Author Topic: Hierarchical print ...  (Read 19980 times)
« on: June 01, 2006, 11:21:02 PM »
I needed a quick function today to print a list's hierarchy (data in native format; i.e. prin1) so I could discern a deeply nested structure. I wrote it quick and dirty and it surely could be optimized (example don't calculate (chr 40|41) each call, use foreach instead of mapcar ... ). You're welcome | invited to do so if you're inclined but it's been a long day for me so I'm opting out.
Without further blather --
(defun Prinh ( x / _PrintItem _PrintList _Main )
    (defun _PrintItem ( _PrintMethod item indents )
        (princ "\n")
        (repeat indents (princ "    "))
        (_PrintMethod item)
    (defun _PrintList ( _PrintMethod lst indents )
        (_PrintItem _PrintMethod (chr 40) indents)
        (mapcar '(lambda (x) (_Main x (1+ indents))) lst)
        (_PrintItem _PrintMethod (chr 41) indents)
    (defun _Main ( x indents )
        (if (vl-consp x)
            (if ((lambda (x) (and x (atom x))) (cdr x))
                (_PrintItem prin1 x indents)
                (_PrintList princ x indents)
    (_Main x 0)
Examples --
;;  print a non list item
(prinh pi)
3.14159
;;  print a simple flat list --
(prinh '(0 1 2))
    0
    1
    2
;;  print a nested list --
(prinh '(0 (1 (2 (3 (4 (5 (6 (7)))))))))
    0
        1
            2
                3
                    4
                        5
                            6
                                7
fwiw; cheers.
FengK
Re: Hierarchical print ...
« Reply #1 on: June 02, 2006, 02:13:39 AM »
Interesting, MP.  I'm trying to picture when I'll need something like this.  Thanks.
« Reply #2 on: June 02, 2006, 06:55:53 AM »
One example could be entity data, in particular when xdata, xdictionaries or xrecords are involved.
Here's a simple example using a viewport with frozen layers (cut down a bit in the interests of brevity) --
(defun c:ListH ( / ename )
    (if (setq ename (car (entsel)))
        (prinh (entget ename '("*")))
    (-1 . <Entity name: 7ef84f98>)
    (0 . "VIEWPORT")
    (330 . <Entity name: 7ef84d40>)
    (5 . "AB")
    (100 . "AcDbEntity")
    (67 . 1)
    (410 . "Layout1")
    (8 . "0")
    (100 . "AcDbViewport")
        10
        2.72966
        2.78451
        0.0
    (40 . 2.35338)
    (72 . 1000)
    (331 . <Entity name: 7ef84c80>)
    (331 . <Entity name: 7ef88090>)
    (331 . <Entity name: 7ef88098>)
    (170 . 0)
        -3
            "ACAD"
            (1000 . "MVIEW")
            (1002 . "{")
            (1070 . 16)
                1010
                0.0
                0.0
                0.0
            (1070 . 0)
            (1002 . "{")
            (1003 . "Lions")
            (1003 . "Tigers")
            (1003 . "And")
            (1003 . "Bears")
            (1003 . "Oh")
            (1003 . "My!")
            (1002 . "}")
            (1002 . "}")
Sdoman
« Reply #3 on: June 02, 2006, 08:10:11 AM »
Interesting code MP.  Makes me think about a having a routine to pretty print a lisp file.
« Reply #4 on: June 02, 2006, 08:18:19 AM »
(defun-q Prinh ( x / _PrintItem _PrintList _Main )
        (princ "\n")
        (_PrintMethod item)
        (if (vl-consp x)
    (_Main x 0)
(prinh prinh)
        X
        _PRINTITEM
        _PRINTLIST
        _MAIN
        DEFUN
        _PRINTITEM
            _PRINTMETHOD
            ITEM
            INDENTS
            PRINC
            "\n"
            REPEAT
            INDENTS
                PRINC
            _PRINTMETHOD
            ITEM
            PRINC
        DEFUN
        _PRINTLIST
            _PRINTMETHOD
            LST
            INDENTS
            _PRINTITEM
            _PRINTMETHOD
                CHR
                40
            INDENTS
            MAPCAR
                QUOTE
                    LAMBDA
                        X
                        _MAIN
                        X
                            1+
                            INDENTS
            LST
            _PRINTITEM
            _PRINTMETHOD
                CHR
                41
            INDENTS
        DEFUN
        _MAIN
            X
            INDENTS
            IF
                VL-CONSP
                X
                IF
                        LAMBDA
                            X
                            AND
                            X
                                ATOM
                                X
                        CDR
                        X
                    _PRINTITEM
                    PRIN1
                    X
                    INDENTS
                    _PRINTLIST
                    PRINC
                    X
                    INDENTS
                _PRINTITEM
                PRIN1
                X
                INDENTS
        _MAIN
        X
        0
Funny, almost looks like my vertical coding style; bwaaa!
