Author Topic: Best Approaches  (Read 13746 times)
Re: Best Approaches
« Reply #15 on: July 10, 2006, 06:16:10 AM »
Doh!, I've even had this happen to me :oops:
I knew what it was as I wasn't looking for another issue (serialisation in your case), all though you build your dll with other modules they must also be in the same folder at runtime as your loaded dll.
- John Carmack
- J.R.R. Tolkien
Re: Best Approaches
« Reply #16 on: July 10, 2006, 08:33:40 PM »
How did you go, did you get it sorted?
- John Carmack
- J.R.R. Tolkien
DBARANAS
Re: Best Approaches
« Reply #17 on: July 11, 2006, 05:26:11 AM »
I got a little farther. I went to a modeless form and had to add the doclock code becuse it started to throw and exception by going modeless
Dim doclock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
'stuff
doclock.Dispose()
I have been trying to get deserialization working but everthying I try won't work. I checked your MSDN link but no luck that way.
I read this link. It explains some things
http://www.marcclifton.com/Articles/Performance/RawSerializer/tabid/130/Default.aspx
but it won't work with structures.
I just tried your suggestion about copying the modules in the bin/debug dir but it didn't work....Is that what you meant? It seems strange to have to do that
I think the problem has something to do with the version info and maybe if I can force it not to add it to the binary file it will work.
Funny that it seems to expect and knows the correct version but it just can't load it. Been googling since yesterday on "deserialization problem dll" Seems like lot's of people have this problem
DBARANAS
Re: Best Approaches
« Reply #18 on: July 11, 2006, 05:58:08 AM »
I just tried loading acad normally and running the dll outside of VS and it worked.
It think it has something to do with launching acad from VS.
Glenn R
Re: Best Approaches
« Reply #19 on: July 11, 2006, 06:06:58 AM »
I've done this before - you should be able to serialise to binary from a dll.
I've also found strange things that disappeared when you launch AutoCAD manually, not in the debugger...go figure.
Cheers,
Glenn.
Re: Best Approaches
« Reply #20 on: July 11, 2006, 06:58:41 AM »
Glad to hear you got it working.
Yes that's what I meant, the reason you have to load the other dll's that contain your other structures or code is no different to using any other dll, they must be in the same path of your dll or the windows system folder (or part of the global assembly files or similar for .net).
While they call them a 'class library', they are really both the lib and the dll in .net whereas in C++ you would link with .lib files when compiling your code but at runtime using the resources from the dll proper. You can do this because of 'jit' ing, your code is compiled into binary against your class lib just before use.
- John Carmack
- J.R.R. Tolkien
DBARANAS
Re: Best Approaches
« Reply #21 on: July 11, 2006, 07:42:32 AM »
Yes I just got it working in the debugger too
This is strange. In desparation I substituted my structure with this simple little test and it worked
   Dim BinFormatter As New Binary.BinaryFormatter()
   Dim R As New Rectangle(10, 20, 100, 200)
   BinFormatter.Serialize(FS, R)
   Dim R As New Rectangle()
   R = CType(BinFormatter.Deserialize(FS), Rectangle)
Then I am on to something, I put my biggest structure in and it works. Put back the original structure and it works. I have absolutely no files copied anywhere else now. I reload VS still works.
I copied the project to another hardrive....stil works. I hope it is not some flaky thing in VS....
DBARANAS
Re: Best Approaches
« Reply #22 on: July 11, 2006, 11:41:32 AM »
[/quote]
[/quote]
This is driving me crazy
I have 6 subs that read and write structures. I have 1 module where I keep all the structures. There is just 1 dll for the project.
By only stripping out the XML parts and replacing it with Binary nothing should have been any different. But it broke again the same way.
    Public Sub dataSetup(ByVal store As Boolean)
        'Select Case store
        '    Case True
        '        Dim SR As New StreamWriter("f:\data\setup.xml")
        '        Dim xmlSerial As New Xml.Serialization.XmlSerializer(opt.GetType)
        '        xmlSerial.Serialize(SR, opt)
        '        SR.Close()
        '        SR = Nothing
        '        xmlSerial = Nothing
        '    Case False
        '        Dim SR As New StreamReader("f:\data\setup.xml")
        '        opt = DirectCast(xmlSerial.Deserialize(SR), setupOptions)
        '        SR.Close()
        '        SR = Nothing
        'End Select
        Select Case store
            Case True
                Dim bf As New System.Runtime.Serialization.Formatters.Binary.BinaryFormatter()
                Dim fs As New IO.FileStream("f:\data\setup.dat", IO.FileMode.Create)
                bf.Serialize(fs, opt)
                fs.Close()
                fs = Nothing
                bf = Nothing
            Case False
                Dim fs As New IO.FileStream("f:\data\setup.dat", IO.FileMode.Open)
                opt = DirectCast(bf.Deserialize(fs), setupOptions)
                fs.Close()
                fs = Nothing
                bf = Nothing
        End Select
I had a few subs doing it the binary way and everything worked then I went ahead and just changed them all and it broke. I went back and changed them one at a time and it worked until I changed the last one. If the first thing that happens it that an XML file gets serialized and then deserialized the all the binary read and writes will be OK after that.
