Author Topic: Info About CAdUiDockControlBar Class ?  (Read 6149 times)
LE
Re: Info About CAdUiDockControlBar Class ?
« Reply #15 on: July 08, 2006, 09:44:30 PM »
As always Mick;
Thanks!
Here are some code of what I am doing/playing... it has been a lot of fun.  :-)
In the custom palette class derivation I put:
File = Cpalette.h
public:
// tree control
CTreeCtrl *pTreeCtrl;
// tooltips control
CToolTipCtrl m_tooltip;
// for the tooltips
void RelayEvent(UINT message, WPARAM wParam, LPARAM lParam);
BOOL PreTranslateMessage(MSG* pMsg);
afx_msg void OnContextMenu(CWnd*, CPoint point);
File = Cpalette.cpp
// map to hold all the tooltips strings
typedef CMap< HTREEITEM,HTREEITEM&,CString,CString& > TipMap;
extern TipMap tooltipMap;
In one function to add the controls I place:
tooltipMap.RemoveAll(); // removing first the previous tooltips
// add the tree control
pTreeCtrl = new CTreeCtrl;
CRect rect;
GetClientRect(&rect);
rect.DeflateRect(2, 8, 2, 2);
// create the tree
if (!pTreeCtrl->Create(WS_CHILD | WS_VISIBLE |
TVS_HASLINES | TVS_HASBUTTONS |
TVS_LINESATROOT, rect,
this, ID_INSTANTBARTREECTRL))
acdbFail(_T("\nTree control fail!.\n"));
// tree style
pTreeCtrl->ModifyStyleEx(0, WS_EX_CLIENTEDGE);
// sample layers data
AcDbLayerTable* LayerTable = NULL;
acdbHostApplicationServices()->workingDatabase()->getSymbolTable(LayerTable, AcDb::kForRead);
AcDbLayerTableIterator* pLayerIterator;
LayerTable->newIterator(pLayerIterator);
AcDbLayerTableRecord* LayerTableRecord;
char *pLayerName;
CImageList pImageList;
CBitmap bitmap;
// tree images setup
pImageList.Create(16, 16, ILC_COLORDDB | ILC_MASK, 0, 0);
bitmap.LoadBitmap(IDB_TREECTRL);
pImageList.Add(&bitmap, RGB(255, 0, 255));
pTreeCtrl->SetImageList(&pImageList, TVSIL_STATE);
bitmap.DeleteObject();
pImageList.Detach();
// iterate all layers
for(pLayerIterator->start() ; !pLayerIterator->done() ; pLayerIterator->step())
pLayerIterator->getRecord(LayerTableRecord, AcDb::kForRead);
// layer name
LayerTableRecord->getName(pLayerName);
// insert the layer name as main node
HTREEITEM nodeLayer = pTreeCtrl->InsertItem(pLayerName);
tooltipMap[nodeLayer] = pLayerName; // Set the tool tip text of the item.
// setup the state and the image
pTreeCtrl->SetItemState(nodeLayer,INDEXTOSTATEIMAGEMASK(1), TVIS_STATEIMAGEMASK);
// returns an AcCmColor object
// that contains the color value of the layer.
//AcCmColor colour = LayerTableRecord->color();
// returns true if and only if the layer is frozen.
// If the layer is thawed, then false is returned.
if (LayerTableRecord->isFrozen())
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Frozen"), nodeLayer);
tooltipMap[nodeChild] = "Frozen";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(3), TVIS_STATEIMAGEMASK);
else
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Thawed"), nodeLayer);
tooltipMap[nodeChild] = "Thawed";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(2), TVIS_STATEIMAGEMASK);
// returns true if and only if the layer is locked.
// If the layer is unlocked, then false is returned.
if (LayerTableRecord->isLocked())
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Locked"), nodeLayer);
tooltipMap[nodeChild] = "Locked";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(6), TVIS_STATEIMAGEMASK);
else
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Unlocked"), nodeLayer);
tooltipMap[nodeChild] = "Unlocked";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(7), TVIS_STATEIMAGEMASK);
// returns true if the layer is plottable.
// If the layer is not plottable, then false is returned.
if (LayerTableRecord->isPlottable())
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Plottable"), nodeLayer);
tooltipMap[nodeChild] = "Plottable";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(8), TVIS_STATEIMAGEMASK);
else
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Unplottable"), nodeLayer);
tooltipMap[nodeChild] = "Unplottable";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(9), TVIS_STATEIMAGEMASK);
// returns true if the layer is off.
// If the layer is on, then false is returned.
if (LayerTableRecord->isOff())
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("Off"), nodeLayer);
tooltipMap[nodeChild] = "Off";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(5), TVIS_STATEIMAGEMASK);
else
HTREEITEM nodeChild = pTreeCtrl->InsertItem(_T("On"), nodeLayer);
tooltipMap[nodeChild] = "On";
pTreeCtrl->SetItemState(nodeChild, INDEXTOSTATEIMAGEMASK(4), TVIS_STATEIMAGEMASK);
LayerTableRecord->close();
acutDelString(pLayerName);
delete pLayerIterator;
LayerTable->close();
m_tooltip.Create(this);
m_tooltip.Activate(TRUE);
m_tooltip.AddTool(GetDlgItem(ID_INSTANTBARTREECTRL), "Layer Explorer"); // adding my tooltips!
