Mark, It's just a simple object from the design center, a cabinet, a sink, a refrigertor. These are blocks, but they are objects. When inserted into a drawing, they take on the effect of an object. If you want to do a section or elevation of a room, these objects are there, there is no need to draw them, they are already inserted into the dwg.
When I was working on ADT 2ki, I could drop these into a drawing on any particular layer and they would take on the color and linetype of that layer.
With ADT 2k4, they are inserted in block form even though they are objects. Unfortunately, they are BY BLOCK so no matter what layer they are placed on, they are layer 0, white because they are BY BLOCK. 2ki wasn't as picky with these things as 2k4 is, with 2ki, you mearly had to designate the layer and they took on the attributes of that layer.
So I need to either find or write a lisp that will allow me to edit these objects without messing up the display of them, to change them to bylayer, or I need to ... do something else.
I'll try to upload a small dwg so you can see what I'm do'in.
Ron,
Yes, that does the trick. Can I edit this to be able to pick which blocks I want this to happen to rather than have it scan and go through everything