Now it works again but only if I do this. If I don't do this then I get the JIT error and it cannot load the assembly. At least I now know what breaks it and what fixes it. What a hack job this is becoming  :pissed:
mohnston
  • CAD Programmer
Re: Best Approaches
« Reply #23 on: July 11, 2006, 12:38:21 PM »
I'm out of my league here but . . .
Could this have anything to do with the "Copy Local" settings of the acdbmgd.dll and acmgd.dll?
I think they should be set to False when running in IDE and True when building for running outside IDE.
I know this frustrated me when I began to look at C#-AutoCAD.
CAD Programming Solutions
Glenn R
Re: Best Approaches
« Reply #24 on: July 11, 2006, 06:28:31 PM »
OK, I'll need some more info before I can help.
What is the format of the file you are trying to serialize...is it pure XML or some other structure...is it a class object or what?
Can you post up the file format or attach an example file for me to see/test with?
Glenn R
Re: Best Approaches
« Reply #25 on: July 11, 2006, 06:49:28 PM »
Also, is there any particular design decision that made you use structures instead of classes or was it a case of a struct is the closest thing to a UDT that you were previously using?
Cheers,
Glenn.
DBARANAS
Re: Best Approaches
« Reply #26 on: July 11, 2006, 07:16:03 PM »
I had these set to true, I switched them and tried it but it made no difference in this case
DBARANAS
Re: Best Approaches
« Reply #27 on: July 11, 2006, 08:30:51 PM »
These are all structures made up of primitives, some of the elements are array's and a few are multidimensional array's.
I made a stripped down version just to test this problem. I ran it a few times and it reproduces the problem exactly. it should run in c:\test
All you have to do is comment out the dataGrid subs which I left as the XML read write and the rest won't work. Put them back and it will work
I stripped out acdbmgd.dll and acmgd.dll to get the zip sile under 100K. Once you point the new paths it should work OK
DBARANAS
Re: Best Approaches
« Reply #28 on: July 11, 2006, 09:01:56 PM »
Cheers,
Glenn.
Yes structures were the closest thing to UDT's. I tried to use classes so I could not be limited by the amount of solid objects a model could contain but it was too hard for me so I am sticking with what already works.
I think of these structures like big cubes where one element can see something it is connected to and also know what the other element sees. There is lots of code that looks like this everywhere. After some time it started to make sense and became intuitive :lol:
                    .ang = (pr(.jP(mS)).ang + pr(.jP(mS)).angB) - 90
                    opsAstdW = fTangent(.angA, .stdW)
                    'Joined wall
                    ofsXIn(ref, pr(.jP(mS)).x, pr(.jP(mS)).y, pr(.jP(mS)).ang, pr(.jP(mS)).adjL + aAngOfs)
                    'this wall
                    ofsXIn(ref, .x, .y, pr(.jP(mS)).ang + pr(.jP(mS)).angB, .stdW)
                    ofsYOut(ref, .x, .y, pr(.jP(mS)).ang + pr(.jP(mS)).angB, opsAstdW + pr(.jP(mS)).oMatT(0))
I learned that the whole buiding structure is basically 1 big object because changing one design element affects so many things in related (building) assemblies. The #1 design rule for this project was "no drafting" everything is parametric and is done and undone entirely in the program.
I have done some off the wall things like let the user design the building and then based of the weekly price of lumber, the size of the trucks, the onsite assembly order.....it will figure out the actual sizes of wall panels.
And to top that as if it were not already enough...this site crews assemble the building like 1,2,3,4,5,.....which has nothing to do with the real references that are only internal to the program. Hard to believe but I have seen that get messed up, and like with any new construction system ...no matter how well you think you have thought of everything all it takes is for something like this to happen and it goes bad.
