Author Topic: Better way to write this  (Read 9306 times)
David Hall
  • Automatic Duh Generator
« on: June 21, 2006, 02:35:28 PM »
I'm trying to compress my dvb files to make things simpler, and was wondering if anyone could compress this sub smaller.   This sub is replacing 6-8 other subs by using the Select Case.  If that doesn't make sense, I'll try and explain better.
Public Sub BATCHP(SIZE As String)
    Dim currentline As String
    Dim PLOTTYPE As String
    Open "c:\dwgnum.dat" For Input As 1
    While Not EOF(1)
        Line Input #1, currentline
        Documents.Open currentline
        Debug.Print currentline
        ThisDrawing.Regen acAllViewports
        Select Case SIZE
        Case "VA"
            Call SetupAndPlot("11x17Draft.pc3", "STANDARDS.ctb", "Business_Letter_(8.50_x_11.00_Inches)", ac1_1, ac0degrees)
            ThisDrawing.Plot.PlotToDevice
            ThisDrawing.Close (True)
        Case "V11"
            Call SetupAndPlot("11x17Draft.pc3", "11X17-CHECKSET.ctb", "ANSI_B_(11.00_x_17.00_Inches)", acScaleToFit, ac90degrees)
        Case "VC"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
        Case "VD"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
        Case "T11"
        Case "TC"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
        Case "TD"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
        Case Else
            Call Vendor1117
        End Select
    Wend
    Close 1
David Hall
Re: Better way to write this
« Reply #1 on: June 21, 2006, 02:36:14 PM »
here is the SetupAndPlot sub
Public Sub SetupAndPlot(ByRef Plotter As String, CTB As String, SIZE As String, PSCALE As String, ROT As String)
    Dim Layout As AcadLayout
    On Error GoTo Err_Control
    Set Layout = ThisDrawing.ActiveLayout
    Layout.RefreshPlotDeviceInfo
    Layout.ConfigName = Plotter    ' CALL PLOTTER
    Layout.PLOTTYPE = acExtents
    Layout.PlotRotation = ROT    ' CALL ROTATION
    Layout.StyleSheet = CTB    ' CALL CTB FILE
    Layout.PlotWithPlotStyles = True
    Layout.CanonicalMediaName = SIZE    ' CALL SIZE
    Layout.PaperUnits = acInches
    Layout.StandardScale = PSCALE    'CALL PSCALE
    Layout.ShowPlotStyles = False
    ThisDrawing.Plot.NumberOfCopies = 1
    Layout.CenterPlot = True
    Layout.ScaleLineweights = False
    ZoomExtents
    Set Layout = Nothing
    ThisDrawing.Save
Exit_Here:
    Exit Sub
Err_Control:
    Select Case Err.Number
    Case "-2145320861"
        MsgBox "Unable to Save Drawing- " & Err.Description
    Case "-2145386493"
        MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style"
    Case Else
        MsgBox "Unknown Error " & Err.Number
    End Select
David Hall
« Reply #2 on: June 21, 2006, 02:53:35 PM »
This is what i am replacing
Public Sub BATCHPLOT1824()
    While Not EOF(1)
        Call VendorQuickPlotC
    Wend
    Close 1
Public Sub BATCHPLOT2436()
    While Not EOF(1)
        ThisDrawing.MSpace = False
        Call VendorQuickPlotD
    Wend
    Close 1
Bob Wahr
« Reply #3 on: June 21, 2006, 04:09:50 PM »
It looks pretty streamlined to me.  You could move the plot and close to the SetupandPlot sub.  Then again, you can leave them.  Looks good.
Greg B
  • Tell me a Joke!
« Reply #4 on: June 21, 2006, 04:15:04 PM »
You sound like a weatherman.
[weatherman voice]It might rain today, then again it might not[/weatherman voice]
MickD
« Reply #5 on: June 21, 2006, 06:41:42 PM »
There is nothing really wrong with having seperate functions, in fact it's probably quicker as there are fewer tests (your switch statement contains many tests) where as a seperate function goes straight to the address offset of the function when called directly.
