Author Topic: Pulling information from a Field  (Read 14594 times)
Re: Pulling information from a Field
« Reply #15 on: July 13, 2006, 12:13:54 PM »
I have steel toed construction boots.  :lmao:
And appreciate all the help I can get. 8-)
Krushert
  • FREE BEER Tomorrow!!
« Reply #16 on: July 13, 2006, 12:27:48 PM »
I need all the help I can get too.  But when you say it Cab, one could think that you you need a help in teaching me because I am so slow.   :lmao:
« Reply #17 on: July 13, 2006, 12:31:44 PM »
Maybe posting a filled out title block would be best, then we can see what would be the best way to search for your information.
« Reply #18 on: July 13, 2006, 12:44:20 PM »
I hope no one took it that way :-)
Try listing out all the sheet label options:
A1 - A99
S1 - S99
TP
Krushert
« Reply #19 on: July 13, 2006, 12:48:47 PM »
Actually I just found it .  The Text Style.  The Drawing number has a unique text.  Ah I am going to say is my fearless leader created the title block.  Normally he creates more work but this time he inadvertly help me (us).  If I confine the search to just paper space and the text style I should come with the just the data for the drawing number.
see code.
(defun c:dwg ()
  (vl-cmdf ".undo" "m")
  (setq SS
(ssget "_x"
(list
  (cons 410 (getvar "ctab"))
  (cons 0 "MTEXT")
  (cons 7 "helv-meds-19")
  (CONS 8 "TITLE-BLOCK-TEXT")
Since I like to fish, I know I caught some data but I don't know what kind of fish (data) it is and how do I cook it (pull the drawing number from it).  :-)
« Reply #20 on: July 13, 2006, 12:55:04 PM »
Once you get the entity name, then use entget to get the entity's code, then look at dxf code 1.
« Reply #21 on: July 13, 2006, 01:07:51 PM »
Potential problem with this:
You must be in that active tab for it to work. If you are in Model space tab, no good.
Or if you are in a tab without a title block, no good.
If you know the name of the tab:
(cons 410 "tabname")
or this if you know the first letter
(cons 410 "N*")
So you may eant to remove that & then check the item to see if it is in paper space.
Krushert
« Reply #22 on: July 13, 2006, 01:59:07 PM »
It took me awhile to get this.  I went fishing in the help section and came up with this.  Though I really dont know "how" it is doing it.
(defun c:dwg ()
  (setq ss
(ssget "_x"
(list
  (cons 0 "MTEXT")
  (setq name (ssname SS 0))
  (setq code (cdr (entget name)))
and it return this for the entget.
Command: dwg ((0 . "MTEXT") (330 . <Entity name: 7ebfad40>) (5 . "47F") (100 .
"AcDbEntity") (67 . 1) (410 . "Layout1") (8 . "TITLE-BLOCK-TEXT") (100 .
"AcDbMText") (10 34.0938 1.54018 0.0) (40 . 0.625) (41 . 2.01297) (46 . 0.0)
(71 . 5) (72 . 5) (1 . "{\\T0.9;A1.02}") (7 . "helv-meds-19") (210 0.0 0.0 1.0)
(11 1.0 0.0 0.0) (42 . 1.68555) (43 . 0.638021) (50 . 0.0) (73 . 1) (44 . 0.75))
Command: 'VLIDE
and you said take a look at dxf code 1
« Reply #23 on: July 13, 2006, 02:11:26 PM »
(cdr (assoc 1 (entget name)))
Now you will have to look at the formating strings for Mtext, so that you will only get the text itself and not all the formating.  This is available in the help docs.
Krushert
« Reply #24 on: July 13, 2006, 03:37:16 PM »
I give up, not finding it in help and I briefly look in the waters of the swamp.  The closest I could find is the Section "Format Multiline Text".  It tells me how to add formating to text but not on removing it.  Could you point me right direction of #$%@ Help Docs.
It took me sometime to figure out on how the formation got there in the first place.  I am the culprit.  Typically we use a 3 characters dwg number, but the project that I am currently assign to is so large. I had to go to a 4 characters dwg# and reduce the spacing between characters.
« Reply #25 on: July 13, 2006, 03:41:41 PM »
You are in the right spot.  It tells you how to add it, so now you know what to look for.  Here is a quick one I wrote.  It might get you going on the right path.  There is also code floating around the net for removing mtext formatting.  If you find one, you can steal (borrow) the portion needed to do your code.
(defun StripString (String / cstr1 cstr2 nString cnt1 tstr1)
; Strips out formation for color, font, height and width.
(setq cnt1 1)
(while (and (setq cstr1 (substr String 1 1)) (> (strlen String) 0))
 (if (= cstr1 "\\")
   (setq cstr2 (substr String 2 1))
   (if (member (strcase cstr2) '("C" "F" "H" "W"))
     (while (/= (substr String cnt1 1) ";")
      (setq cnt1 (1+ cnt1))
     ); while
     (setq String (substr String (1+ cnt1) (strlen String)))
     (setq cnt1 1)
    ); progn
     (if nString
      (setq nString (strcat nString (substr String 1 1)))
      (setq nString (substr String 1 1))
     ); if
     (setq String (substr String 2 (strlen String)))
    ); progn
   ); if
  ); progn
   (if nString
   ); if
  ); progn
 ); if
); while
(setq tstr1 (vl-string->list nString))
(if (and (not (member 92 tstr1)) (member 123 tstr1))
 (setq tstr1 (vl-remove-if '(lambda (x) (or (= x 123) (= x 125))) tstr1))
); if
(vl-list->string tstr1)
« Reply #26 on: July 13, 2006, 03:53:51 PM »
« Reply #27 on: July 13, 2006, 03:56:36 PM »
Another stripper 8-)
You just wanted to say that.....
« Reply #28 on: July 13, 2006, 04:22:14 PM »
Yes  :-D
OK try this.
If you use the 410 you will not need the 67.
If you use the 67 then it will get all layouts if more than one.
(defun c:dwg ()
       (setq  ss
              (ssget "_x"
                       (list
                         (cons 0 "MTEXT")
                         ;'(67 . 1) ; in paper space but if you have >1 tab
                         '(-4 . ">=,>=,*")'(10 0.0 0.0 0.0)
                         '(-4 . "<=,<=,*")'(10 5.0 5.0 0.0)
      (setq txt (cdr (assoc 1 (entget (ssname SS 0)))))
      (setq txt (strip txt)) ; use a mtext code stripper
Krushert
« Reply #29 on: July 13, 2006, 04:37:36 PM »
:-o :-o :-o :-o :-o
 :cry: :cry: :cry: :cry: :cry:
All three suggested codes are huge for just formation that "should not" be there in the first place.   I still have to plunk it into my existing code.
Makes me rethink things again.
