Author Topic: Discovering AutoCAD...  (Read 1556 times)
Andrea
« on: June 26, 2006, 02:37:52 PM »
Hi all,...
I work AutoCAD since release 2.0...
each day I lurn and discover many thing in AutoCAD..
think i'm not finished.. :wink:
But one thing I've discover today..
maybe you already know...but I would like to share this thing with all people
who help me on this forum...
OK,
When you make a PAN with the mouse wheel button, you can also hold the "Shift" key to
activate the ortho ON right ?
but see what happen when hold the "Ctrl" key and try to make a PAN.
(note: you have to push the "Ctrl" key BEFORE making a PAN with the mouse wheel)
If you have any combinason key that I can try also....please let me know.
seeya !
Keep smile...
Re: Discovering AutoCAD...
« Reply #1 on: June 26, 2006, 02:57:55 PM »
Neat stuff Andrea.
On my system, Intella Mouse
[Crtl] [Middle Button]  -> Auto Pan
[Shift] [Middle Button]  ->  Ortho Pan
uncoolperson
« Reply #2 on: June 26, 2006, 03:08:49 PM »
*shudder*....microstation....
Didge
« Reply #3 on: June 28, 2006, 09:02:30 AM »
Well thats 2 new things I've learnt today, I didn't know either option was available. Not sure about the autopan but the ortho pan will definately be of use to me. Thanks a bunch.
Another goodie is  the "3dCorbit" command, not to be confused with "3dorbit".
Think Slow......
hudster
« Reply #4 on: June 28, 2006, 09:15:01 AM »
In case you didn't know, the shift ortho mode works with all commands, so if you need to draw a line in orth mode you can do it that way.
Kate M
« Reply #5 on: June 28, 2006, 01:10:12 PM »
In case you didn't know, the shift ortho mode works with all commands.
2005 & above, I think. (Doesn't work for 2004.)
Bob
« Reply #6 on: June 29, 2006, 03:13:29 AM »
Just tried it with plain old ACAD2K.
It works!
