Author Topic: zoom problems  (Read 3903 times)
diarmuid
zoom problems
« on: March 11, 2004, 07:57:00 AM »
when using acad 2002, in paper space, when i zoom the model (lets call it plan01) it zooms  with me.  i.e.  when i zoom into the drawing, still in paperspace and NOT in floating paperspace either,  i zoom into the sheet the plan fills the screen and zooms in "with me".
also if i pan using the middle button, the view "try's" to stay on the screen and will get smaller so it can.
also the ucsicon (the 3 colour 3d ucs icon) is displayed even though i am in paper space.  the paper space the right angle triangle one is also still displayed.
this is really confusing
any help would be greatly appreciated
thanks in advance
Diarmuid
If you want to win something run the 100m, if you want to experience something run a marathon
42
zoom problems
« Reply #1 on: March 11, 2004, 08:02:20 AM »
It is likly that you have the viewport locked, right click on the viewport and uncheck the "lock viewport"
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
zoom problems
« Reply #2 on: March 11, 2004, 08:23:02 AM »
You have shading turned on in the offending viewport. Set modelspace in the offending viewport, then set shademode to 2d wireframe.
42
zoom problems
« Reply #3 on: March 11, 2004, 08:28:51 AM »
Opps I did not read all of your post, I concur with Keith on the second answer.
Technical Director
diarmuid
zoom problems
« Reply #4 on: March 11, 2004, 09:33:53 AM »
perfect
thanks very much
this has made look very smart indeed.
cheers guys
Diarmuid
ELOQUINTET
zoom problems
« Reply #5 on: March 11, 2004, 09:34:15 AM »
i'm not totally clear on what's happening but i've read about crazy zoom instances when the UCSFOLLOW variable is changed. could this be it guys dunno?
42
zoom problems
« Reply #6 on: March 11, 2004, 10:21:59 AM »
No. What UCS follow does is set the plan view for a viewport. When you set ucsfollow to 1 in YP 1 it will always switch to plan view when you change the ucs in any other VP.
Technical Director
