Author Topic: Better way to write this  (Read 9307 times)
David Hall
  • Automatic Duh Generator
« on: June 21, 2006, 02:35:28 PM »
I'm trying to compress my dvb files to make things simpler, and was wondering if anyone could compress this sub smaller.   This sub is replacing 6-8 other subs by using the Select Case.  If that doesn't make sense, I'll try and explain better.
Public Sub BATCHP(SIZE As String)
    Dim currentline As String
    Dim PLOTTYPE As String
    Open "c:\dwgnum.dat" For Input As 1
    While Not EOF(1)
        Line Input #1, currentline
        Documents.Open currentline
        Debug.Print currentline
        ThisDrawing.Regen acAllViewports
        Select Case SIZE
        Case "VA"
            Call SetupAndPlot("11x17Draft.pc3", "STANDARDS.ctb", "Business_Letter_(8.50_x_11.00_Inches)", ac1_1, ac0degrees)
            ThisDrawing.Plot.PlotToDevice
            ThisDrawing.Close (True)
        Case "V11"
            Call SetupAndPlot("11x17Draft.pc3", "11X17-CHECKSET.ctb", "ANSI_B_(11.00_x_17.00_Inches)", acScaleToFit, ac90degrees)
        Case "VC"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
        Case "VD"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
        Case "T11"
        Case "TC"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
        Case "TD"
            Call SetupAndPlot("OCE DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
        Case Else
            Call Vendor1117
        End Select
    Wend
    Close 1
End Sub
David Hall
Re: Better way to write this
« Reply #1 on: June 21, 2006, 02:36:14 PM »
here is the SetupAndPlot sub
Public Sub SetupAndPlot(ByRef Plotter As String, CTB As String, SIZE As String, PSCALE As String, ROT As String)
    Dim Layout As AcadLayout
    On Error GoTo Err_Control
    Set Layout = ThisDrawing.ActiveLayout
    Layout.RefreshPlotDeviceInfo
    Layout.ConfigName = Plotter    ' CALL PLOTTER
    Layout.PLOTTYPE = acExtents
    Layout.PlotRotation = ROT    ' CALL ROTATION
    Layout.StyleSheet = CTB    ' CALL CTB FILE
    Layout.PlotWithPlotStyles = True
    Layout.CanonicalMediaName = SIZE    ' CALL SIZE
    Layout.PaperUnits = acInches
    Layout.StandardScale = PSCALE    'CALL PSCALE
    Layout.ShowPlotStyles = False
    ThisDrawing.Plot.NumberOfCopies = 1
    Layout.CenterPlot = True
    Layout.ScaleLineweights = False
    ZoomExtents
    Set Layout = Nothing
    ThisDrawing.Save
Exit_Here:
    Exit Sub
Err_Control:
    Select Case Err.Number
    Case "-2145320861"
        MsgBox "Unable to Save Drawing- " & Err.Description
    Case "-2145386493"
        MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style"
    Case Else
        MsgBox "Unknown Error " & Err.Number
    End Select
End Sub
David Hall
« Reply #2 on: June 21, 2006, 02:53:35 PM »
This is what i am replacing
Public Sub BATCHPLOT1824()
    While Not EOF(1)
        Call VendorQuickPlotC
    Wend
    Close 1
End Sub
Public Sub BATCHPLOT2436()
    While Not EOF(1)
        ThisDrawing.MSpace = False
        Call VendorQuickPlotD
    Wend
    Close 1
End Sub
Bob Wahr
« Reply #3 on: June 21, 2006, 04:09:50 PM »
It looks pretty streamlined to me.  You could move the plot and close to the SetupandPlot sub.  Then again, you can leave them.  Looks good.
Greg B
  • Tell me a Joke!
« Reply #4 on: June 21, 2006, 04:15:04 PM »
You sound like a weatherman.
