Author Topic: Managed HotKeys  (Read 54668 times)
Re: Managed HotKeys
« Reply #90 on: June 28, 2010, 07:37:09 PM »
Hi Daniel
I think this is the latest
http://www.theswamp.org/index.php?topic=31924.msg374004#msg374004
I haven't made time to look at it.
There were no exceptions thrown though ...
Re: Managed HotKeys
« Reply #91 on: June 28, 2010, 07:40:39 PM »
May be an idea to add something like this to the Initialize()  and the  keysOn() ,  keysOff() <- with 'unloaded' message
                docMan.MdiActiveDocument.Editor.WriteMessage(
                        "\nHotkeys_2010/11 are loaded.\n Commands : KeysOn, KeysOff, KeysToggle, KeysConfig, EditKeys");
Re: Managed HotKeys
« Reply #92 on: June 28, 2010, 09:16:20 PM »
Try this one
Re: Managed HotKeys
« Reply #93 on: June 28, 2010, 09:50:08 PM »
Thanks Dan
eFilerError
   at
Autodesk.AutoCAD.DatabaseServices.ImpHostApplicationServices.FindFile(String
fileName, Database database, FindFileHint hint)
   at HotKeys.KeysFile.locateKeysFile()
   at HotKeys.AppRegistry.initialize()
   at HotKeys.Main.Initialize()
Re: Managed HotKeys
« Reply #94 on: June 28, 2010, 10:04:43 PM »
Great!
We should probable put this in a FAQ somewhere, if you use IExtensionApplication, add a try catch
   public void Initialize()
      try
       //todo
      catch (System.Exception ex)
        Autodesk.AutoCAD.ApplicationServices.Application.
          DocumentManager.MdiActiveDocument.Editor.
          WriteMessage("\n{0}\n{1}", ex.Message, ex.StackTrace);
Re: Managed HotKeys
« Reply #95 on: June 28, 2010, 10:05:16 PM »
Looks like the Registry entrys are not being made.
I thought the initial initialize added the entrys if they didn't exist ...
This is the reg after running the netload ..
[added]
and the same under
HKEY_CURRENT_USER\Software\ManagedHotKeys
HKEY_USERS\S-1-5-21-1614435629-549356334-4198987207-1000\Software\ManagedHotKeys
« Last Edit: June 28, 2010, 10:12:18 PM by Kerry Brown »
Re: Managed HotKeys
« Reply #96 on: June 28, 2010, 10:07:56 PM »
Great!
      try
       //todo
Great idea
If you like I'll add a reference into the 'Getting Started' Series.
Re: Managed HotKeys
« Reply #97 on: June 28, 2010, 10:11:34 PM »
where is your xml file?
look under HKEY_CURRENT_USER\Software\ManagedHotKeys
Re: Managed HotKeys
« Reply #98 on: June 28, 2010, 10:15:34 PM »
No entry
as posted in piccy.
Re: Managed HotKeys
« Reply #99 on: June 28, 2010, 10:16:04 PM »
From the looks of it, the XML file must be in a search path, or in My documents.. where is yours?
Re: Managed HotKeys
« Reply #100 on: June 28, 2010, 10:19:01 PM »
In the same folder as the .DLL  ... NOT on the Search Path
both the default xml and my personal renamed modified xml.
What are your thoughts on this ??
Personally I'd rather not need to modify the Search path.
Re: Managed HotKeys
« Reply #101 on: June 28, 2010, 10:32:01 PM »
quick fix, put a file called HotKeys.xml in my documents.
launch Acad and load dll.
use the keysconfig command to locate your personal xml
this should save the setting in the reg.
Re: Managed HotKeys
« Reply #102 on: June 28, 2010, 10:38:53 PM »
Just came back to say I'd done exactly that ... and it worked fine.
I'll look at the options when I get a chance ... unless someone beats me to it.
Thanks Dan
Regards
Re: Managed HotKeys
« Reply #103 on: June 28, 2010, 10:40:00 PM »
@ Chuck -- Rule #1749-5 of the programmers handbook, always test your code on a virgin machine   :lol:
Re: Managed HotKeys
« Reply #104 on: June 28, 2010, 10:42:46 PM »
Just as a note for later
the
 (int)AppDomain.GetCurrentThreadId());
is depricated.
[added]
Also for later ..
perhaps a .NET editor for the XML files to replace the current VB6 editor.
« Last Edit: June 28, 2010, 10:52:50 PM by Kerry Brown »
