Author Topic: Plot & Dim Scales  (Read 1091 times)
M-dub
Plot & Dim Scales
« on: July 11, 2006, 09:48:56 AM »
Stupid question:
What is the relationship between the Plot and Dim scales?
David Hall
  • Automatic Duh Generator
Re: Plot & Dim Scales
« Reply #1 on: July 11, 2006, 09:51:52 AM »
could be the same, or very different.  Depends on how you plot.  Dimscale is a multiplier that gets applied to all of the relevent dim vars to "scale" up the graphics so when you plot, they are scaled back down to the correct size
David Hall
« Reply #2 on: July 11, 2006, 09:53:55 AM »
But the bigger issue is how do you plot?  If from paper space, you are probable plotting 1:1 which is probably not your dimscale.  Thats where viewport scaling comes into play.  Typically, your viewport scale is the same as your dimscale (inverse porportional).  Does that make any sense?
M-dub
« Reply #3 on: July 11, 2006, 09:54:33 AM »
Ok, that's what I thought.
Time to get back on the phone with this surveyor...
:roll:
Thanks, Duh :)
David Hall
« Reply #4 on: July 11, 2006, 09:55:29 AM »
Beware, he may be using 1 inch equals XX feet, and you might be expecting 1 inch = xx INCHES.  you have a factor of 12 that might be giving you fits
