Author Topic: Entity layer by colour  (Read 2430 times)
Shade
« on: July 05, 2006, 10:38:40 AM »
Does anyone have a lisp that will sort the entities to layers by the colour of the entity.
I have a drawing that was made in chief architect and translated to cad, but all the entities are on 1 layer and the colours is changed.
I wish to send each object of colour to the co-orsponding layer.
ie. line with colour 5 change to layer 5, with colour by layer?
I may have to writen something, but time is of essence.
Any help would be greatly appreciated..
Damn architects, oh wait that me....  :lmao:
M-dub
Re: Entity layer by colour
« Reply #1 on: July 05, 2006, 10:42:50 AM »
Have you tried the QSelect command?  I think it should work for you...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: July 05, 2006, 10:58:02 AM »
(defun test (/ ss)
  (if (setq ss (ssget "_X"))
    (foreach x (mapcar (function entget)
                       (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex ss)))
      (if (assoc 62 x)
  (entmod (subst (cons 8 (itoa (cdr (assoc 62 x)))) (assoc 8 x) x))
  (entupd (cdr (assoc -1 x)))
) ;_  progn
      ) ;_  if
    ) ;_  foreach
  ) ;_  if
) ;_  defun
M-dub
« Reply #3 on: July 05, 2006, 11:03:41 AM »
oops, after re-reading your first post, I see what you're trying to do.  Guess Qselect isn't what you're after... Sorry ;)
  • Custom Title
« Reply #4 on: July 05, 2006, 11:08:16 AM »
(defun test (/ ss)
      (if (assoc 62 x)
) ;_  progn
      ) ;_  if
    ) ;_  foreach
  ) ;_  if
) ;_  defun
Nice stuff !!
Shade
« Reply #5 on: July 05, 2006, 11:32:46 AM »
Thanks ElpanovEvgeniy, works like a charm.
Thanks for the input M-dub, but i was using ssx and properties pullout. Slower then a lisp but faster then manual change.
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #6 on: July 05, 2006, 01:21:39 PM »
Fnork!
Oh wait.  Possibly they are billing C.A. as a BIM product and that was an undeserved fnork...although I did let one escape when I first read this and what's done can't be undone.  Oh well, I'll just have to leave it be :-)
Bobby C. Jones