BOOL CMyPalette::PreTranslateMessage(MSG* pMsg)
if(pMsg->message == WM_MOUSEMOVE && pMsg->hwnd == pTreeCtrl->m_hWnd)
CPoint point(LOWORD(pMsg->lParam), HIWORD(pMsg->lParam));
HTREEITEM hItem = pTreeCtrl->HitTest(point);
if(hItem != NULL)
CString text = tooltipMap[hItem];
m_tooltip.UpdateTipText(text, pTreeCtrl);
m_tooltip.RelayEvent(pMsg);
return FALSE;
void CMyPalette::OnContextMenu(CWnd* pWnd, CPoint point)
if (pWnd != pTreeCtrl)
CWnd::OnContextMenu(pWnd, point);
return;
CPoint CurPos;
UINT nFlags;
GetCursorPos(&CurPos);
ScreenToClient(&CurPos);
HTREEITEM hItemClk = pTreeCtrl->HitTest(CurPos, &nFlags);
pTreeCtrl->SelectItem(hItemClk);
CMenu menu;
CMenu* pContextMenu;
menu.LoadMenu(IDR_MENU1);
ASSERT(menu);
CString txt = "";
if ((hItemClk != NULL) && (TVHT_ONITEM & nFlags))
pTreeCtrl->Select(hItemClk, TVGN_CARET);
txt = pTreeCtrl->GetItemText(hItemClk);
pContextMenu = menu.GetSubMenu(0);
ASSERT(pContextMenu);
// delete previous items
// here I have to do the following since I did not found a better way
pContextMenu->DeleteMenu(0, MF_BYPOSITION);
pContextMenu->DeleteMenu(1, MF_BYPOSITION);
// to here
pContextMenu->AppendMenu(MF_STRING, 0, (LPCTSTR)txt.GetString());
pContextMenu->AppendMenu(MF_SEPARATOR, 0, _T(""));
pContextMenu->AppendMenu(MF_STRING, 0, _T("Menu Property1"));
pContextMenu->AppendMenu(MF_STRING, 0, _T("Menu Property2"));
pContextMenu->AppendMenu(MF_STRING, 0, _T("Menu Property3"));
pContextMenu->AppendMenu(MF_STRING, 0, _T("Menu Property4"));
pContextMenu->AppendMenu(MF_STRING, 0, _T("Menu Property5"));
CMenu menuPopup;
menuPopup.CreatePopupMenu();
ASSERT(menuPopup);
menuPopup.AppendMenu(MF_STRING | MF_ENABLED, 0, _T("PopupMenu Item1"));
menuPopup.AppendMenu(MF_STRING | MF_ENABLED, 0, _T("PopupMenu Item2"));
menuPopup.AppendMenu(MF_STRING | MF_ENABLED, 0, _T("PopupMenu Item3"));
menuPopup.AppendMenu(MF_STRING | MF_ENABLED, 0, _T("PopupMenu Item4"));
pContextMenu->AppendMenu(MF_POPUP | MF_ENABLED, (UINT)menuPopup.Detach(), _T("&Open PopupMenu"));
pContextMenu->TrackPopupMenu(TPM_LEFTALIGN|TPM_RIGHTBUTTON, point.x, point.y, this, 0);
pContextMenu->Detach();
menu.Detach();
« Last Edit: July 08, 2006, 09:51:47 PM by LE »
LE
« Reply #16 on: July 09, 2006, 07:01:43 PM »
Mick;
And what approach do you use to update the data (controls) for your palette? [OnSetActive ?] - when switching documents.
le
MickD
  • !false...it's funny 'cause it's true!
« Reply #17 on: July 09, 2006, 07:14:13 PM »
I haven't gone that far with it yet Luis, at the moment I'm only interested in what's in my master model drg. The button I use to load the form only works in the current active document which is all I need at the moment. This way I can get objects from the master model and import them into a different document.
There are many document event handlers to override though so I imagine it wouldn't be too hard.
A programmer's wife tells him, "Run to the store and pick up a loaf of bread. If they have eggs, get a dozen."
The programmer comes home with 12 loaves of bread.
LE
« Reply #18 on: July 09, 2006, 07:30:16 PM »
I am using a docmanager reactor . . .
class CDocReactor : public AcApDocManagerReactor
public:
virtual void  documentActivated(AcApDocument* pDoc);
template <class T> class AsdkDataManager : public AcApDocManagerReactor
public:
    AsdkDataManager()
        acDocManager->addReactor(this);
    ~AsdkDataManager()
        acDocManager->removeReactor(this);
    virtual void documentToBeDestroyed( AcApDocument *pDoc )
        m_dataMap.erase(pDoc);
    T& docData(AcApDocument* pDoc)
        std::map<AcApDocument*, T>::iterator i;
        i = m_dataMap.find(pDoc);
        if (i==m_dataMap.end())
            return  m_dataMap[ pDoc ];
        else
            return (*i).second;
    T& docData()
        return docData(acDocManager->curDocument());
private:
    std::map<AcApDocument*, T> m_dataMap;
static CDocReactor* gpDocReactor = NULL;
void CDocReactor::documentActivated(AcApDocument* pDoc)
// my update function for the tree control data
void InitApplication()
gpDocReactor = new CDocReactor();
acDocManager->addReactor(gpDocReactor);
void UnloadApplication()
if(gpDocReactor)
acDocManager->removeReactor(gpDocReactor);
delete gpDocReactor;
MickD
« Reply #19 on: July 09, 2006, 09:48:26 PM »
That'll do it :)
The .net equivalent for reference is Autodesk.AutoCAD.ApplicationServices.DocumentCollection events methods which wrap these reactors.