If you want to streamline your switch, put your cases in the most used order. i.e. if BATCHPLOT1824 is used most often, put it as your first switch, this way you exit your switch with lest tests more often.
To stream line your existing functions I see the same lines of code repeated in each -
(note: more as an example than a requirement for this particular code snippet)
    While Not EOF(1)
perhaps this could be put in its own sub and reduce it to one line in each working sub, this way each sub re-uses the same code (same address in memory which saves space).
This may not be applicable in all cases but you get the idea.
This is also why almost any app needs re-writng once you've finished the first version or beta :)
hth,
Mick.
- John Carmack
- J.R.R. Tolkien
Bryco
« Reply #6 on: June 21, 2006, 11:46:27 PM »
I don't know if this will work for you but I use goto a lot to try shorten my code.
    While Not EOF(1)
        Select Case SIZE
        Case "VA"
        Case "V11"
        Case "VC"
        Case "VD"
        Case "T11"
        Case "TC"
        Case "TD"
        Case Else
            Call Vendor1117
            GoTo skip
        End Select
skip:
    Wend
    Close 1
David Hall
« Reply #7 on: June 22, 2006, 10:16:40 AM »
Thanks Bryco, I didnt even see the last 2 lines I was repeating 8 times.  That shortened it up a lot.
David Hall
« Reply #8 on: June 22, 2006, 10:19:03 AM »
Thanks Mick!  You should have seen what a mess this was before I started compressing it into re-useable pieces.  Anyway, what you said made sense, so I will try and pull out the parts  where I can.
David Hall
« Reply #9 on: June 22, 2006, 10:44:10 AM »
So Mick,
what would you do with this list?
Public Sub VendorA()
Public Sub Vendor1117()
Public Sub VendorQuickPlotC()
Public Sub VendorQuickPlotD()
Public Sub TEPQuickPlot11x17()
Public Sub TEPQuickPlotC()
Public Sub TEPQuickPlotD()
Public Sub TEP9800D()
    Call SetupAndPlot("OCE 9800 DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
Public Sub TEPDWFD()    'Setups for C size and 11x17 do not exist, need to be created.
    Call SetupAndPlot("DWF6 ePlot.pc3", "tep.ctb", "ARCH_full_bleed_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
Public Sub VENDORDWFD()    'Setups for C size and 11x17 do not exist, need to be created.
    Call SetupAndPlot("DWF6 ePlot.pc3", "VENDOR MEDIUM.ctb", "ARCH_full_bleed_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
since they are all self contained, would you leave as is or try and compress?  All of these are in the same VBA module
Greg B
  • Tell me a Joke!
« Reply #10 on: June 22, 2006, 11:16:18 AM »
Can you create a plot and close sub?
David Hall
« Reply #11 on: June 22, 2006, 11:28:43 AM »
Im not sure I understand what you asking.
A close sub would look like
public sub DwgClose()
ThisDrawing.close true
end sub
Greg B
  • Tell me a Joke!
« Reply #12 on: June 22, 2006, 11:56:47 AM »
I just notice that each case has
Can't you use a sub to make it one line?
Public Sub PlotClose()
Then each case would be
Public Sub yabba()
  Call dabba
  PlotClose
You save a line of code.
David Hall
« Reply #13 on: June 22, 2006, 12:00:00 PM »
got ya! yes, that could and should be condensed.  In the example Bryco posted, they moved those two lines to the bottom after the select case.  In the example I just posted for Mick, those are all separate subs, so my question was should they stay separate for memory use or be combined.
Greg B
  • Tell me a Joke!
« Reply #14 on: June 22, 2006, 12:03:32 PM »
aH...got ya...
MickD
« Reply #15 on: June 22, 2006, 05:56:51 PM »
This can be a hard decision depending on implementation, if you are relying on random user input (i.e. they have a multiple choice like radio buttons or list box pick) a switch case with good ordering may be the only way to go but if you have buttons where the decision is 'direct', go directly to the sub without switch tests should be quicker.
As Greg said (is that THE Greg Blandin...coding!) and Bryco demonstrated you can still pick up some efficiency with some thought to 're-usable' code placement.
