Bryco,
I can't help you wiith that code, but if your problem is not there, then it won't matter.
Please do not forget to do the basics to remove all other outside variables and try to narrow it down while stepping through it. If it is failing, you should see that in design time. Something "should" give you a clue.
I would try a virgin machine and remove the call to a network printer and add a dedicated one on LPT1 instead and see if that works. I would not believe the order issue. That "should" not matter.
I can do some testing for you on a couple of diffent networks if you would like. Just let me know what info you need and make a arx, dll or dvb for 2002 and I would be more than happy to test anything I can for you. I have both, a dedicated canon on its own ip and shared out plotters.
Also, I see you have hp design jet in there. I remember having many issues with those old boxes, forget what they are called, that take the cat5 cable and turn it into a parallel port. You could have a faulty cable somewhere too, stc. Best to get your coded tested other places if it really being that bad.
Good luck
You can email or call me if you want a tester.
david@smartlister dot com
<phone number removed by MP>