 :-D
Sdoman
« Reply #5 on: June 02, 2006, 08:36:54 AM »
Niceness.  It does resemble your formatting style a little.  Just noticed too, the subtle change of switching to Defun-q so that the actual code can be manipulated.
« Reply #6 on: June 02, 2006, 09:49:44 AM »
Wasn't that I wanted to be able to manipulate prinh, I just wanted to demonstrate you could walk a function's code if were defuned by defun-q. Rather than pen a contrived sample function using defun-q for prinh to examine, I thought it would be fun to have prinh look up its own skirt.
« Reply #7 on: June 02, 2006, 10:05:33 AM »
Command: (defun prinh_2 (x)
(_>    (if (atom x)
((_>      x
((_>      (cons (prinh_2 (car x))
(((_>            (prinh_2 (cdr x)))) )
PRINH_2
Command: (prinh_2 pi)
3.14159
Command: (prinh_2 '(1 2 3 (4 5 (6 7)) 8 9 (0)))
Command: (prinh_2 3.14)
3.14
« Reply #8 on: June 02, 2006, 10:14:30 AM »
(_>    (if (atom x)
((_>      x
PRINH_2
3.14159
3.14
« Reply #9 on: June 02, 2006, 10:18:28 AM »
fwiw, this is what I ended up putting in my library. It's not the most concise but it seems to run reliably, reasonably quickly AND I can understand it.
        (princ "\n")
        (_PrintMethod item)
        (_PrintItem _PrintMethod "(" indents)
        ((lambda (i) (foreach x lst (_Main x i))) (1+ indents))
        (_PrintItem _PrintMethod ")" indents)
        (if (vl-consp x)
    (_Main x 0)
GDF
« Reply #10 on: June 02, 2006, 11:39:36 AM »
Michael
This maybe a stupid question on my part, but I will ask anyway. Could this routine be used on a dcl code?
Gary
« Reply #11 on: June 02, 2006, 07:23:19 PM »
Hi Gary.
It's not a stupid question, I could see how a function that hiearchically displays dcl code might be useful for development / debugging purposes. However, as currently coded, prinh could not be used on dcl code directly.
- Michael.
« Reply #12 on: June 03, 2006, 12:45:57 PM »
Hey Gary --
IF you preprocessed a dcl definition a slight mod to prinh might work for you.
Example, a standard AutoCAD dcl definition (from tblname.dcl) --
tblname : dialog
 label = "";
 key="dlgTitle";
 : column
  : spacer {}
  : text_part
    key="msg";
    label="";
  : boxed_column {
     fixed_width=true;
     width=50;
     : list_box {
        key="name_list";
     : row {
       : button {
         fixed_width=true;
         width=5;
         key="pickit";
         label= "&Pick<";
         alignment=left;
       : edit_box {
         key="name";
         is_default=true;
         edit_limit=256;
         alignment=left;
         fixed_width=true;
         width=41;
     } //row
     : spacer {}
  } // boxed column
  : row
     : spacer {}
     : button {
        fixed_width=true;
        width=11;
        key="accept";
        label= "OK";
     : button {
        fixed_width=true;
        width=11;
        is_cancel=true;
        key="cancel";
        label= "Cancel";
     : button {
        fixed_width=true;
        width=11;
        key="help";
        label= "&Help";
        is_help=true;
     : spacer {}
  } // row
  : text_part
    key="error";
    label="";
 } // column
Step 1:
• trim leading/trailing space
• force statements / braces to their own line
• delete comments
• replace quotes (") with backslash quote (\")
tblname : dialog
label = \"\";
key=\"dlgTitle\";
: column
: spacer
: text_part
key=\"msg\";
label=\"\";
: boxed_column
fixed_width=true;
width=50;
: list_box
key=\"name_list\";
: row
: button
fixed_width=true;
width=5;
key=\"pickit\";
label= \"&Pick<\";
alignment=left;
: edit_box
key=\"name\";
is_default=true;
edit_limit=256;
alignment=left;
fixed_width=true;
width=41;
: spacer
: row
: spacer
: button
fixed_width=true;
width=11;
key=\"accept\";
label= \"OK\";
: button
fixed_width=true;
width=11;
is_cancel=true;
key=\"cancel\";
label= \"Cancel\";
: button
fixed_width=true;
width=11;
key=\"help\";
label= \"&Help\";
is_help=true;
: spacer
: text_part
key=\"error\";
label=\"\";
Step 2:
• enclose all lines in quotes except brace lines
• convert braces { } to parenthesis ( )
"tblname : dialog"
"label = \"\";"
"key=\"dlgTitle\";"
": column"
": spacer"
": text_part"