- John Carmack
- J.R.R. Tolkien
David Hall
« Reply #16 on: June 22, 2006, 06:03:24 PM »
is there a way to store a variable in the dwg (im thinking user??) to specify which ctb file should be saved with that dwg.  Then you could take out the random user input and go straight to the plot.  I know the ctb is stored in pagesetup, but as size changes, so does the ctb file.  Also, we get crap from vendors that use all kinds of colors, thus the vendor medium ctb file.
Bob Wahr
« Reply #17 on: June 22, 2006, 06:06:48 PM »
I'm thinking named page setups although we've had this conversation and I know you don't want to use them.
David Hall
« Reply #18 on: June 23, 2006, 09:54:26 AM »
Bob, what I need is a way to find out whether or not a drawing was done by us or an outside vendor.  That drives which ctb file to use.  My biggest problem is people using the wrong ctb file.  And dont even try to batch plot
David Hall
« Reply #19 on: June 23, 2006, 09:55:17 AM »
I'm thinking named page setups...
Could that name be extracted easily in my sub?  I need to test that
DaveW
« Reply #20 on: June 23, 2006, 10:28:05 AM »
Batch plt is a great utility.It took me a while to really get it down the way I wanted. Named pagesetups are big part of it. I use it to go to plt files, then use othercomputers that do not have ACAD to print them. I am going to follow this tread closely, as automating the process from VB sounds pretty good, but I do not know where to start either. :) When I see what you guys do, it amazes me that anything I do, coding wise, works at all.
Bob Wahr
« Reply #21 on: June 23, 2006, 10:59:59 AM »
Sub test()
Dim objPSet As AcadPlotConfiguration
Dim objPSets As AcadPlotConfigurations
Set objPSets = ThisDrawing.PlotConfigurations
For Each objPSet In objPSets
  Debug.Print objPSet.Name
Next objPSet
Bob Wahr
« Reply #22 on: June 23, 2006, 12:10:15 PM »
Here's a function that is a part of a pagesetup creation/replacement DVB that I was doing.  I shelved it for some reason, maybe it was a time issue, I'm not sure, then forgot all about it until now.  Maybe it will help
Function SNA11x17()
Dim objPS As AcadPlotConfiguration
  Set objPS = ThisDrawing.PlotConfigurations.Add("SNA-AZTU-11x17", False)
  objPS.ConfigName = "\\SERVER2\SAVIN 4035 PCL 6"
  objPS.CanonicalMediaName = "Tabloid"
  objPS.CenterPlot = True
  objPS.PaperUnits = acInches
  objPS.PlotHidden = False
  objPS.PlotRotation = ac90degrees
  objPS.PlotType = acExtents
  objPS.PlotViewportBorders = False
  objPS.PlotViewportsFirst = True
  objPS.PlotWithLineweights = True
  objPS.PlotWithPlotStyles = True
  objPS.ScaleLineweights = False
  objPS.ShowPlotStyles = False
  objPS.StandardScale = acScaleToFit
  objPS.StyleSheet = "SNA-11X17.ctb"
  objPS.UseStandardScale = True
End Function
Now I got's to finish this thing.
David Hall
« Reply #23 on: June 23, 2006, 02:16:04 PM »
thats a lot like mine
    ZoomExtents
    ThisDrawing.Save
Exit_Here:
    Exit Sub
Err_Control:
    Case "-2145320861"
    Case "-2145386493"
    Case Else
    End Select
Bob Wahr
« Reply #24 on: June 23, 2006, 02:23:48 PM »
true dat.  Mine's alphabeticalized though ;P
Bryco
« Reply #25 on: June 23, 2006, 07:45:41 PM »
I've been doing some set ups for metric and have once again failed completely to get the plotconfifs to work programmatically. It seems certain plotters wont behave. Some people have mentioned the order is important. I've switched stuff around all over the place to no avail. My code looks a lot like yours, I mean we are all setting the same things. But yours works. For a couple of years I have been using objectArx to open a template file and copy the plotconfigs which works perfectly but it's galling to not be able to do it the proper way.
Every setting is copied from a readout of a manually made plotconfig, so unless the plot origin requires umpteen decimal places they should all be kosher.
