Author Topic: A time to use 'Send Command' ?  (Read 9344 times)
MickD
Re: A time to use 'Send Command' ?
« Reply #15 on: June 07, 2006, 01:02:34 AM »
Adding to what Glenn is saying -
 a snippet from the ARX api help on sendStringToExecute() -
....The new document will be locked according to the new command's lock level as specified during its registration.
Which all makes sense really :)
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #16 on: June 07, 2006, 02:33:58 AM »
All sort of goes together really doesn't it? ;)
Glenn R
« Reply #17 on: June 07, 2006, 02:37:12 AM »
Actually, this reminds me of an application I was involved with that was built by Autodesk for Telstra.
It had a custom palette with a tree of commands that was loaded from an XML file and once a tree item was hit, it was sending a command string with answers to the prompts...custom commands defined by the arx.
MickD
« Reply #18 on: July 05, 2006, 11:03:58 PM »
I just discovered another reason you might want to use SendStringToExecute() behind your controls, if your last 'command' proper was undo, you lose all of your previous work!
Although a quick redo will fix it, it is annoying.
- John Carmack
- J.R.R. Tolkien
