Author Topic: Parenthesis matching ... DUH!!!  (Read 5607 times)
« on: June 29, 2006, 03:54:41 AM »
(ACTION_TILE "nyloc" "(_calextra)")
(ACTION_TILE "mk_pick" "(progn(_getparams)(DONE_DIALOG 9))")
(ACTION_TILE "replaceblock" "(progn (SETQ bolt:replace T) (check_eval)")
(ACTION_TILE "eval_length" "(_evallen)")
(ACTION_TILE "accept" "(check_eval)")
(ACTION_TILE "cancel" "(DONE_DIALOG 0)")
No prizes ...  but this had me chasing my tail for a while ...    :oops:
Re: Parenthesis matching ... DUH!!!
« Reply #1 on: June 29, 2006, 07:00:51 AM »
my guess ....
« Reply #2 on: June 29, 2006, 08:00:29 AM »
yep, and damn difficult to find.  ... locks up the routine, and ACAD, dead .. with no error message ..
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: June 29, 2006, 08:05:48 AM »
(ACTION_TILE "nyloc" (VL-PRIN1-TO-STRING '(_calextra)))
(ACTION_TILE "mk_pick" (VL-PRIN1-TO-STRING '(progn(_getparams)(DONE_DIALOG 9))))
(ACTION_TILE "replaceblock" (VL-PRIN1-TO-STRING '(progn (SETQ bolt:replace T) (check_eval))))
(ACTION_TILE "eval_length" (VL-PRIN1-TO-STRING '(_evallen)))
(ACTION_TILE "accept" (VL-PRIN1-TO-STRING '(check_eval)))
(ACTION_TILE "cancel" (VL-PRIN1-TO-STRING '(DONE_DIALOG 0)))
« Reply #4 on: June 29, 2006, 08:17:36 AM »
I cheated! :-)
delium55
« Reply #5 on: June 29, 2006, 09:20:08 AM »
Bonjour Mark,
Just a simple question; how do you check the extra paranthesis with VIM.
« Reply #6 on: June 29, 2006, 09:33:47 AM »
If the question comes up it's <Ctrl> <M> in Textpad.
« Reply #7 on: June 29, 2006, 10:01:52 AM »
Bonjour Mark,
In that particular instance I simply placed the cursor on each beginning paren, Vim 7 highlights the opening, closing parens by default.
Joe Burke
« Reply #8 on: June 29, 2006, 11:47:21 AM »
Michael,
I wish TextPad was smart enough to ignore commented out lines while checking parens with Ctrl M.
« Reply #9 on: June 29, 2006, 12:30:58 PM »
Also in UltraEdit placing the cursor causes the matching paren to highlight.
« Reply #10 on: June 29, 2006, 03:00:52 PM »
Michael,
That's a good idea (as an toggled option) Joe, I'll pass that on to the Helios folks when I get a chance. Thanks.
qjchen
  • Best wishes to all
« Reply #11 on: June 29, 2006, 10:03:00 PM »
when use Pspad, type the left Parenthesis, the right Parenthesis automatic generate, when point to the left Parenthesis, it automatic found the Parenthesis.
Lisplink use ctrl+M to find the matching. and its ctrl+A is very useful for me.
Fig.1 Pspad, Fig.2 Lisplink
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
« Reply #12 on: June 30, 2006, 06:24:27 PM »
Thanks guys,
It wasn't so much the capability of checking matching paren's  line by line ..
.. more the fact that we have to know where to look.
Because AutoCAD freezes when it tries to evaluate the callback, any debugging and animation/tracing is suspended as well .. so I thought the problem was in the (check_eval) function ; but only under certain conditions 'cause it is called from other locations as well.
Resolved the location by using debug:print statements. .. just tedious !
Sort of an anticlimax to discover the cause, I tell you.
MickD
« Reply #13 on: June 30, 2006, 06:28:32 PM »
It's allways something simple :D
I know just how you feel, I had a lot of these moments lately!
- John Carmack
- J.R.R. Tolkien
Andrea
« Reply #14 on: July 04, 2006, 12:00:55 AM »
now if you talk about lisp editor...
I use this....
http://www.studioware.com/
Keep smile...