[weatherman voice]It might rain today, then again it might not[/weatherman voice]
MickD
« Reply #5 on: June 21, 2006, 06:41:42 PM »
There is nothing really wrong with having seperate functions, in fact it's probably quicker as there are fewer tests (your switch statement contains many tests) where as a seperate function goes straight to the address offset of the function when called directly.
If you want to streamline your switch, put your cases in the most used order. i.e. if BATCHPLOT1824 is used most often, put it as your first switch, this way you exit your switch with lest tests more often.
To stream line your existing functions I see the same lines of code repeated in each -
(note: more as an example than a requirement for this particular code snippet)
    While Not EOF(1)
perhaps this could be put in its own sub and reduce it to one line in each working sub, this way each sub re-uses the same code (same address in memory which saves space).
This may not be applicable in all cases but you get the idea.
This is also why almost any app needs re-writng once you've finished the first version or beta :)
hth,
Mick.
- John Carmack
- J.R.R. Tolkien
Bryco
« Reply #6 on: June 21, 2006, 11:46:27 PM »
I don't know if this will work for you but I use goto a lot to try shorten my code.
    While Not EOF(1)
        Select Case SIZE
        Case "VA"
        Case "V11"
        Case "VC"
        Case "VD"
        Case "T11"
        Case "TC"
        Case "TD"
        Case Else
            Call Vendor1117
            GoTo skip
        End Select
skip:
    Wend
    Close 1
End Sub
David Hall
« Reply #7 on: June 22, 2006, 10:16:40 AM »
Thanks Bryco, I didnt even see the last 2 lines I was repeating 8 times.  That shortened it up a lot.
David Hall
« Reply #8 on: June 22, 2006, 10:19:03 AM »
Thanks Mick!  You should have seen what a mess this was before I started compressing it into re-useable pieces.  Anyway, what you said made sense, so I will try and pull out the parts  where I can.
David Hall
« Reply #9 on: June 22, 2006, 10:44:10 AM »
So Mick,
what would you do with this list?
Public Sub VendorA()
End Sub
Public Sub Vendor1117()
End Sub
Public Sub VendorQuickPlotC()
End Sub
Public Sub VendorQuickPlotD()
End Sub
Public Sub TEPQuickPlot11x17()
End Sub
Public Sub TEPQuickPlotC()
End Sub
Public Sub TEPQuickPlotD()
End Sub
Public Sub TEP9800D()
    Call SetupAndPlot("OCE 9800 DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
End Sub
Public Sub TEPDWFD()    'Setups for C size and 11x17 do not exist, need to be created.
    Call SetupAndPlot("DWF6 ePlot.pc3", "tep.ctb", "ARCH_full_bleed_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
End Sub
Public Sub VENDORDWFD()    'Setups for C size and 11x17 do not exist, need to be created.
    Call SetupAndPlot("DWF6 ePlot.pc3", "VENDOR MEDIUM.ctb", "ARCH_full_bleed_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
since they are all self contained, would you leave as is or try and compress?  All of these are in the same VBA module
Greg B
  • Tell me a Joke!
« Reply #10 on: June 22, 2006, 11:16:18 AM »
Can you create a plot and close sub?
David Hall
« Reply #11 on: June 22, 2006, 11:28:43 AM »
Im not sure I understand what you asking.
A close sub would look like
public sub DwgClose()
ThisDrawing.close true
end sub
Greg B
  • Tell me a Joke!
« Reply #12 on: June 22, 2006, 11:56:47 AM »
I just notice that each case has
Can't you use a sub to make it one line?
Public Sub PlotClose()
End Sub
Then each case would be
Public Sub yabba()
  Call dabba
  PlotClose
End Sub
You save a line of code.
David Hall
« Reply #13 on: June 22, 2006, 12:00:00 PM »
got ya! yes, that could and should be condensed.  In the example Bryco posted, they moved those two lines to the bottom after the select case.  In the example I just posted for Mick, those are all separate subs, so my question was should they stay separate for memory use or be combined.
Greg B
  • Tell me a Joke!
« Reply #14 on: June 22, 2006, 12:03:32 PM »
aH...got ya...
