Author Topic: Managed HotKeys  (Read 10059 times)
Jeff H
Re: Managed HotKeys
« Reply #135 on: June 08, 2012, 11:47:48 pm »
Sounds like it's time to pull my finger out and re-write the editor as well ... perhaps it's a good excuse for a full re-write.
Kerry if you do a re-write would you use the Application.PreTranslateMessage event or would that work here?
They show this as correct way here but seemed as easy here
  • Mesozoic Relic
Re: Managed HotKeys
« Reply #136 on: June 09, 2012, 02:42:41 am »
I hadn't really thought it through Jeff.
I really wanted to do without the hoops needed to write the alias file ... looking for a way that wouldn't require so much translation.
... I need to cross one creek at a time though :)
Discipline : absolutely none at all.
--> Donate to TheSwamp <--
BlackBox
Re: Managed HotKeys
« Reply #137 on: June 09, 2012, 11:24:53 am »
Thanks for the reminder, Jeff - I got so busy with work that I neglected to pick that task back up (the 2nd link). Also, thanks for the DevBlog link as well.   :-)
"Potential has a shelf life." - Margaret Atwood
Tom
Re: Managed HotKeys
« Reply #138 on: June 28, 2012, 04:08:29 pm »
"Has anyone done a compile for 2013 they can post?" Bump
  • Mesozoic Relic
Re: Managed HotKeys
« Reply #139 on: June 28, 2012, 10:36:20 pm »
Tom,
I've built it and had it running but my 2013 has issues and I haven't finished testing.
I'll rebuild it on my laptop over the weekend and try to finish testing.
Regards
BlackBox
Re: Managed HotKeys
« Reply #140 on: June 29, 2012, 07:48:10 am »
Kerry -
Only because you mentioned having 2013 'working', would you by chance have the 2010 build available for those of us stuck back with 2010-2012 apps?  :angel:
  • Mesozoic Relic
Re: Managed HotKeys
« Reply #141 on: June 29, 2012, 09:36:01 am »
Kerry -
Here we go !
http://www.theswamp.org/index.php?topic=10570.msg409779#msg409779
and to play with:
« Last Edit: June 29, 2012, 09:45:24 am by Kerry »
BlackBox
Re: Managed HotKeys
« Reply #142 on: June 29, 2012, 10:48:18 am »
That build doesn't work... That's why I asked again. :wink:
** Edit - Just saw that you added some attachments... Off to play. :lol:
BlackBox
Re: Managed HotKeys
« Reply #143 on: June 29, 2012, 11:10:01 am »
... Same as before. It's not working.  :|
Civil 3D 2011, 2012.
  • Mesozoic Relic
Re: Managed HotKeys
« Reply #144 on: June 29, 2012, 06:23:31 pm »
I don't have Civil to test against.
That version is the same build date  I'm using sucessfully for AC2012 Vanilla.
Tom
Re: Managed HotKeys
« Reply #145 on: July 26, 2012, 04:19:08 pm »
CADDee
  • Mosquito
Re: Managed HotKeys
« Reply #146 on: October 25, 2012, 09:16:35 am »
Kerry,
I tracked down Chuck Gabriel and he informed that you are now the keeper of the most useful tool ever written for AutoCAD.
I'm finally getting around to upgrading to 2013, and I realized that Hotkeys is broken again.
So all of my desperate measures have lead me to this post, where I can see others are asking for an update too.
Did you ever get the Hotkeys.dll to load without errors and can you please share?
Thank you in advance!
Jim Dee
