Author Topic: Find pline intersections?  (Read 3676 times)
matrix2005in
« on: June 13, 2006, 01:16:30 PM »
yoyo that's gr8  8-)
i was wasted my time for that line.......actually i am just a beginner so no idea about that kinda syntax...well thanks jeff..
ok here is another question...
how can i find self intersection of a polyline..and i would like to put a point on that intersection.
if it has 1 or more then it should put points on all intersections...is it possible??
Re: How to find vertex number
« Reply #1 on: June 13, 2006, 03:10:03 PM »
How about this.....note that it will not catch an intersection if that intersection lies EXACTLY on a vertex.....and I used a circle instead of a POINT......
(defun c:circleints (/ coords coordsz doc idx intlist ints pline space ss z lyr layname circ)
  (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
      (setq idx -1
    coordsZ nil
    intList nil
    doc (vla-get-activedocument (vlax-get-acad-object))
    space (if (= (getvar "cvport") 1)
    (vla-get-paperspace doc)
    (vla-get-modelspace doc)
    layname "CircleLayer" ;;use your Layer name
      (setq lyr (vla-add (vla-get-layers doc) layname))
      (vla-put-color lyr 1);;make this whatever color you want, 1 is red
      (while (setq pline (ssname ss (setq idx (1+ idx))))
(setq pline (vlax-ename->vla-object pline))
(setq ints (vlax-invoke pline 'intersectwith pline acextendnone))
(setq coords (vlax-get pline 'coordinates))
(setq z (vla-get-elevation pline))
(while coords
  (setq coordsZ (cons (list (car coords) (cadr coords) z) coordsZ))
  (setq coords (cddr coords))
(while ints
  (setq intList (cons (list (car ints) (cadr ints) (caddr ints)) intList))
  (setq ints (cdddr ints))
(foreach x coordsZ
  (setq intlist (vl-remove-if '(lambda (y)
(equal x y 0.0001)
  intList)
(mapcar '(lambda (x)
   (setq circ (vlax-invoke space 'addcircle x 2.0));;you can adjust the Radius by changing the 2.0 here
   (vla-put-layer circ layname)
intlist)
EDIT - modified code for the circles layer
« Last Edit: June 15, 2006, 04:17:00 PM by Jeff_M »
LE
« Reply #2 on: June 13, 2006, 04:04:43 PM »
Just a little comment, and basically for the newbies, is there a chance to open a new thread for each change from the original topic or it is required to be in the same thread?
Hope that helps.
« Reply #3 on: June 13, 2006, 04:35:08 PM »
Good point Luis!
Re: Find pline intersections?
« Reply #4 on: June 13, 2006, 06:44:06 PM »
Thanks for the 'Heads Up' Luis.
I split the thread for the readers.
As for the posters it did read like a rambling conversation about plines & lisp.
Hope the split did not leave anyone high & dry. :-)
matrix2005in
« Reply #5 on: June 14, 2006, 12:37:00 PM »
hi jeff
gr8 stuff..... :-)
well ...if we can put that circles in given layer... 8-)
thanks
mathew
matrix2005in
« Reply #6 on: June 14, 2006, 12:38:54 PM »
thank you CAB for starting a new topic
« Reply #7 on: June 15, 2006, 12:14:24 PM »
gr8 stuff..... :-)
Thanks and you're welcome!
Here's some code snips to be strategically placed into the code above:
To place the circle on a specific layer, first make sure the layer is there for our use...
);;end of initial setq's
(setq lyr (vla-add (vla-get-layers doc) "CircleLayer"));;use your Layer name
(while (setq pline .......
Then, where each circle is created by this: (vlax-invoke space 'addcircle x 2.0)
change it to this:
(vla-put-layer circ (vla-get-name lyr));;make sure to use the same name here
Also, make sure to add the variables lyr & circ to the Local declarations at the beginning
matrix2005in
« Reply #8 on: June 15, 2006, 02:02:26 PM »
hi jef
i am not sure ...but i am getting error
; error: bad argument type: VLA-OBJECT nil
i am not sure where i am mistaken :-(
mathew
« Reply #9 on: June 15, 2006, 04:11:28 PM »
Well, that means you are probably inserting the code into the incorrect spot....I'll update the code above in a few minutes.
matrix2005in
« Reply #10 on: June 16, 2006, 12:33:45 PM »
hi jeff
i am waiting  :roll:
« Reply #11 on: June 16, 2006, 12:55:42 PM »
hi jeff
i am waiting  :roll:
For what? As I said I'd do, I modified the code above...note the edit time at the bottom of that post.......
matrix2005in
« Reply #12 on: June 16, 2006, 02:14:18 PM »
hi jeff
thanks man very good...yeah i wasn't aware that you modified the above one...
thanks again :kewl:
