Author Topic: dimscale in dxf code?  (Read 3174 times)
paulmcz
« on: June 27, 2006, 04:29:51 PM »
I'd like to select dimension and set the dimscale to the value that dimension has. Where in the dxf code can I find the value and how can I retrieve it, if the dimscale for that dimension was set to 1?
This is what I have but it doesn't work if the selected dimension has dimscale 1.
(defun c:dsc (/ dim lst xd)
(setq dim (car (entsel "\n Select dimension to copy dimscale from: ")))
(setq lst (entget dim '("ACAD")))
(setq xd (cdr (assoc 1040 (cdadr (assoc -3 lst)))))
(setvar "dimscale" xd)
Thanks,
Paul.
Crank
Re: dimscale in dxf code?
« Reply #1 on: June 27, 2006, 05:27:18 PM »
(command ".dim1" "restore" "" pause)
« Reply #2 on: June 27, 2006, 05:42:35 PM »
(or (setq xd (cdr (assoc 1040 (cdadr (assoc -3 lst)))))
    (setq xd 1.0)
This will default to 1 if the selected dimension has not been altered.
A comment if I may: You should verify that 1.) the user DID select something, and 2.) the selected entity IS a dimension.....
paulmcz
« Reply #3 on: June 27, 2006, 08:11:28 PM »
    (setq xd 1.0)
Thanks Jeff. That's what I have.
  (command "cmdecho" (getvar "cmdecho"))
  (setq
  (cond ((or
   (= (cdr (assoc 0 lst)) "DIMENSION")
   (= (cdr (assoc 0 lst)) "LEADER")
(if (assoc -3 lst)
    (setq xd 1.0)
   (princ (strcat "\n Dimscale is now set to: " (rtos xd 2 3)))
(T (princ "\n No dimension selected"))
I am wondering if the dimscale value exists in the code if you select dimension that has dimscale 1. This > (assoc -3 lst) < evaluates to nil in such case.
paulmcz
« Reply #4 on: June 27, 2006, 08:21:36 PM »
Very simple and it does the job too.
Thanks.
Nick-LTC
« Reply #5 on: July 06, 2006, 12:07:18 PM »
;try this, in your cond statement
(cond   ((or
   (if (assoc -3 lst)
       (setq xd (if (setq xd (cdr (assoc 1040 (cdadr (assoc -3 lst))))) xd 1.0)); added to check for nil<<<<<<<<<<<
       (setq xd 1.0)
« Reply #6 on: July 06, 2006, 12:33:12 PM »
Nick, welcome to the swamp.
Here is my version of paulmcz's routine.
(defun c:dsc (/ dim lst xd usercmd)
  (setq usercmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (or
    (and
      (setq dim (entsel "\n Select dimension to copy dimscale from: "))
      (setq lst (entget (car dim) '("ACAD")))
      (vl-position (cdr (assoc 0 lst)) '("DIMENSION" "LEADER"))
      (or
        (and (assoc -3 lst)
        (setq xd 1.0)
  (setvar "cmdecho" usercmd)
