Author Topic: blank text  (Read 3392 times)
Ron Heigh
blank text
« on: March 17, 2004, 12:59:54 PM »
Where would I get a routine to remove all blank text (including just spaces) in a drawing?
blank text
« Reply #1 on: March 17, 2004, 01:08:05 PM »
Try this to get the blank text......
(ssget "x" '((1 . "")))
and for spaces ... well, you could have any number of spaces in a text entity, so it would need to be a deeper lisp than above...
Ron Heigh
blank text
« Reply #2 on: March 17, 2004, 02:28:30 PM »
Thanks Keith.
I took what you gave me and solved the spaces on my own.
Regards
blank text
« Reply #3 on: March 17, 2004, 02:47:32 PM »
Did you see this code on this thread?
;_____________________________________________________________________________
  ;; DELETES NUL LINES OF TEXT, MTEXT, AND BLOCKS
  (if (setq TXT   (ssget "X"
             '((-4 . "<and")
          (-4 . "<or")
          (0 . "MTEXT")
          (0 . "TEXT")
          (-4 . "or>")
          (-4 . "<or")
          (1 . "")
          (1 . " ")
          (1 . "  ")
          (1 . "   ")
          (1 . "{}")
          (1 . "{ }")
          (1 . "{  }")
          (1 . "{   }")
          (1 . "{}\P")
          (1 . "{ }\P")
          (1 . "{  }\P")
          (1 . "{   }\P")
          (-4 . "or>")
          (-4 . "and>")
      (command "_erase" TXT "")
      (princ (strcat "\n  "
           (itoa (sslength TXT))
           " nul text strings deleted. "
    (princ "\n  No nul text strings found. ")
  (setq   BLK   (tblnext "BLOCK" T)
   NAMES nil
  (while BLK
    (if   (= (cdr (assoc 0 (entget (cdr (assoc -2 BLK))))) "ENDBLK")
   (if (setq NB (ssget "X" (list (assoc 2 BLK))))
     (command "_erase" NB "")
   (setq NAMES (cons (cdr (assoc 2 BLK)) NAMES))
    (setq BLK (tblnext "BLOCK"))
  (if NAMES
    (progn (textscr)
      (princ "\n  Nul blocks found and need purging: ")
      (foreach X NAMES (princ "\n    ") (princ X))
    (princ "\n  No nul blocks found. ")
blank text
« Reply #4 on: March 17, 2004, 10:02:21 PM »
Quote from: CAB
Actually I did not...
