Author Topic: Folder Browsing in .Net  (Read 3806 times)
MickD
« on: June 02, 2006, 02:43:32 AM »
I couldn't believe it, I couldn't find a folder browser in the .net framework!!
There is the OpenFile and SaveFile dialogs, why not this one?!?
Anyway, if you do any development in .net you will be sure to need this sooner or later, it took me a while to find a decent resource so here it is -
http://www.netomatix.com/FolderBrowser.aspx
Enjoy,
Mick.
- John Carmack
- J.R.R. Tolkien
Re: Folder Browsing in .Net
« Reply #1 on: June 02, 2006, 03:43:39 AM »
ta Mick !
Glenn R
« Reply #2 on: June 02, 2006, 08:02:11 AM »
You're kidding right?
Visual Studio .Net 2003:
System.Windows.Forms.FolderBrowserDialog dlg = new System.Windows.Forms.FolderBrowserDialog();
If memory serves, this what not available in .NET 1.0, but was introduced in .NET 1.1.
Cheers,
Glenn.
MickD
« Reply #3 on: June 04, 2006, 06:03:15 PM »
Well there you go, I'm still using 2002. :oops:
I started looking for an answer to this and I came up with a plethora of work arounds so I figured that was that.
Seems like time to upgrade VS.
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #4 on: June 04, 2006, 07:39:27 PM »
Seriously Mick, go for 2005 - I think you will like it a LOT!
Cheers,
Glenn.
