Author Topic: Managed HotKeys  (Read 54341 times)
Re: Managed HotKeys
« Reply #150 on: August 24, 2013, 06:53:10 AM »
I isolated the cause of the issue to the new command line technology used in 2013.
Discussions with ADN were unable to resolve the issue. I put the build aside and haven't looked at it since.
Quote from: me
I get AutoCAD crashes when I use Ctrl-V, Ctrl-C etc  when either the Command line or VLIDE have focus.
This does not happened prior to 2013.
