Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
dwf in .Net
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: dwf in .Net (Read 2261 times)
CmdrDuh
Automatic Duh Generator
King Gator
dwf in .Net
on:
June 15, 2006, 04:13:39 PM »
Does anyone know what files are needed to access the dwf stuff for autocad in .Net? Im trying to write an app that will allow you to batch print DWF's
Logged
They say money can't buy happiness, but it can buy Bacon and that's a close second
MikePerry
Guest
Re: dwf in .Net
Reply #1 on:
June 16, 2006, 09:54:50 AM »
Hi
Does any of the following help...
DWF Toolkit 7.2.1 Now Available
DWF Toolkit 7.2 Handles All DWF files
Autodesk Web Site URLs for DWF
Have a good one, Mike
Logged
CmdrDuh
King Gator
Re: dwf in .Net
Reply #2 on:
June 16, 2006, 11:07:35 AM »
ok, question, I'm using C#. the source files are C++. can I use them at all?
I guess the reason I ask is I thought the new thing with dot net was the ability to use different programming languages in your program. Am I way off base?
Last Edit: June 16, 2006, 11:11:02 AM by CmdrDuh
Logged
MickD
Gator
(x-in)->[process]->(y-out)
WWW
Re: dwf in .Net
Reply #3 on:
June 16, 2006, 07:33:10 PM »
I have no idea about dwf but if you have an api and some samples in C++ you can do this using DllImport to use the exported functions of the api.
Logged
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
WWW
Re: dwf in .Net
Reply #4 on:
June 16, 2006, 09:15:00 PM »
Can't help with DWF yet David.
Mark <the Man here> asked me yesterday to put it on my list ... so perhaps you will have it sorted out by the time I'm free to look.
Logged
--> Donate to theSwamp<--
Draftek
Water Moccasin
Re: dwf in .Net
Reply #5 on:
June 19, 2006, 08:12:51 AM »
David,
You should check out plotting, the dwf issue will merely be a driver selection for autocad.
Logged
Soli Deo Gloria
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
dwf in .Net
