dimscale in dxf code?
paulmcz:
I'd like to select dimension and set the dimscale to the value that dimension has. Where in the dxf code can I find the value and how can I retrieve it, if the dimscale for that dimension was set to 1?
This is what I have but it doesn't work if the selected dimension has dimscale 1.
--- Code: ---(defun c:dsc (/ dim lst xd)
(setq dim (car (entsel "\n Select dimension to copy dimscale from: ")))
(setq lst (entget dim '("ACAD")))
(setq xd (cdr (assoc 1040 (cdadr (assoc -3 lst)))))
(setvar "dimscale" xd)
--- End code ---
Thanks,
Paul.
Crank:
--- Code: ---(command ".dim1" "restore" "" pause)
--- End code ---
Jeff_M:
--- Code: ---(or (setq xd (cdr (assoc 1040 (cdadr (assoc -3 lst)))))
(setq xd 1.0)
--- End code ---
This will default to 1 if the selected dimension has not been altered.
A comment if I may: You should verify that 1.) the user DID select something, and 2.) the selected entity IS a dimension.....
paulmcz:
--- Quote from: Jeff_M on June 27, 2006, 05:42:35 PM ---
(setq xd 1.0)
--- End code ---
--- End quote ---
Thanks Jeff. That's what I have.
(command "cmdecho" (getvar "cmdecho"))
(setq
(cond ((or
(= (cdr (assoc 0 lst)) "DIMENSION")
(= (cdr (assoc 0 lst)) "LEADER")
(if (assoc -3 lst)
(setq xd 1.0)
(princ (strcat "\n Dimscale is now set to: " (rtos xd 2 3)))
(T (princ "\n No dimension selected"))
--- End code ---
I am wondering if the dimscale value exists in the code if you select dimension that has dimscale 1. This > (assoc -3 lst) < evaluates to nil in such case.
paulmcz:
--- Quote from: Crank on June 27, 2006, 05:27:18 PM ---
--- End code ---
--- End quote ---
Very simple and it does the job too.
Thanks.
Navigation
[0] Message Index
[#] Next page
Go to full version
