStyle
    Dim RadialdimStyle As AcadDimStyle
    Dim LeaderdimStyle As AcadDimStyle
    Dim LineardimStyle As AcadDimStyle
    Dim activeDoc As AcadDocument
    With ThisDrawing
        Set activeDoc = .Application.ActiveDocument
        Set LineardimStyle = .DimStyles.Add(sDimStyle & "$0")
        LineardimStyle.CopyFrom activeDoc
        .SetVariable "DIMATFIT", 3
        .SetVariable "DIMBLK1", "."
        .SetVariable "DIMBLK2", "."
        .SetVariable "DIMCEN", 0
        .SetVariable "DIMDLE", 0
        .SetVariable "DIMDLI", 0.0625
        .SetVariable "DIMEXE", 0.125
        .SetVariable "DIMSAH", 0
        .SetVariable "DIMTAD", 0
        .SetVariable "DIMTIH", 1
        .SetVariable "DIMTMOVE", 2
        .SetVariable "DIMTOFL", 0
        .SetVariable "DIMTOH", 1
        .SetVariable "DIMUPT", 1
        Set AngulardimStyle = .DimStyles.Add(sDimStyle & "$2")
        AngulardimStyle.CopyFrom activeDoc
        .SetVariable "DIMADEC", 1
        .SetVariable "DIMATFIT", 0
        .SetVariable "DIMCEN", 0.09125
        .SetVariable "DIMTAD", 1
        .SetVariable "DIMTIH", 0
        .SetVariable "DIMTMOVE", 0
        .SetVariable "DIMTOFL", 1
        .SetVariable "DIMTOH", 0
        Set DiameterdimStyle = .DimStyles.Add(sDimStyle & "$3")
        DiameterdimStyle.CopyFrom activeDoc
        Set RadialdimStyle = .DimStyles.Add(sDimStyle & "$4")
        RadialdimStyle.CopyFrom activeDoc
        '"$6" is ordinate
        Set LeaderdimStyle = .DimStyles.Add(sDimStyle & "$7")
        LeaderdimStyle.CopyFrom activeDoc
        'reset for next dimstyle
        .SetVariable "DIMBLK1", "ArchTick"
        .SetVariable "DIMBLK2", "ArchTick"
        .SetVariable "DIMCEN", 0.09375
        .SetVariable "DIMDLE", 0.0625
        .SetVariable "DIMDLI", 0.5625
        .SetVariable "DIMEXE", 0.0625
        .SetVariable "DIMSAH", 1
        .SetVariable "DIMUPT", 0
    End With
Bob Wahr
« Reply #2 on: July 11, 2006, 03:48:07 PM »
First off, I would use SetVariable instead of SendCommand to set the variables.  I made these changes in notepad for a find and replace so it might need some more cleanup but give this a shot
ThisDrawing.SetVariable "TEXTSTYLE", "DIMTXT"
ThisDrawing.SetVariable "dimcen", 3 / 32
ThisDrawing.SetVariable "DIMADEC", 2
ThisDrawing.SetVariable "DIMALT", "Off"
ThisDrawing.SetVariable "DIMALTD", 2
ThisDrawing.SetVariable "DIMALTF", 25.4
ThisDrawing.SetVariable "DIMALTRND", 0
ThisDrawing.SetVariable "DIMALTTD", 2
ThisDrawing.SetVariable "DIMALTTZ", 0
ThisDrawing.SetVariable "DIMALTU", 2
ThisDrawing.SetVariable "DIMALTZ", 0
ThisDrawing.SetVariable "DIMAPOST", ""
ThisDrawing.SetVariable "DIMASSOC", 1
ThisDrawing.SetVariable "DIMASZ", 1 / 8
ThisDrawing.SetVariable "DIMATFIT", 0
ThisDrawing.SetVariable "DIMAUNIT", 0
ThisDrawing.SetVariable "DIMAZIN", 2
ThisDrawing.SetVariable "DIMBLK1", "_ArchTick"
ThisDrawing.SetVariable "DIMBLK2", "_ArchTick"
ThisDrawing.SetVariable "DIMCEN", 0
ThisDrawing.SetVariable "DIMCLRD", 0
ThisDrawing.SetVariable "DIMCLRE", 0
ThisDrawing.SetVariable "DIMCLRT", 256
ThisDrawing.SetVariable "DIMDEC", 3
ThisDrawing.SetVariable "DIMDLE", 1 / 16
ThisDrawing.SetVariable "DIMDLI", 1 / 16
ThisDrawing.SetVariable "DIMDSEP", "."
ThisDrawing.SetVariable "DIMEXE", 1 / 16
ThisDrawing.SetVariable "DIMEXO", 1 / 16
ThisDrawing.SetVariable "DIMFIT", 5
ThisDrawing.SetVariable "DIMFRAC", 2
ThisDrawing.SetVariable "DIMGAP", 1 / 64
ThisDrawing.SetVariable "DIMJUST", "0"
ThisDrawing.SetVariable "DIMLDRBLK", ""
ThisDrawing.SetVariable "DIMLFAC", 1
ThisDrawing.SetVariable "DIMLIM", "OFF"
ThisDrawing.SetVariable "DIMLUNIT", 4
ThisDrawing.SetVariable "DIMLWD", -1
ThisDrawing.SetVariable "DIMLWE", -1
ThisDrawing.SetVariable "DIMPOST", ""
ThisDrawing.SetVariable "DIMRND", "1/16"
ThisDrawing.SetVariable "DIMSAH", "On"
ThisDrawing.SetVariable "_dimscale", "192"
ThisDrawing.SetVariable "DIMSD1", "OFF"
ThisDrawing.SetVariable "DIMSD2", "OFF"
ThisDrawing.SetVariable "DIMSE1", "OFF"
ThisDrawing.SetVariable "DIMSE2", "OFF"
ThisDrawing.SetVariable "DIMSHO", "ON"
ThisDrawing.SetVariable "DIMSOXD", "OFF"
ThisDrawing.SetVariable "DIMTAD", 1
ThisDrawing.SetVariable "DIMTDEC", 3
ThisDrawing.SetVariable "DIMTFAC", 1
ThisDrawing.SetVariable "DIMTIH", "OFF"
ThisDrawing.SetVariable "DIMTIX", "ON"
ThisDrawing.SetVariable "DIMTM", 0
ThisDrawing.SetVariable "DIMTMOVE", 1
ThisDrawing.SetVariable "DIMTOFL", "ON"
ThisDrawing.SetVariable "DIMTOH", "OFF"
ThisDrawing.SetVariable "DIMTOL", "OFF"
ThisDrawing.SetVariable "DIMTOLJ", 1
ThisDrawing.SetVariable "DIMTP", 0
ThisDrawing.SetVariable "DIMTSZ", 0.09375
ThisDrawing.SetVariable "DIMTVP", 0
ThisDrawing.SetVariable "DIMTXSTY", "DIMTXT"
ThisDrawing.SetVariable "DIMTXT", 0.09375
ThisDrawing.SetVariable "DIMTZIN", 0
ThisDrawing.SetVariable "DIMUNIT", 6
ThisDrawing.SetVariable "DIMUPT", "OFF"
ThisDrawing.SetVariable "DIMZIN", 3
ThisDrawing.SetVariable "TEXTSIZE", 18
ThisDrawing.SetVariable "DIMBLK", "ArchTick"
newDimStyle.CopyFrom ThisDrawing
Bryco beat and topped me but Imma post anyway
mohnston
  • CAD Programmer
« Reply #3 on: July 11, 2006, 08:24:25 PM »
Don't forget each style will have children which may or may not be affected by a change to the parent.
Another option for maintaining and setting dim variables is
Public Function FixDims(aDoc As AcadDocument) As Boolean
   On Error GoTo Err_Handler
   Dim aDStyle As AcadDimStyle
   Dim strDSName As String
   Dim intFldCount As Integer
   Dim fld As ADODB.Field
   Dim db As ADODB.Connection
   Dim rs As ADODB.Recordset
   Dim strSQL As String
   Set db = New ADODB.Connection
   db.Open ENG_SYS_DB
   Set rs = New ADODB.Recordset
   strSQL = "SELECT * " & _
               "FROM dimvars"
   rs.Open strSQL, db, adOpenForwardOnly
   With rs
      While .EOF = False And .BOF = False
         Set aDStyle = aDoc.DimStyles.Add(.Fields("style_name").Value)
         For Each fld In rs.Fields
            If UCase(Left(fld.Name, 3)) = "DIM" Then
               aDoc.SetVariable fld.Name, .Fields(fld.Name).Value
            End If
         Next
         aDStyle.CopyFrom aDoc
         .MoveNext
      Wend
   End With
   Set aDStyle = ThisDrawing.DimStyles("MyStandardDimStyle")
   aDoc.ActiveDimStyle = aDStyle
   aDoc.Save
   FixDims = True
Exit_Here:
   Exit Function
Err_Handler:
   Select Case Err.Number
      Case -2145320861 ' error saving file
         aDoc.Close False
         Set aDoc = Nothing
         FixDims = False
         Resume Exit_Here
      Case Else
         FixDims = False
         InputBox "Error " & Err.Description, "Fix Dims", Err.Number
         Resume Exit_Here
   End Select
End Function
The table looks like . . .
  style_name varchar(255) NOT NULL,
  style_description varchar(255),
  dimasz float8,
  dimblk varchar(255),
  dimblk1 varchar(255),
  dimblk2 varchar(255),
  dimcen float8,
  dimclrt float8,
  dimclrd float8,
  dimdle float8,
  dimexe float8,
  dimfit float8,
  dimgap float8,
  dimjust float8,
  dimlfac float8,
  dimpost varchar(255),
  dimtad float8,
  dimtfac float8,
  dimtih float8,
  dimtofl float8,
  dimtoh float8,
  dimtolj float8,
  dimtsz float8,
  dimtvp float8,
  dimtxt float8,
  dimsd1 int2 DEFAULT 0,
  dimsd2 int2 DEFAULT 0,
  dimse1 int2 DEFAULT 0,
  dimse2 int2 DEFAULT 0,
  dimsoxd int2 DEFAULT 0,
  dimldrblk varchar(64),
  dimatfit int2,
  dimtmove int2,
  dimdec int2 DEFAULT 3
This way you can have many dim styles and tweak their settings without reopening or redistributing your code.
CAD Programming Solutions
Matersammichman
« Reply #4 on: July 12, 2006, 12:08:49 PM »
So...I guess any "quick fix" with the vba equivalent of "Dimoverride" for the current dimstyle is just a pipe dream?? :lmao:
yujebey
« Reply #5 on: September 04, 2014, 06:51:24 AM »
it happened to me and i fixed with adding this code;
ThisDrawing.SetVariable "DIMSAH", 1
its allow to show what you assign to DIMBLK, DIMBLK1, DIMBLK2