"key=\"msg\";"
"label=\"\";"
": boxed_column"
"fixed_width=true;"
"width=50;"
": list_box"
"key=\"name_list\";"
": row"
": button"
"fixed_width=true;"
"width=5;"
"key=\"pickit\";"
"label= \"&Pick<\";"
"alignment=left;"
": edit_box"
"key=\"name\";"
"is_default=true;"
"edit_limit=256;"
"alignment=left;"
"fixed_width=true;"
"width=41;"
": spacer"
": row"
": spacer"
": button"
"fixed_width=true;"
"width=11;"
"key=\"accept\";"
"label= \"OK\";"
": button"
"fixed_width=true;"
"width=11;"
"is_cancel=true;"
"key=\"cancel\";"
"label= \"Cancel\";"
": button"
"fixed_width=true;"
"width=11;"
"key=\"help\";"
"label= \"&Help\";"
"is_help=true;"
": spacer"
": text_part"
"key=\"error\";"
"label=\"\";"
Step 3
• enclose the whole mess in quoted list '( ... )
• assign to a variable
(setq dcldef
        "tblname : dialog"
        "label = \"\";"
        "key=\"dlgTitle\";"
        ": column"
        ": spacer"
        ": text_part"
        "key=\"msg\";"
        "label=\"\";"
        ": boxed_column"
        "fixed_width=true;"
        "width=50;"
        ": list_box"
        ": row"
        ": button"
        "fixed_width=true;"
        "width=5;"
        "key=\"pickit\";"
        "alignment=left;"
        ": edit_box"
        "key=\"name\";"
        "is_default=true;"
        "edit_limit=256;"
        "alignment=left;"
        "fixed_width=true;"
        "width=41;"
        ": spacer"
        ": row"
        ": spacer"
        ": button"
        "fixed_width=true;"
        "width=11;"
        "key=\"accept\";"
        "label= \"OK\";"
        ": button"
        "fixed_width=true;"
        "width=11;"
        "is_cancel=true;"
        "key=\"cancel\";"
        ": button"
        "fixed_width=true;"
        "width=11;"
        "key=\"help\";"
        "label= \"&Help\";"
        "is_help=true;"
        ": spacer"
        ": text_part"
        "key=\"error\";"
        "label=\"\";"
Step 4
• message the prinh function to suit (a very fast stab)
(defun _PrinDcl ( x / _PrintItem _PrintList _Main )
            (   item
                (princ "\n")
                (_PrintMethod item)
            (   (princ " { }")  )
        (if (< -1 indents) (_PrintItem _PrintMethod "{" indents))
        (if (< -1 indents) (_PrintItem _PrintMethod "}" indents) (princ))
        (if (vl-consp x)
                (_PrintItem princ x indents) ;; formerly prin1
    (_Main x -1)
Step 5
• Run it
(PrinDCL dcldef)
Result
tblname : dialog
    label = "";
    key="dlgTitle";
    : column
        : spacer ()
        : text_part
            key="msg";
            label="";
        : boxed_column
            fixed_width=true;
            width=50;
            : list_box
                key="name_list";
            : row
                : button
                    fixed_width=true;
                    width=5;
                    key="pickit";
                    label= "&Pick<";
                    alignment=left;
                : edit_box
                    key="name";
                    is_default=true;
                    edit_limit=256;
                    alignment=left;
                    fixed_width=true;
                    width=41;
            : spacer { }
        : row
            : spacer { }
            : button
                fixed_width=true;
                width=11;
                key="accept";
                label= "OK";
            : button
                fixed_width=true;
                width=11;
                is_cancel=true;
                key="cancel";
                label= "Cancel";
            : button
                fixed_width=true;
                width=11;
                key="help";
                label= "&Help";
                is_help=true;
            : spacer { }
        : text_part
            key="error";
            label="";
All you have to do is code up functions to achieve steps 1 - 3.
GDF
« Reply #13 on: June 05, 2006, 10:30:31 AM »
Michael
Thanks...I was hoping this could be done.
Gary
taner
« Reply #14 on: June 19, 2008, 09:20:45 AM »
Hi Gary.
- Michael.
Dear MP,
Could you please change the code to automatively creat dcl file? tks!
