Author Topic: string manipulation  (Read 5502 times)
matrix2005in
string manipulation
« on: June 26, 2006, 02:35:53 PM »
how i can divide combined strings to equal number of strings?/
eg:- the combined string is - ABCDEFGHIJKL
i would like to divide into - ABC DEF GHI JKL
how i can do it??
thanks
mathew
Re: string manipulation
« Reply #1 on: June 26, 2006, 02:58:09 PM »
Find out how long the stirng is, then find the number of new strings you want.  Then use substr.
Hint: strlen, loop with while, substr
« Reply #2 on: June 26, 2006, 03:16:39 PM »
What do you want the final product to be (a string or a list) and what should the function do when passed strings that don't divide evenly?
matrix2005in
« Reply #3 on: June 26, 2006, 10:47:06 PM »
A string only..but that must be divided equally...the input will be even number and number of strings will be predefined..eg:
input string: GHJLIETYHDWR =12(this will be predefined)
Output must be = GHJL IETY HDWR
thanks
mathew
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: June 27, 2006, 12:47:17 AM »
thanks
mathew
Hi Mathew
(defun str-trim-i (str i)
   (if (> (strlen str) 0)
      (cons (substr str 1 i) (str-trim-i (substr str (1+ i)) i))
   ) ;_  if
) ;_  defun
(str-trim-i  "GHJLIETYHDWR" 2)  ; ->> ("GH" "JL" "IE" "TY" "HD" "WR")
(str-trim-i  "GHJLIETYHDWR" 3)  ; ->> ("GHJ" "LIE" "TYH" "DWR")
(str-trim-i  "GHJLIETYHDWR" 4)  ; ->> ("GHJL" "IETY" "HDWR")
(str-trim-i  "GHJLIETYHDWR" 5)  ; ->> ("GHJLI" "ETYHD" "WR")
(str-trim-i  "GHJLIETYHDWR" 6)  ; ->> ("GHJLIE" "TYHDWR")
« Last Edit: June 27, 2006, 01:03:39 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: June 27, 2006, 01:11:29 AM »
Variant with string...  :-)
(defun str-trim-i>str (str i)
 (if (> (strlen str) i)
  (strcat (substr str 1 i) " " (str-trim-i>str (substr str (1+ i)) i))
  str
 ) ;_  if
) ;_  defun
(str-trim-i>str "GHJLIETYHDWR" 2) ;->> "GH JL IE TY HD WR"
(str-trim-i>str "GHJLIETYHDWR" 3) ;->> "GHJ LIE TYH DWR"
(str-trim-i>str "GHJLIETYHDWR" 4) ;->> "GHJL IETY HDWR"
(str-trim-i>str "GHJLIETYHDWR" 5) ;->> "GHJLI ETYHD WR"
(str-trim-i>str "GHJLIETYHDWR" 6) ;->> "GHJLIE TYHDWR"
Sdoman
« Reply #6 on: June 27, 2006, 08:15:18 AM »
(defun str-trim-i (str i) ...
Very elegant solutions, Elpanov!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: June 27, 2006, 08:42:53 AM »
Thank!  :-)
« Reply #8 on: June 27, 2006, 11:07:50 AM »
Very nice Evgeniy!
And for a non-recursive version:
(defun string-break (str brk@ / idx result tmp)
  (setq idx (- 1 brk@))
  (while (/= (setq tmp (substr str (setq idx (+ idx brk@)) brk@)) "")
    (if result
      (setq result (strcat result " " tmp))
      (setq result tmp)
  result
(defun string-break2 (str brk@ / idx result tmp)
    (if result
      (setq result (cons tmp result))
      (setq result (list tmp))
  (reverse result)
LE
« Reply #9 on: June 27, 2006, 12:20:50 PM »
(defun break_string  (txt cnt / string strings)
  (setq string (substr txt 1 cnt))
  (setq strings (cons string strings))
  (while (/= (setq txt (vl-string-left-trim string txt)) "")
    (if (/= (setq string (substr txt 1 cnt)) "")
      (setq strings (cons string strings))))
  (reverse strings))
(break_string "ABCDEFGHIJKLMNOPQRSTUVWXYZ" 3)
("ABC" "DEF" "GHI" "JKL" "MNO" "PQR" "STU" "VWX" "YZ")
matrix2005in
« Reply #10 on: July 01, 2006, 12:51:54 PM »
hi thanks that's gr8
another question..regarding looping....code given below is to strip off characters from a set of word..
(defun test ()
  (setq afg "GHJ5623JHG56")
  (setq drv (dos_strremove (strcat afg) "G"))
  (setq drv (dos_strremove (strcat DRV) "H"))
  (setq drv (dos_strremove (strcat drv) "J"))
actually variable afg wont be predefined like i mentioned here...afg will be include any letters that i dont know so i need to add all alphabet here...instead of repeating same code is there any other way to do this..looping or something??
« Reply #11 on: July 01, 2006, 06:51:18 PM »
It must be my Sunday morning brain fog ... but I cant determine your requirements.
Do you want the string stripped of ALL alpha characters, upper and lower case ???
... only returning numeric digits ?
.... OR ... ?
« Reply #12 on: July 01, 2006, 06:55:25 PM »
if ... only returning numeric digits ?
something like this may suit you ...
(DEFUN numsOnly (str /)
    (VL-LIST->STRING (VL-REMOVE-IF-NOT 'numchar-p (VL-STRING->LIST str)))
(DEFUN numchar-p (n) (AND (> n 47) (< n 58)))
(setq stripper (numsOnly afg))
;;=> "562356"
« Reply #13 on: July 01, 2006, 07:12:44 PM »
Kerry, if it's any consolation, that's what my Saturday afternoon brain thought was wanted as well.   :| I was waiting for the task to be clarified.......
« Reply #14 on: July 01, 2006, 08:06:43 PM »
Hi Jeff,
just checked my news/mail .. looks like Jon on the newsgroup read the same question another way ...
.. and gave a replacement functionality for dos_strremove.
so, yes, just goes to show.
I have always maintained that the question is more important than the answer. .. but perhaps thats my personal problem.
