Author Topic: extract out pick point  (Read 3285 times)
rude dog
« on: March 15, 2004, 02:50:21 PM »
if ssnamex echoes this:
((1 <Entity name: 40069128> 0 (0 (34.0599 0.0 0.0))))
(34.0599 0.0 0.0)and this is this the pick point (i think?)how does one extract this out into a list (and setq its value)...with some type of a CxxxxR function? :?
rude dog
« Reply #1 on: March 15, 2004, 02:56:53 PM »
i know i could use a getpoint....but now im curious
SMadsen
« Reply #2 on: March 15, 2004, 03:25:02 PM »
The exact sequence would be something like
(cadr (cadddr (car lst)))
but dealing with return values from SSNAMEX it would be a good idea to check which kind of pick was made because the output varies. So first check the CAR element, for example:
(setq ssxlist (ssnamex sset a))
(if (= (car (setq slist (car ssxlist))) 1)
  (setq ppoint (cadar (reverse slist))))
rude dog
« Reply #3 on: March 15, 2004, 03:37:03 PM »
:)  wow...thanks I'll study it
