Author Topic: How do I load VLX and LISP files with VBA?  (Read 6783 times)
Atook
  • AKA Tim
Re: How???
« Reply #15 on: June 27, 2006, 03:13:38 PM »
..ThisDrawing.SendCommand "(load ""lispname.lsp"" (alert ""Load knackered.""))" & vbCr..
MP:
Are there too many quotes in the alert line?
(load "lispname.lsp" (alert "Load knackered.")) works for me, but I had to delete some of the quotes.
With the extra quotes the load tossed a binky..  :-D
Matersammichman
Re: How???
« Reply #16 on: June 27, 2006, 03:14:56 PM »
 :wink:It's all good...
All I had to do was add double backslashes.
Thanks all!
Bob Wahr
Re: How???
« Reply #17 on: June 27, 2006, 03:47:08 PM »
Atook, as a lisp statement, (load "lispname.lsp" (alert "Load knackered.")) is correct.  If you want that to work from vba though, it needs to be ThisDrawing.sendcommand "(load ""lispname.lsp"" (alert ""Load knackered.""))"
Double quotes("") in a string in VBA add a single quote(") to the string.  It's pretty much the same reason that you have to use a double backslash (\\) in lisp.
David Hall
  • Automatic Duh Generator
Re: How???
« Reply #18 on: June 27, 2006, 04:21:00 PM »
Dont toss the binky....
Atook
  • AKA Tim
Re: How???
« Reply #19 on: June 27, 2006, 04:33:12 PM »
Thanks for pointing that out Bob, I should have seen it.
I always used Chr$(34) for a quote in VB6, but never had to evaluate a quote in VBA.
Good to know.
Bob Wahr
Re: How???
« Reply #20 on: June 27, 2006, 05:10:27 PM »
heh, missed the tossed the binky.  Chr$(34)/Chr(34)   works in VBA as well, I just couldn't remember the number so "" was easier.  AFAIR, "" works in VB6 as well.  When it gets down to it, it probably doesn't matter which way you skin the cat as long as it ends up on the fish hook.