If you can see something wrong I'ld appreciate the tip.
Sub PcsMM()
    Dim pC As AcadPlotConfiguration
    Dim PCs As AcadPlotConfigurations
    Dim oLayout As AcadLayout
    Dim oLayouts As AcadLayouts
    Dim PlotOrig(1) As Double
    Dim Orig
    Set oLayouts = ThisDrawing.Layouts
    Set PCs = ThisDrawing.PlotConfigurations
    Set oLayout = ThisDrawing.PaperSpace.Layout
    PlotOrig(0) = 18.542: PlotOrig(1) = 12.192
    Set pC = PCs.Add("22x34final", False)
    With pC
        .CanonicalMediaName = "User1639"
        .CenterPlot = True
        .ConfigName = "\\DESIGNSERVER\HPDJ"
        .PlotOrigin = PlotOrig
        .PlotRotation = ac180degrees
        .StandardScale = ac1_1
    End With
    PcTyp pC
    oLayout.CopyFrom pC
    PlotOrig(0) = 19.01: PlotOrig(1) = 12.68
    Set pC = PCs.Add("22x34draft", False)
    With pC
        .PlotType = acLayout
        .ConfigName = "\\DESIGNSERVER\HPDRAFT"
        .PaperUnits = acMillimeters
    End With
    PcTyp pC
    oLayout.CopyFrom pC
    PlotOrig(0) = 1.31: PlotOrig(1) = 4.48
    Set pC = PCs.Add("11x17half", False)
    With pC
        .CenterPlot = True
        .ConfigName = "\\designserver\KONICA"
        .PlotRotation = ac270degrees
        .StandardScale = ac1_2
        '.CanonicalMediaName = "User288"
    End With
    PcTyp pC
'ModelSpace
    Set oLayout = ThisDrawing.ModelSpace.Layout
    Set pC = PCs.Add("22x34-model", True)
    With pC
    End With
    PCAdds pC
    Set pC = PCs.Add("22x34draft-model", True)
    With pC
    End With
    PcTyp pC
    Set pC = PCs.Add("11x17-model", True)
    Orig = ThisDrawing.GetVariable("Viewctr")
    PlotOrig(0) = Orig(0): PlotOrig(1) = Orig(1)
    With pC
        '.SetCustomScale 1, 1
        '.PlotType = acExtents
        .CenterPlot = True
    End With
    PcTyp pC
    oLayout.CopyFrom pC
'Pc.RefreshPlotDeviceInfo
ThisDrawing.Regen 0
Function PcTyp(pC As AcadPlotConfiguration)
    With pC
        .PlotHidden = False
        .StyleSheet = "Lexington Standard.ctb"
    End With
End Function
I'm also not sure of the logic of  using extents rather than layout. But that didn't work either.
« Last Edit: June 23, 2006, 07:48:56 PM by Bryco »
Bob Wahr
« Reply #26 on: June 23, 2006, 07:55:12 PM »
Bryco, at a quick glance, I don't see anything.  I'll look some more but not until Monday.
DaveW
« Reply #27 on: June 23, 2006, 09:02:36 PM »
Bryco,
I can't help you wiith that code, but if your problem is not there, then it won't matter.
Please do not forget to do the basics to remove all other outside variables and try to narrow it down while stepping through it. If it is failing, you should see that in design time. Something "should" give you a clue.
I would try a virgin machine and remove the call to a network printer and add a dedicated one on LPT1 instead and see if that works. I would not believe the order issue. That "should" not matter.
I can do some testing for you on a couple of diffent networks if you would like. Just let me know what info you need and make a arx, dll or dvb for 2002 and I would be more than happy to test anything I can for you. I have both, a dedicated canon on its own ip and shared out plotters.
Also, I see you have hp design jet in there. I remember having many issues with those old boxes, forget what they are called, that take the cat5 cable and turn it into a parallel port. You could have a faulty cable somewhere too, stc. Best to get your coded tested other places if it really being that bad.
Good luck
You can email or call me if you want a tester.
david@smartlister dot com
<phone number removed by MP>
« Last Edit: June 26, 2006, 12:35:44 PM by MP »
