Author Topic: RText Justification  (Read 6919 times)
Matersammichman
RText Justification
« on: July 06, 2006, 07:29:32 AM »
Is there any way (yet) to Middle Center justify RText?
Re: RText Justification
« Reply #1 on: July 06, 2006, 08:26:28 AM »
Not sure what version you're using but have you tried FIELDS in MTEXT yet? IMHO, it beats the snot out of RTEXT.
Matersammichman
« Reply #2 on: July 07, 2006, 07:13:44 AM »
Haven't tried it. I'll look into it. Just got off of ADT2002 and onto 2005.
Andrea
« Reply #3 on: July 07, 2006, 09:06:49 AM »
I use RTEXT for many years..and didn't find the way to change the text justification..
but with the field now....seem to be better.
No diesel code.
The problem is that some client have AutoCAd 2000i.   :lol:
Keep smile...
Bob Wahr
« Reply #4 on: July 07, 2006, 10:48:28 AM »
Same as RTEXT, you have to have an AutoCAD that will use it for it to work.  2000i(or was it 2002) didn't ship with express tolls, it cost extra and without express tools, no RTEXT.
pmvliet
« Reply #5 on: July 07, 2006, 11:03:00 AM »
Rtext doesn't work with LT either... :x
Birdy
« Reply #6 on: July 07, 2006, 12:25:29 PM »
I had the same question when on '04.  No luck.
Abandoned RTEXT for fields when we switched to '06. :) much nicer.
pmvliet
« Reply #7 on: July 07, 2006, 01:05:27 PM »
Woo Hoo
I beat birdy in posts... :lol:
Hey Jim...
Birdy
« Reply #8 on: July 07, 2006, 10:57:12 PM »
Grrrrrr....
been a carpy week (cept for mon/tues :) )
Matersammichman
« Reply #9 on: July 11, 2006, 07:24:17 AM »
Thanks Mark. MText Fields does work great!!!
CHulse
« Reply #10 on: January 12, 2023, 08:22:09 AM »
Sorry to resurrect an antique thread, but it seemed appropriate.
Have there been any changes to RTEXT since this thread started? Still no way to change justification?
Unfortunately, I'm not aware of any way to use custom drawing properties in Diesel within a field (GETPROP works only within RTEXT). I know you can reference custom dwg props in a field directly, but I know of no way to do any math with that approach.
SO -
Still no what to adjust RTEXT justification?
No way to use custom dwg props within diesel in fields (to use with math functions)?
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
« Reply #11 on: January 12, 2023, 08:33:00 AM »
Still no way to justify Rtext that I know of (I highly doubt they've even touched Rtext in 20+ years).
I think you know that you can use Diesel in a field but I don't think I totally understand your need. Do you have a specific example?
CHulse
« Reply #12 on: January 12, 2023, 08:38:05 AM »
I'm using it create a sheet index for a large project that will be updatable based on some custom dwg props.
This is an example of the RTEXT I am using now. It works fine, I just wish I could justify MC.
$(getprop,%sheet_Prefix)$(+,$(getprop, %sheet_num_offset),1)
Specifically, the GETPROP diesel function does not work with diesel in fields, only RTEXT.  Makes no sense to me. :uglystupid2:
Cary Hulse
« Reply #13 on: January 12, 2023, 09:22:40 AM »
Ah. Sorry. That sucks because that sounds like a big time saver.
CHulse
« Reply #14 on: January 12, 2023, 05:09:07 PM »
The RTEXT route works fine, I just wish it behaved more like MTEXT... Oh well.
Just makes no sense to me that Diesel in fields doesn't leverage everything Diesel can do. Dumb.
Cary Hulse
