Author Topic: block insertion with attribute..  (Read 1708 times)
Andrea
« on: June 19, 2006, 05:13:21 PM »
Hi all,
I have a block with an attribute...
But i'm trying to insert this block and show an alert when the block is inserted..
I mean...after entering the attribute..
for the moment i have this.....
(command "_.-insert" CBF CBpick CBscale "" pause)
  (while (eq (getvar "CMDACTIVE") 0))
  (alert "1")
But the alert comes BEFORE entering the attribute..
any idea how ?
Keep smile...
Re: block insertion with attribute..
« Reply #1 on: June 19, 2006, 05:23:53 PM »
Like so?
  (setvar "attreq" 1)
  (setvar "attdia" 1)
  (setvar "cmdecho" 1)
(command "_.-insert" CBF CBpick CBscale "")
  (while (/= 0 (getvar "cmdactive"))
    (command pause)
  (alert "Attributes are done....")
Andrea
« Reply #2 on: June 19, 2006, 05:51:52 PM »
thanks Jeff....it work.. 8-)
I forgot the attreq variable.. ^-^
Keep smile...
